  New Posts New Posts RSS Feed - car motor in boat?
car motor in boat?
fredo68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fredo68 Quote  Post ReplyReply Direct Link To This Post Topic: car motor in boat?
    Posted: May-05-2006 at 10:10am
may be dumb question, but i cant
find a motor for my 66 mustang
but i bought a lincoln continental
with a 302 with 32000 miles.
what if anything can i do to make
that work or am i completly out
of my skull.
desperate
fredo68
fredo68
jimbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimbo Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2006 at 11:57am
You can marinize the engine yourself if you're up to it. Some parts need to be replaced with marine parts like the distributor, starter, altenator and carb. You can probablly use some of the parts from your old motor (depending if the old motor was standard rotation). Depending on the rotation, you may have to do something with the transmission as well.
I'd recommend reading this book first:
http://boatdesigns.com/prodinfo.asp?number=12%2D431
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2006 at 1:19pm
If the 302 has a 2 piece rear seal you can't use the crank out of the car, because the wick lines will pull oil out the rear. Also you need a reverse cam so the valves will open in the right order. As far as the carb goes, I have the original '66 carb that came on my boat and it's not marine, neither was the fuel pump or altenator. All you'll probably be able to use is the block and the heads. Is the original motor a 302? It's probably a 260, and you'll need a different bell housing because the bolt pattern isn't the same. If you don't know, the two top bolts on the bell housing on a 302 are 5 3/16 apart and the 260 is 5 7/8 apart.
Tim D
advsouthwind View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote advsouthwind Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2006 at 8:36am
Your cam specs may be different also
Post Options Post Options   Thanks (0) Thanks(0)   Quote fredo68 Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2006 at 10:00am
great info thanks much i was sure
someone would blast me for the question
that gives me some ideas. i have the
original motor for the mustang would
it be wiser just to rebuild that one
thanks again
fredo68
fredo68
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2006 at 10:34am
Re-building what you have and adding a different cam, aluminum intake and doing some head work would really increase the HP and cost basicly the same maybe an extra 500 bucks if you tweak the heads a little.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fredo68 Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2006 at 12:10pm
79 nautique
ive got a 84 cutlass that we built
a dart 383 stroker for.
can get dart aluminum heads reasonable
would the automotive heads work or
strictly marine. ive got an extra
demon carb, and edelbrock pro performer
laying around. how radical of a cam
do you recomend. and since your 30 mins
from me where should i go for marine
parts or just mail order.
thanks a million
fredo68
fredo68
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2006 at 12:21pm
I doubt that I'm 30 min's from you since I don't live in Syracuse anymore,
you don't want to get too crazy with the cam, stay with 112 degree seperation and do a search here for cam specs and that will give you an idea what to go with. Automotive block parts are fine you just need to use the right type of piston's (hyperphudic -sp)and brass freeze plugs, I wouldn't really recommend aluminum heads, these angine really don't get hot enough and some have had issues using them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fredo68 Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2006 at 11:39am
bc
ok thanks for all the advice
im gonna get right on the rebuild
fredo68
fredo68
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2006 at 5:33pm
Fredo,
    After talking on the phone the other day, I figured out a way to deliver the 302 we talked about. If you find you're interested just let me know.
http://i54.photobucket.com/albums/g96/DrCC-74/66-75engine.jpg
    Here is a pic of the 302/175hp. Drop it in, hook it up and go!    call me
                         Thanks AT
88skisupreme View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 88skisupreme Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2006 at 5:53pm
I know a boat mechanic who has a pleasurecraft 351 in his truck
Post Options Post Options   Thanks (0) Thanks(0)   Quote fredo68 Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2006 at 2:22pm
dr cc
after careful consideration,
i think doing the rebuild
on the correct motor for the
boat is the best course of
action. i do thank you for
offering it to me for such
a reasonable price, im sure
youll have no problem selling
it.
thanks again,
fredo68
fredo68
