  New Posts New Posts RSS Feed - Floor Replacement-69 Barracuda
Oobatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oobatz Quote  Post ReplyReply Direct Link To This Post Topic: Floor Replacement-69 Barracuda
    Posted: December-15-2010 at 2:49pm
I am replacing the rotten floor on my 69 Barracuda. The plywood is coming up in slivers. There is what looks like a thin layer of fiberglass under top layer of plywood. Does this need to be removed also? How do you tell if the foam is water logged? Any help would be greatly appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: December-15-2010 at 3:02pm
So this would be a small thin layer of plywood, over foam covered in glass. To put back together as original all layers are important.. the plywood holds the vinyl but also spreads out the impact on the floor so that it doesnt crack the glass or crush the foam. To inspect the foam get out a hole saw and go exploring if you find all is well a little patching is all you will need to do... if you find water keep digging till you don't. Most here will bet you find water and plenty of it and that minimally all the foam will need to come out, but no harm in hoping for the best and checking for the worst.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oobatz Quote  Post ReplyReply Direct Link To This Post Posted: December-15-2010 at 3:12pm
Is there any plywood under that thin layer of glass?
Is there any plywood under that thin layer of glass, or just foam?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-15-2010 at 3:29pm
Andrew,
Keep digging and in between do some reading here on stringer replacement. Lots of great info and threads on the subject.
How about some pictures?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-15-2010 at 3:42pm
If the boat is original, its just foam.
