  New Posts New Posts RSS Feed - lt vent window
lt vent window
emccallum View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote emccallum Quote  Post ReplyReply Direct Link To This Post Topic: lt vent window
    Posted: August-02-2010 at 11:26pm
After breaking a couple I just made them out of plexiglass from Lowes. I made a cardboard template, cut it out, and polished the edges. Glued it into the hinge. Ready for the next time I forget and leave it open when docking in a tight area.
JERGY2.0 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JERGY2.0 Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2010 at 11:12am
e-mail sent
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2010 at 2:21am
Larry,
I have the glass, but it does not have the metal trim that acts as the hinge. I needed the passenger side glass for my 1980 and I found one. Once I got the glass with metal trim, the glass was slightly shorter ( 1/2"). Upon more inspection the angles were slightly different.
I removed my right (Driver) side glass and took it to a glass shop and made an exact copy ( Green type glass with two 3/8" holes drilled) and they sent it out to be tempered. We put the metal trim piece on the new glass so now I have a complete window. The metal trim is still slightly different, but it works.
This old glass, without trim may fit your boat. I am not sure where it came from, but it may of been from a 82-83 2001 Hull. E-Mail me and I can send you some measurements and a picture of what I have to see if it will work for you. I found the Taylor Tee Handles on E-Bay. I got lucky. The Taylor Adjustable Arms are available on E-Bay also. I got mine at Wholesale Marine.com . They also have some Plastic Tee locks that may work for you. The orginal Tee Handles, they act as locks, are hard to find.
If you do not have the metal trim piece, this glass will not do you any good. If you have a cracked window or a broken window with the trim I may be able to help.
Donald
Post Options Post Options   Thanks (0) Thanks(0)   Quote JERGY2.0 Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2010 at 10:48pm
Hey, does anyone have a left vent window glass I could buy, for a '81 SN........THX
