Winterizing ... plugs question ... |
damonwells
Groupie Joined: June-13-2006 Location: United States Status: Offline Points: 87 |
Posted: October-30-2010 at 4:14am |
why do some recommend only hand tighten spark plugs and leaving the cables loose over the winter ?
how important is it to torque the plugs and not just tighten them up 1/2 turn or so with wrench ? thanks, cheers, John |
John,
Leaving the plugs only hand tight isn't even in the engine manual. Who's telling you this and what is their reasoning? Was it someone at a marina? Marina's do have some tricks to increase their revenue. They get you back in spring for the so called BS "summarization"! The same is true with removing the RWP impeller. |
damonwells
I saw it on a post here that I Searched under Winterize Checklist. The Poster was NAUTI84.
It didn't make sense to me, I've never done that, which is why I asked. He also said to remove the water pump and remove Impeller. I actually do that, I store my pump in the garage where it won't freeze and I remove the impeller to inspect, or to replace the next year (I replace every 3 years) and to keep it from getting a set over the winter. Thanks. Cheers, John |
id like to see that post
Here it is Eric,6th one down.
It still doesn't say why!! I really don't see the logic?? Plus, unless you have a injected engine, fogging down the carb is sure easier!! It's always worked for thousands and thousands of winterizations. Maybe it was started by someone using the -100 stuff? Probably not as they were doing the "quick and dirty"!!!
a bit baffled but it does say that.
here is the easiest explanation for winterizing drain water, if you like fill with antifreeze |
skfitz
Senior Member Joined: October-15-2009 Location: Herculaneum Status: Offline Points: 138 |
yep. |
OverMyHead
Following Petes recommendations I simplified this year. I ran seafoam through system, filled tank with non ethanol (as usual) with seafaom added. Fogged down carb till stalled. Changed oil.(20w 50 vr) Drained all plugs and diconnected a few low points on intake hoses to drain, and removed strainer basket/container. I left the impellor in and filled above and below with antifreeze, and dumped antifreeze through t-stat housing till full. re-installed t-stat. charged and disconnected the battery but left in. Spring should be reconnect batttery and start.
1987 Ski Nautique |
Dave, Doing good except there's no reason to open up the T stat. Pour the AF down one of the hoses that goes to the T stat housing. |
