  New Posts New Posts RSS Feed - Winterize Checklist??
Wacko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wacko Quote  Post ReplyReply Direct Link To This Post Topic: Winterize Checklist??
    Posted: September-26-2010 at 3:10pm
Hello,
I did try the search first but it didn't seem to be working.
Just wondering if you all could post your winterization checklists.
I will be winterizing my 1980 SN I purchased this spring for the first time in the next couple days and would appreciate any tips or tricks of the trade you may have.
Thanks in advance
sagres88 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sagres88 Quote  Post ReplyReply Direct Link To This Post Posted: September-26-2010 at 3:40pm
Jep me too!
I know the basic things, but maybe some extra tips?
Thanks.
1990 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-26-2010 at 4:25pm
Really, the best place to look is the owners manual. If you don't have one, take a look under "manuals" in the reference section.
Hawktique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hawktique Quote  Post ReplyReply Direct Link To This Post Posted: September-26-2010 at 11:47pm
Fill gas tank, and add fuel stabilizer.
Change oil
fog carb and cylinders
drain block and all hoses and fill with antifreeze
disconnect the battery (I keep mine on a battery tender)
seal exhaust flap
I put a dehumidifier in that drains out a tube through the hull drain to keep it dry inside(mine gets kept in a barn for the winter.)
"A Veteran is someone who at one point in his life, wrote a blank check made payable to: 'The United States of America,' for an amount of 'up to, and including his life." Semper Fi
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wacko Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2010 at 12:47am
How do you seal the exhaust flaps?
NAUTI84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NAUTI84 Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2010 at 11:10am
For what it's worth
Here's how I've done it for (20)years:
Fill tank. Add Stabilizer & Dry Gas
Run engine to running temp.
Change Oil & Filter.
Restart to running temp.
Fog Engine - Pour 6oz. Mystery oil slowely into carb.
Don't let it stall - Shut down as finish pouring (Heavy Smoke).
Remove Spark Plugs - Squirt Mystery oil in each Cyl. (about 1 tbs.)
Crank engine a few times to spread oil.
Replace plugs hand tight with wires on loose.
Drain fuel filter.
Remove Block drain plugs & Elbow Drain plug.
Poke holes with Coathanger wire to remove any debries.
Remove exhaust hose, flush out with hose, prop up to drain.
Remove Manifold drain plugs, Flush out with hose.
Disconnect all water hoses.
Thru engine block water hose Add Antifreeze.
Blow into hose to keep filling until you see it drip from manifold.
Remove water pump & Impeller.
Loosen Belts & Remove Battery.
Disconnect Speedos at both ends.
Cover Exhaust Outlets. (Plastic bag & wrap of Duct tape.)
Recommish:
Reverse above.
Spin oil from plugs (Lay towel over plug holes)
Change Tranny oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sagres88 Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2010 at 3:59pm
Thanks guys.
That's a big list!
Mine is running on LPG so i can skip the tank and carb part.
Is mystery oil a special kind of oil, or can i use something more familiar?
1990 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2010 at 4:29pm
Originally posted by sagres88 sagres88 wrote:
Thanks guys.
That's a big list!
That sure is a big list!! I used a 50/50 mix of Marvel and engine oil way back in the 70's. Although very good at fogging, it wasn't the easiest to use. I've since just stuck with one of the aerosol fogging oils down the carb only.
Btw, after 42 years of winterizing, I don't and have never done half of the above list!! Never a problem.
Keeganino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2010 at 11:53pm
Pete I thought you were older than 45
1973 Skier
east tx skier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote east tx skier Quote  Post ReplyReply Direct Link To This Post Posted: September-28-2010 at 6:21pm
I second giving the manual a close look. This is what I have used and it works well for me.
Winterization Checklist
This is not brand specific. So there are some alternate methods in there for some things, i.e., adding antifreeze by circulating through the water pump, that are more suited to Indmar motors. The dump 3 gallons in through the intake hose above the tstat housing is in there, too.
1998 Ski Nautique (Red & Silver Cloud); GT-40; Perfect Pass Stargazer; Acme 422.
98ski-AIR! View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 98ski-AIR! Quote  Post ReplyReply Direct Link To This Post Posted: October-09-2010 at 4:21pm
Is it a good idea to add antifreeze to ballast tanks? or not really necessary...if so how do you add it and how much?
1998 sport air nautique
Thanks
Pat
trippboucher3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote trippboucher3 Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2010 at 11:54pm
I live in Dallas. Do I need antifreeze, fogger, and to tape the exhaust? How long does stable last in the gas? If the oil and filter are 20 hrs old should I still change?
Thanks Everyone
trippboucher
