Transmision Fluid Leak |
jimbo
Senior Member Joined: September-07-2004 Location: United States Status: Offline Points: 473 |
Posted: April-27-2006 at 1:42am |
I've got fluid leaking down near the shift leaver. I pulled the shift lever but I can't figure out how to get the stud out. I assume there's an o-ring behind it that's worn out. Any suggestions?
Jim_In_Houston
Put a few drops of Dawn in your bilge and turn on your bilge pump when no one is looking. That's what I do.
jimbo
Usually I use Simple Green. This leak is pretty bad. I have to top off the fluid after each use. Sometimes during each use. I'm pretty sure it's coming from the shift lever stud. It might be the rear main gasket but fluid is up on the lever. Any help? |
jbear
J_I_H: Gotta love your solutions! I really do live to look forward to some of your answers. Never fails to crack me up. john
Jim_In_Houston
Jimbo, I buy Dexron III by the case - it's cheaper. And if you buy enough of it you start getting free delivery. I also have to stop and add fluid during use. I have trained several of my riders to perform the task fairly competantly. Do you get that sudden high engine speed slip when the fluid gets too low? It really blows the soot out of the cylinders. One of these days I will get my '66 in the water which will give me a chance to rebuild the tranny in the '68. Now there's an idea, you could use the tranny as an excuse to buy a "backup boat".
Jimbo,
Have you downloaded the velvet-drive disassembly manual yet from the reverence section? I had that valve off last summer, but I don't remember vividly enough to describe confidently. I think it was pretty straightforward. |
jimbo
I looked through the maunual but it wasn't much help. I must have missed the section on removing it. I took the value cover off and the shift lever but the stud didn't seem to want to move. I thought I should ask before I took the rubber mallet to it. J-I-H...Is that why they named it "Chocolate Bayou"? |
jimbo
Ok, I found it on page 24. Thanks.
