  New Posts New Posts RSS Feed - Torque Settings
Torque Settings
jagnweiner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jagnweiner Quote  Post ReplyReply Direct Link To This Post Topic: Torque Settings
    Posted: May-19-2006 at 9:37am
Not a CC owner, but you guys seem to have about the most helpful forum going. I have a '71 Century Resorter w/ a Chrysler 340 (great boat). One of the nuts holding the carb to the manifold has been missing for the three years I have owned it. I finally got around to getting a new nut, but was wondering how much this nut should be torqued down. I assume that it would be the same on pretty much any V-8.
Thanks.
Scott Johnson
AWhite70 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AWhite70 Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2006 at 10:42am
I use my calibrated arm and get it "about that tight". I've never been able to get a torque wrench on mine so I just snug them up pretty good, being careful not to over torque them.
Usually carb studs are 5/16" and the standard torque for a Grade 5 5/16" nut is 18lb-ft. I'd say don't go any higher than that.
bkhallpass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bkhallpass Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2006 at 10:46am
Welcome Scott,
I'd say about a half grunt should do it BKH
Livin' the Dream
Post Options Post Options   Thanks (0) Thanks(0)   Quote jagnweiner Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2006 at 11:46am
Thanks, guys. I guess that's about what I figured.
Scott Johnson
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2006 at 12:05pm
Yep, not too tight. Over tightening can warp the carb base plate and lead to vacuum leaks, etc. Just snug her down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jagnweiner Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2006 at 12:24pm
Yeah, I think I may have a vacuum leak already from running it with the missing nut for so long. At the end of the season I will probably take the carb off, check for flatness and reinstall with a new gasket. For now I'll make do.
It has problems on take off. If you "floor it," the engine just dies. If you ease into it, it does fine. I also experienced some sluggishness at full throttle. I was pulling a barefooter for the first time a few weeks ago, so I was pretty much at full throttle. Ran great for a few runs, then started losing power at full throttle. I'm also changing the fuel filter, which hasn't been hanged since I bought it.
Thanks for all the help. Like I said, you guys seem to have the best thing going.
Scott Johnson
Post Options Post Options   Thanks (0) Thanks(0)   Quote AWhite70 Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2006 at 2:01pm
The symptoms you describe could also be a bad accelerator pump or the linkage on the accelerator pump needs to be adjusted.
When I rebuilt my carb there was a dead spot on the throttle right when you'd take off. I found the accelerator pump had too much slop in the linkage. I reduced the clearance and then the hole shot was instantaneous.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jagnweiner Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2006 at 2:53pm
I'll check that out. Thanks.
Scott Johnson
