  New Posts New Posts RSS Feed - 86 SN rebuild
86 SN rebuild
 Post Reply Post Reply Page    <1 45678 11>
Keeganino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2010 at 6:52pm
Originally posted by gun-driver gun-driver wrote:
Man all it takes is someone talking about their wood to get a good rise out of Pete!!!
Out of context this is truly a Hollywood moment
1973 Skier
Sephmu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sephmu Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2010 at 2:57pm
Just saw this thread today, loving it! I remember doing stuff like this with my Dad when I was your son's age (not quite as involved as a re-string though!) and it was that kinda work that turned into my hobbies later in life...as with most here I assume.
One word of caution...In 10-15 years, your driveway will become your son's workshop!!!
I don't have my own garage at the moment and after rebuilding my trailer etc. this summer in pops' driveway, and seeing him shake his head at all the rust flakes and paint everywhere, I can't help but laugh and remind him that he started it!
Keep up the good work, I really admire all you guys for your time and effort you put into redoing these classics...
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2010 at 1:51pm
Six pages and one secondary bedded this thread may top them all
Ranger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranger Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2010 at 11:25am
Pbrain,
That's how I'm doing it. I scribe both sides and use a power plane. Once I get it close, I usually finish it up with a belt sander. The main is just taking me a little longer than I expected.
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2010 at 10:22am
I knew it wouldnt be long
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2010 at 10:19am
Jeff,
I you use a compass or divider its easier.
Set your stringer level then take the compass and set it to the widest gap you have. Then run the compass the length of the stringer keeping it square with the stringer and wah-lah done deal.
The actual scribing is the easy part. It's the angular change of the cut fore to aft that's the challenge!! Scibe both sides and go after it with a power hand planer. Some hear have gotten cheap ones from Harbor and found them to work very well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2010 at 10:11am
Originally posted by Matt R. Matt R. wrote:
talked to a guy who has redone boats for 16 years and i asked him about dug. fir. because i am having trouble finding dug. fir and when i do it's outrageous in price. he told me he would not use fir but use a marine grade plywood with non oil in the plywood. Says it is much stronger than fir because you can make it whatever thickness you need. And also do you know the difference between the different types of marine grade plywood..with and without oil.
Sorry Matt but the guy doing boats for 16 years doen't know what the he's talking about!!!! Plywood stronger than a Fir solid? He sure isn't much of a engineer. Every layer of veneer the grain of the wood is rotated 90 degrees. In a stringer application, you want all the grain running fore to aft and not vertical. If you can't find Fir, take a look at LVL. All the grain in the veneer layers run the same way - the length. We have a member who's currently using LVL (microlam)
Also, what does he tell you to do at the ply splice needed due to the lenght issue? Scarf? Sister?
BTW, I've been working on wood boats for 42 years. If your friend what's to talk, I'd be happy to give him some advice!
37N122W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 37N122W Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2010 at 2:06am
I think it depends on the region you're in as well. Doug Fir is readily available in California so it's a good option. Other parts of the country have to special order it.
"It never gets easier, you just go faster." Greg LeMond
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranger Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2010 at 1:49am
Matt, there are several ways to skin a cat and if you use the search function on this site, you will find all kinds of reading material. But I would bet that for every person you find that says plywood is the answer, you will find an equal number of people who will say use fir, or composite, or coosa, or??? it will just keep going.
I'm very happy with my choice and feel very confident that I wont have any issues in the future.
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranger Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2010 at 1:45am
When I first set it in, I use a compass. But it never seems to get me as tight as I want to be. So, I usually follow up with the pencil. Basically the same thing, but the pencil is always set at 1/8 inch.
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2010 at 12:55am
Jeff,
Matt R. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt R. Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2010 at 12:38am
jeff sorry to hear about your truck,i just have a question ,talked to a guy who has redone boats for 16 years and i asked him about dug. fir. because i am having trouble finding dug. fir and when i do it's outrageous in price. he told me he would not use fir but use a marine grade plywood with non oil in the plywood. Says it is much stronger than fir because you can make it whatever thickness you need. And also do you know the difference between the different types of marine grade plywood..with and without oil. I'm just trying to figure things out. Thanks for the help.
Matt R.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranger Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2010 at 6:48pm
Wow, that's a great idea. But who would have 14 foot lengths of carbon paper? I'm using a thick pencil. If I lay it on its side, it will follow the contour of the hull and draw a line about 1/8 inch above the hull. I then take a plane or belt sander to the stringer and bring both sides to the line. Works pretty well.
What I had issues with was while I was scribing the front in, the rear wasn't settling enough to get the pencil to make a line. So, the front kept going deeper and deeper. Pretty soon, I had the stringer so out of level, it was almost looking like I should throw it in the fireplace and start a new one. But, I caught it soon enough and was able to drop the rear down to where it should be. I also take a flashlight and run it along the seam. You can see pretty easily where the stringer is not setting flush.
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2010 at 5:25pm
Jeff,
I don't know the specific method of scribbing you're using but if you are really getting down to a tight fit, lay down some carbon (copy) paper. Set the stringer down and move it slightly. The high spots of course will be black. I've used this method for tigh fits needed on joining complex shapes that are bright (stained and varnished). I got the idea one day after visiting the dentist!! The only problem is finding the carbon paper these days!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranger Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2010 at 2:47pm
Hi James, Padres fan? you bet! We had a great season and my son and I enjoyed watching. As far as my truck, I agree it's your fault. Send me $1,500 and we will call it even.
The boat is progressing nicely. Last night I almost finished scribing the starboard main. It seems as though, it's taking me longer with this one than the secondary I did last week. Not sure why, but it sure feels that way. I'm probably being too particular with the fit. I really want a nice uniform tight fit all the way along the stringer. So, I just keep working it.
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote 37N122W Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2010 at 2:23pm
Oh Snap! Sorry about the truck Jeff. It's likely my fault. My ex-boats seem to be bad luck for diesels. A few years ago, some dude's Ford Turbo blew up on the way to pick up a boat I was selling down in LA. Of course, the deal fell apart. The good news (for me at least) is, the SN is in your drive way already!
While we are on the subject of disappointing performances, I want to send my condolences for your Padres' effort towards the end of the season. Not sure if you're a baseball fan, but I just thought I'd try to cheer you up a little just in case. : )
You've been moving really fast on the boat. I bet once you get the other stringers out, it will come together really quickly.
JJ
C-Bass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Bass Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2010 at 2:05pm
By the way...enjoying this rebuild. Really glad several of you have went through these rebuilds on the mid 80's boats...feel like I've got my hands around it before I even start thinking about doing mine.
Craig
67 SN
73 SN
99 Sport
85SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranger Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2010 at 2:00pm
Getting back to the boat, I'm still planning on bedding the main this weekend. Once it's bedded, I will then start on the blocks and built up areas on the starboard side. If I can manage to get everything dry fitted and then bedded, I just might be able to cut the port main out. I really want to get all of the old stringers cut out and grinded clean. I think it will probably be the worst part of this project and if I have them all out, I will feel like I have accomplished my first goal.
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Bass Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2010 at 1:00pm
Not Fords fault!?! Last I checked the EPA mandates all engine manufacturers meet their standards. It's not the EPA's fault that Ford couldn't find a good solution, but other engine manufacturers did...\
Get a Cummins of course I'm a little biased.
Craig
67 SN
73 SN
99 Sport
85SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranger Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2010 at 11:51am
Thanks guys for the bilge pump suggestions.
As far as the truck goes, I have 115,000 miles on it so far. Yes, I'm familiar with the engine cooler blockage issues and EGR cooler failures. I have decided to use Bullet Proof Diesel's products. They make a bolt up EGR cooler that eliminates the smaller fin design of the stock cooler. Much better design in my opinion I also ordered there new oil cooler. Their cooler eliminates the stock water fed unit with an exterior mounted air cooled unit. It also gets rid of the original oil filter assembly. The oil cooler is kind of pricey, but since I'm not paying any labor, I will be actually saving money than the dealers quote. Check them out on line at bulletproofdiesel.com
As far as the Turbo, they said it was bad, but they couldn't tell be what was wrong with it. They had a new one priced on the quote however. So I went ahead and ordered a new Garrett Powermax. Cheaper than stock, but a much better unit. They are backordered 6 weeks, so I won’t have it for a while.
I have a lot of experience with gas engines, but not diesels. But this is fairly straight forward. Just a bunch of parts to remove to get to the EGR cooler.
Thanks again for everyone's suggestions.
Jeff
NAUTIQUEjunky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NAUTIQUEjunky Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2010 at 1:24am
Quote.hmmm, must be a 6L. sorry to hear about that Ranger. Such a common issue I can't believe Ford turns a blind eye to it.
Its not Fords fault the EPA got involved in 03 and told manufactures they had too put emission bull chit on there diesel's. Diesel engines dont need EGR systems or converters. But there were forced to do so by EPA. My 04 6.0 no longer has a working egr cooler or converter they got blocked off or removed somehow
Ranger let me know if you have any questions, i have some experience on turning wrenches on 6 oh's. I do find it hard to believe they siad you needed egr cooler, oil cooler, and a turbo all at the same time. The oil cooler blocks coolant flow and causes the egr cooler to fail. The turbo could be salvaged unless there is lots of corrosion from the coolant going through it.
1977 MasterCraft Stars&Stripes
1994 Ski Nautique
2000 Super Air Nautique
1986 Ski Nautique 2001
1999 Sport Nautique gt40 current
79TiqueRebuild View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79TiqueRebuild Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2010 at 8:54pm
I just used some thickened epoxy and set the stainer down on it. Where it came through the screw holes i flattened it down to help hold it down. When it setup I snapped the pump back on the strainer.It doesn't take much epoxy. Monty
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2010 at 8:00pm
Originally posted by Ranger Ranger wrote:
I think I read about glueing done somewhere else too.
I also used these and hot glued them to my stringers so that I didn't have to screw the cable ties into the stringers.
So far so good with them holding.
http://www.lowes.com/pd_292685-1781-45-1MBUVL_0__?productId=3128405&Ntt=adhesive+cable+ties&pl=1¤tURL=%2Fpl__0__s%3FNtt%3Dadhesive%2Bcable%2Bties
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2010 at 7:39pm
Originally posted by Bremsen Bremsen wrote:
On the pump mount, I was thinking you could just use some 4200 to glue a small scrap of HDPE then screw the pump to that. Its probably the way I'm going to go on mine.
I thought about doing something along those lines but wanted the pump to be at the lowest point.
The only way to do that was to fill and taper then glue right to the hull.
Works very well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2010 at 7:34pm
I have ran into my first stumbling block. Not the boat, but my truck. I drive a 2006, F350 diesel and the EGR Cooler, Engine Cooler, EGR valve and Turbo decided it was time to take a dump. My first quote.... $6,200, my second quote.... $5,700, My third quote.... $4,700. My last and final quote..... My driveway so that I can do it myself. I sure don't want to waste the time and money, but it looks like I haven’t a choice. I'll park the truck next to the boat, so that I can gaze over the gunnels once in a while.
On another note, the turbo I bought is back ordered for 6 weeks. So, maybe I can get the stringers at least bedded before I tear into the ford.
Jeff
How many miles are on her. I have a '06 F-250 Power Stroke
Bremsen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bremsen Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2010 at 6:28pm
you were making great progress on the boat, I'm sure you'll get back to it in no time. On the pump mount, I was thinking you could just use some 4200 to glue a small scrap of HDPE then screw the pump to that. Its probably the way I'm going to go on mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranger Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2010 at 6:21pm
Thanks Gun-Driver, I think I read about glueing done somewhere else too. Makes sense. When I grinded my pad out, it too held a lot of water. Your's looks good, I especially like how you changed the hull so that it drains more effiecently.
Thanks Gun-Driver, I think I read about someone else gluing their pump down too. Makes sense. When I grinded my pad out, it too held a lot of water. Yours looks good, I especially like how you changed the hull so that it drains more efficiently.
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2010 at 5:57pm
Jeff,
There is ply under the glass for the bilge mounts. And it will trap water!!
I ground mine out then leveled with epoxy and used a couple uf dabs from a hot glue gun to attach the pump strainer. Worked great and no screws!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranger Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2010 at 6:38pm
Thanks for the advice Gun Driver. Something I need to consider. I would certainly like to get them all bedded, but then again, I need room to get to everything.
Thanks Charger, I think I will go that route. Put down a couple of extra layers of glass and be done. I can't wait until I'm as close as you. Post some pictures, I would love to see how you did yours.
Jeff
charger496 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote charger496 Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2010 at 6:12pm
Jeff,
As far as the bilge pump pad goes, it should only be enough extra layers of glass to hold the pump down with the short screws. No wood necessary. You're movin' right along with the build! I've got the motor assembled, and everything glassed in except the floor pieces on the '77 SN. (I know, pictures!) I hope to paint the bilge and drop the motor back in next weekend, then I'll feel like I'm getting close. My goal is to get it in the water just in time to winterize it.
