NOT GETTING FULL POWER |
Post Reply | Page <12 |
Rick
Senior Member Joined: March-03-2004 Location: United States Status: Offline Points: 338 |
I spoke with Steve and he has the DIS
docmartini
Newbie Joined: June-02-2004 Location: United States Status: Offline Points: 6 |
Yes, I do have the DIS.
Here is a picture of it. I got another carb to test out on my boat last night. I will be testing tonight to see if that was my problem. Wish me luck. I do not think this is the issue, however I have to rule it out once and for all. I want to go water skiing so bad. Steve |
STEVEN MARTINI
70 degress and sunny |
docmartini
By, the way. PCM does not make this part anymore and they have replaced it with a standard electronic distrbuter system. I would like to know where I could find one of these
STEVEN MARTINI
It looks like a magnavoz system I would try the auto parts store. If memory serves me right the coils are one big potted assembly and you have to replace all at once but maybe thats just for the V6 applications. The picture looks like it is broke up into two seperate coil packs and you could get by with one. Check the plugs and look for a fouled plug or plugs and trace it back to the coil pack and replace that one first. GM scraped Maganavox's system a couple of years into production as well and replaced it with there own system.
66polyhead
Senior Member Joined: December-20-2003 Location: United States Status: Offline Points: 171 |
Man am I glad mine has breaker - point ignition! But it looks like something I'd like to work on. Good luck!
kenny g
Senior Member Joined: December-13-2003 Location: United States Status: Offline Points: 318 |
66POLYNOGGIN..i cant find your # call me this week when you get a chance 371-1852.
kenny g
docmartini
Just wanted to let you know that my problem was the carb after all. Even though I had it rebuilt by San Diego Carburator and they refused to believe that it did not work, it was that after all. I made them give me another carb and know she is running like a top. Thank you for all of your help, I have learned a lot and appreciate the time that you took to help me out. If you are ever in S.D and want to go for a ski, I am your guy. Take care,
Sincerely, Steven Martini |
STEVEN MARTINI
docmartini
Well I am back guys.
She is not running like a top anymore. Eric Raymond, (a great guy who let me borrow a 4160) that I met on this listserv. I have tried three carbs and keep getting three different problems. I am still convienced that it is the carb however. I have done numerous checks ont eh iginition system including hooking a timing light up to each spark plug wire and testing them under loads. I think it is possible that I am getting the problems in the fuel system. Some idle good, some idle bad, all have the same top end problem. Sometimes I get full top end speed, sometimes I do not. Dont know what to do. |
STEVEN MARTINI
Check your fuel pressure and make sure it is steady and does not change with rpm, or it changes very little.
Rick
Steve you sound like you need a good ski to ease the pain. How about Thursday or Friday?
64 Skier
Senior Member Joined: February-08-2004 Location: United States Status: Offline Points: 415 |
Different Carb's have different jets and Power valve or springs and metering rods so expect different results unless they're all tuned to your engine. Tuning one is not difficult and you can come close at idle with the proper tools. Just learned this the hard way myself.
Whether or not you do it, or someone else, measure your engine vacuum at idle. Knowing Vacuum is more important than the Carb selection. After you get the Power Valve set correctly, then the best way is to try WOT and then try to pull a skiier (recruit a big boy...it's a test!). After you get past this then start checking for color indications on the plugs. Have you mentioned the plug color? A "good" Holley man can do all this in a few minutes. A friend of mine who races will measure engine vacuum to set and also test when the Power Valve kicks in as well as tuning this with the vacuum advance and then the Secondaries. Your Carb Re-builder should be able to do this. If not, he's just another guy with a $2 bottle of carb cleaner and a set of gaskets. |
