Foam |
tstafford
Groupie Joined: March-15-2004 Location: United States Status: Offline Points: 81 |
Posted: June-03-2004 at 3:14pm |
Well, the new stringers and bulkhead are in and it's time for the foam. Does anyone have a source and advice on refoaming? How much foam will I need? Cost?...
Trevor 1968 Mustang
ken@ckbd.com
Newbie Joined: May-31-2004 Location: United States Status: Offline Points: 17 |
Trevor,
I did the foam thing 11 years ago on my Mustang. At the time the only product I could find was called "Mountains in Minutes". It's used by model railroaders to create foam mountains and landscapes. I was able to buy it in 1 gallon cans (2 parts) and we used about 4 or 5 sets of the stuff (8 to 10 gallons). There's a lot of waste that gets cut away. I just tried a search on Yahoo and nothing showed up...it may not be available anymore, I don't know. I know it was expensive stuff back then. Jeff at CC told me that the key was to use a 'closed cell' foam. The spray foam you get in a can at Home Cheap-o' is not closed cell and not recommended. Also, invest in plenty of latex gloves and a good resperator mask!!! Good luck. |
68 Mustang
Rbest
Newbie Joined: January-22-2004 Location: United States Status: Offline Points: 23 |
I used TAP X-30 Polyurethane Foam
http://www.tapplastics.com Did you take any pictures? |
Rob 68MustangSS
ken@ckbd.com
Rbest,
I don't know if Trevor took pictures, but I did; lots of them. I have to find them and scan them into my computer to share with everyone. Do you have any pictures of that SS? |
68 Mustang
kenny g
Senior Member Joined: December-13-2003 Location: United States Status: Offline Points: 318 |
TREVOR,call john greer,619-238-1919.for flotation [closed cell]foam.they will ship it to you.
how did the gunwhale pattern work out for you ? $65 for a set,1 set = 2 gl of product - 1/2 of it is waste + shipping cost.it's cheeper to buy it in 5 gl buckets'but shipping cost go's up |
kenny g
Rbest
I've got a couple of me putting the 351 in. I am far from being done.
Rob 68MustangSS
tstafford
Ken, how many gal. will it take to do the job?
The paterns that you sent are great. I am waiting to finish the floor before I tackle that project. With the floor in I can be sure of my mesurements. |
Trevor 1968 Mustang
kenny g
trevor,i have not put the foam in yet i figured on 4 sets,= 8 gl .when you check www.john greer website you'll see it's cheaper just to order 5gl part a and 5gl part b . i removed ALL the foam in mine,up in front it's almost 3' thick.only yhe lowest part at the keel was wet ,but as i was digging it out i ran into a nest of little black hungry piss ants.sooo..all the foam,and ants are gone
sorry about that trev,it's www.jgreer.com |
kenny g
77stang
Senior Member Joined: May-19-2004 Location: United States Status: Offline Points: 342 |
US Composites. here's the specific page. http://www.shopmaninc.com/foam.html
