  New Posts New Posts RSS Feed - Winterizing an EFI engine
GK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GK Quote  Post ReplyReply Direct Link To This Post Topic: Winterizing an EFI engine
    Posted: October-04-2010 at 4:00pm
Hi. I am new to correctcraftfan.com I apologize if I have duplicated this topic. I am trying to get the full set of instructions to winterize my boat. I looked in the engine manual section but do not see a manual for my 351 EFI engine (1998 Nautique). Any help you can provide to point me in the right direction. I have never winterized a boat before (actually my husband is going to do it for me with me looking over his back ). Thanks for your feedback.
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2010 at 4:35pm
Gretchen,
Sounds like you have a GT-40, does the boat have a shower or heater?
GK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GK Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2010 at 5:19pm
no shower, but it does have a heater.
GK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GK Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2010 at 5:22pm
oh and yes it is a GT-40.
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2010 at 6:49pm
Your owners manual should have some limited info on winterizing, the PCM manual gets a bit more specific. Not sure if those manuals are on this site, I do know you can find them both on Planet Nautique.
You may want to try searching on this site as I would imagine this has been covered in more specific detail.
Basically there are certain steps that need to be taken, different engines will vary slightly in terms of location of drain plugs, heater hoses, etc.
Fill fuel tank 95% full with Sta-Bil added
Run engine to warm and move treated fuel thru system
Change oil/filter & trans fluid
Lube rudder
Drain fuel control cell water/replace filter as necessary (see manual)
Run again briefly to circulate clean replaced fluids
Drain water throughout system: block, low hoses/water pump, exhaust manifolds, heater, strainer (clean & drain), trans cooler, etc. (see manual)
Refill system with anti-freeze solution: different ways to accomplish, pour in, run through, etc. - use method of choice.
Drain speedo's/pitots
Remove spark plugs and spray treatment/fogging oil into each cylinder - once complete rotate engine by hand a couple full rotations
Remove battery, store in warm dry location & charge fully then periodically
Completely dry interior and bilge
Clean and wax hull
Clean and treat interior with Babes or 303 protectant, spread dryer sheets around interior as a rodent deterrent.
If you have access to the boat over the lay-up it's a good idea to exercise the steering every 2-4 weeks by cranking the wheel back and forth several times to ensure the cable remains lubed.
Hopefully that cover most or all items???? Your trailer may need certain maintenance items as well depending on hub type, lube points, etc.
As mentioned a search should probably turn up several threads and maybe even some pic's to assist.
Good Luck.
GK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GK Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2010 at 6:50pm
I found the winterizing checklist on another post so I think I am all set but have one question about put fogging oil into the spark plug cylinders. One person I spoke with said not to do it because it can cause hydostatic locking. I see in the manual it says to take great care doing this. Should I avoid it all together like I was told or follow the manual and pour 1 teaspoon full into each cylinder???? I have a hard enough time following recipes when it comes to baking so I am very nervous about doing this.
GK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GK Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2010 at 7:06pm
Quinner - Thanks so much for taking the time to answer my question and give me more information on winterizing. The PCM manuals that I have found on this site and Planet Nautique appear to be for carbureted engines but they are pretty specific and are helpful.
storm34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2010 at 6:53pm
great post quinner
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2010 at 7:09pm
and now for the pictures
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2010 at 9:17pm
....of CQ getting the water out of the heater and hoses!!
east tx skier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote east tx skier Quote  Post ReplyReply Direct Link To This Post Posted: November-12-2010 at 8:26pm
Quick question regarding turning the engine over by hand. How exactly are you guys doing this. Are you just locking onto the pull with something, pulling the kill switch and turning it over once? That seems logical, but I don't want to mess this up.
1998 Ski Nautique (Red & Silver Cloud); GT-40; Perfect Pass Stargazer; Acme 422.
Clew In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clew In Quote  Post ReplyReply Direct Link To This Post Posted: November-12-2010 at 8:53pm
Clew In
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: November-12-2010 at 9:35pm
Doug,
I use the bolt in the center of the crank pulley and turn it over with a socket wrench. Much easier if you do it plugs out and that also allows you to spray the cylinders a 2nd time lightly if you stop your rotations 180 from where you started.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: November-13-2010 at 9:30am
I have a real hard time with pulling plugs and spraying the cylinders, I dont get it, its impossible to spray the criticals in that cylinder and gravity keeps the oil pocketed in the cylinder...I pulled alot of heads over the years on boats and see no difference in non fogged engines compared to fogged engines...maybe its just me.
I really would think by making the intake air tight it would protect more
Post Options Post Options   Thanks (0) Thanks(0)   Quote east tx skier Quote  Post ReplyReply Direct Link To This Post Posted: November-13-2010 at 5:58pm
Thanks, Quinner.
rightnwrong View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rightnwrong Quote  Post ReplyReply Direct Link To This Post Posted: December-03-2010 at 10:10am
What if you go in a mechanical shop? I'm sure they can help you a lot there. :)
