trans seal leak? |
rtsuggs
Senior Member Joined: January-19-2010 Location: alabama Status: Offline Points: 300 |
Posted: November-28-2010 at 12:46am |
I replaced the main shaft seal twice this past summer and the leak keeps comming back. The shaft is pitted very little. How can I stop it from messing up seals without installing a new shaft in the trans?
1978 ski nautique 1 to 1 velvet drive Thanks |
harriss28
Senior Member Joined: July-24-2010 Location: Titusville PA Status: Offline Points: 128 |
JB Weld and sand smooth
rtsuggs
really? that will hold up?
Rob |
Go with this Rob.I have had one on for 20yrs.Measure the shaft size and go to napa or a bearing supply house.
rtsuggs
Thanks I'll check into one of those. Does anyone know the shaft size?
Thanks |
Eric will,he's usually on here early.
Rob,
Speedy sleeve yes, epoxy no. |
or recess the seal until it rides on a good clean surface. there is room to push it in another 1/8 with no problem. its a double lip seal and the front lip is a dust seal. be more concerned about where the back lip rides.
if need be you can use a speedi sleeve, but i dont know the shaft size off of the top of my head because i measured it years ago and now merely just order the sleeve by part number, which also i cant remember until tommorow. but, do you think the shaft is clean enough to push it back farther? |
rtsuggs
Yea that's what I did the last time. I slid it back as far as I could but it didn't last a day before it started leaking. I'm going to get a speed sleeve as soon as someone can tell me the shaft size.
And also can someone tell me the part # on the seal I've lost the number some where. Thanks |
are you sure your pump is in good shape? is it leaking between the shaft and the seal?
Yes, Eric has mentioned it many times, that the seal really doesn't see any pressure if the pump is good. Time for a rebuild??? |
M3Fan
Re: the shaft size- Caliper?
rtsuggs
How do I know if the pump is going bad? It performed like it should all summer aside from having to put fluid in about every two trips to the lake.
Thanks |
ever run it low?
rtsuggs
not to the point it slipped or anything.
Rob |
