Sending Unit Gas Tank |
tcarden
Groupie Joined: February-21-2006 Location: United States Status: Offline Points: 54 |
Posted: May-03-2006 at 10:00am |
Got to reading your post yesterday and worked on my 82SN last night. Wasn't working properly. Easy to remove, 5 - 1/4 screws and remove from tank. Inspected and found as DavidF mentioned varnish on connections inside unit. I checked it with a volt/ohm meter and wasn't getting a reading when moving float. I sanded varnish off all conduction points, i.e. the spring and where the body grounds, used some brake cleaner and generally cleaned everything up good. I also stretched the spring on the float slightly because it didn't look like it was making good contact. reinstalled and it seems to work just fine. After I fill up with gas next time I will know if it is indicating right or not. If not can you adjust the reading on the back of the gauge or somewhere else?
It was a neat little evening project. When i had it apart I showed my 12 yr. old son how it worked using the volt/ohm meter. Don't think I impressed him much but hey he's 12 right?! |
"Boat - A hole in the water surrounded by wood (and fiberglass) into which one pours money"
tjackle
Groupie Joined: September-30-2005 Location: United States Status: Offline Points: 60 |
I replaced my sending unit for about $20. Local boat store had it. Works great now. If you have to remove the gas tank (like I did) $20 is cheap enough just to replace it.
David F
I gave this a bit more thought...
1. check the output of the sending unit with a multimeter (set to read resistance, ohms). 2. check the wiring connection at the guage. Sending units work on resistance. i.e. high resistance = empty indication and low resistance = full indication (or vise versa). A poor connection could be falsly providing a high resistance. But, I still think the sending unit is either varnished up or faulty. |
1998Nautique
Senior Member Joined: January-26-2006 Location: Canada Status: Offline Points: 190 |
I'll try it. Thank x a lot for your help. My first year with the biat so there we'll be lots of questions.
David F
Yes, definately. But, try cleaning up the one you have before you replace it.
1998Nautique
So chances are good it is my sending unit. The dial is way below the E and twitches a bit when I move the float?
Atmspltr
Senior Member Joined: May-04-2005 Location: United States Status: Offline Points: 170 |
By the way, I have an original mechanical fuel gauge with indicator on the top (the one you look down thru the topside to view) from a 67 Mustang in someone needs one. It's in great shape and still works. Didn't know if you wanted to keep it original.
RB |
David F
Sometimes, a bit of carb cleaner or brake cleaner sprayed liberally on the sending unit will remove the varnish and let the sending unit work again.
1998Nautique
Sure let me know.
If its got two wires you dont have to worry about it being grounded, a new sending unit should come with the float. I am hoping my new one arrives today from skidim, if your interested I will let you know what I think of it when it comes in. I don't have an old one to compare it to though since my boat originally came with a mechanical gauge a peep hole on the back deck to look down on it.
-Joe. |
1998Nautique
I had both wires hooked up to the sending unit when I was moving the float. Is that the proper way?
this is probably a stupid question but did you have the sending unit grounded while you were moving the float up and down
Atmspltr
West Marine or Boater's World...it does not need to be a Correct Craft item. It comes with everything you'll need. Take the old one for sizing.
1998Nautique
I pulled my sending unit out, and moved the float up and down. And the gas guage stayed well below the E and moved around a bit as I moved the float. I take it I will need a new sending unit. Does the unit come with the float and everything?
