  New Posts New Posts RSS Feed - Trailer Carpet
Trailer Carpet
drtybrdy9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drtybrdy9 Quote  Post ReplyReply Direct Link To This Post Topic: Trailer Carpet
    Posted: September-16-2010 at 3:00pm
I need to replace the carpet on my trailer. Where is the best place to buy it and what should I use to attach it to the wood? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2010 at 4:21pm
Mason,
Most will use trailer bunk carpet that's available from any marine supply. It's stapled on with ether stainless or monel staples.
How's the wood?
Tell us more! What's the boat? Condition? Get some pictures submitted for the diaries. There's a link in that section for the application.
Welcome to CCfan.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2010 at 4:39pm
This is true unless you have a newer Correct Craft or Ramlin trailer (mid 80's or later), as they have bunks that are longer than the 12' bunk carpet that is commonly sold. Without buying an entire roll of carpet, your best bet in this case is a CC dealer (White Lake, etc).
Post Options Post Options   Thanks (0) Thanks(0)   Quote drtybrdy9 Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2010 at 5:01pm
The wood is ok condition I think, not really sure until I get all of the old stuff off. Its a 2005 so I'm sure it can't be too bad. Also, the heater on my boat doesn't work, being new to all of this, what is a likely problem?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2010 at 5:09pm
Mason,
No heat or no blower?
If the blower is out, then you'll need to trace the wiring back to it's source and see if it's getting power. If it is, then the blower motor is out.
If it's no heat, trace the engine coolant lines back to the engine and tell us how they are connected to the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote drtybrdy9 Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2010 at 6:26pm
When i press the heater button on the dash, nothing happens. Is there a different motor for the actual blower and the heater blower or is it the same one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2010 at 6:55pm
Mason,
Better get the volt/Ohm meter out!! There will only be one power feed to the heater. There's one blower.
dmiracle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmiracle Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2010 at 7:03pm
Contact Ram-Lin directly. They can sell you the whole OEM carpet package that's pre-cut and everything needed for your trailer.
I believe total cost was around $65.
Doug
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2010 at 7:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmiracle Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2010 at 7:30pm
Just to clarify, the package and price I referenced above included bunks, side steps, and bow stop.
Doug
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2010 at 7:51pm
$53 (before discount) from White Lake
ccf gets discount??
need some decals...
98ski-AIR! View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 98ski-AIR! Quote  Post ReplyReply Direct Link To This Post Posted: October-01-2010 at 8:18pm
Wow! I just Joined CCF, but have been to the site many times when I was looking to buy a Nautique. This is a great website. Plus, you guys are great! I came to ask a couple questions and they had been already asked and answered...glad you guys are here to help us newbies!
Pat
Whitfield View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Whitfield Quote  Post ReplyReply Direct Link To This Post Posted: October-01-2010 at 8:41pm
Again I'm saddened that I don't yet own a Correct Craft... Whitelake and CCfan make this stuff so easy.
I just bought bunk carpet by the roll eBay item #200519961418 26 oz!!! Blue Boat Trailer Bunk Carpet - 11"x50' $35
I'm looking at using left over carpet glue on top and stainless staples on the underside.
Michael ....
I'm the black sheep ~ 1984 Dixie 299 Super Skier (350 Chev PCM / counter rotation / Velvet drive) Open Bow.
tnplicky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tnplicky Quote  Post ReplyReply Direct Link To This Post Posted: October-02-2010 at 12:02am
maybe it goes with out saying, but if you don't have a pnuematic narrow gauge stapler, find a friend that does or look into renting one
