  New Posts New Posts RSS Feed - Engine rotation/ HEI conversion
classic63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote classic63 Quote  Post ReplyReply Direct Link To This Post Topic: Engine rotation/ HEI conversion
    Posted: April-24-2006 at 9:23am
1963 Classic w/215 V8 Buick. Will an automotive HEI dist work, or is the rotaion wrong. I believe my prop is LH. Thanks, BB
BB
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: April-24-2006 at 10:54am
if yours is a LH then that's conventional and it should work other than it's not a marine grade unit
SS-201 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SS-201 Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2006 at 6:00am
All CC boat from the factory use RH props. The late CC still use RH standard SAE rotation engines and change the PCM tranny, that goes either way to turn RH.
pcm tranny tha can tur
SS 201
tjackle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tjackle Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2006 at 10:28am
I can't believe that 79 is letting this go so easy. Automotive parts in a marine motor!?!?
(hehehe )
78 Nautique
If you're going to do it...
Do it in a boat
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2006 at 10:32am
With that engine the guy really doesn't have much choice, and all he really has to do is swap the vent screens from the marine unit he has to the new dist and be pretty religous with running the blower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote classic63 Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2006 at 11:25am
Hey thanks for the info.
However, my original distributor has no screens. It appears to be a common automotive dist. And where would screens fit in a dist?My boat also never had a blower system. I am planning on istalling a bilge blower. I purchased a Proform HEI unit for a 215 buick application. It is a couple inches taller than the points dist, but the same on the drive end.
I have a velvet drive 1:1 tranny. My prop is LH also.
BB
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2006 at 2:27pm
on the underside of the dist. base where the cap attaches too there may be two vents in the base housing. Sounds like conventional rotation so you shold be good to go.
