Pylon, Prop |
H2O ![]() Newbie ![]() Joined: January-29-2011 Status: Offline Points: 5 |
![]() ![]() ![]() ![]() ![]() Posted: March-18-2011 at 7:36pm |
Standard height pylon($150) and OJ 14x16 three blade($125) for sale. Original on 96 Ski. Excellent.
tkenny ![]() Newbie ![]() Joined: February-26-2011 Location: Greenville Status: Offline Points: 27 |
do you have the base plate for the pylon as well?
There is no removeable baseplate. The pylon is secured by three U-bolts.
petermuhic ![]() Groupie ![]() ![]() Joined: July-13-2010 Location: Toronto Ontario Status: Offline Points: 50 |
is the three blade prop an Rh or LH direction?
And what is the shaft size? 14 would be the diameter and 16 the pitch? thank you |
RH rotation, 1 inch diameter, 14 diameter, 16 pitch. Factory prop on mid-ninetys direct drive Nautique.
DEF187 ![]() Groupie ![]() ![]() Joined: August-04-2009 Location: Janesville WI Status: Offline Points: 54 |
Prop still for sale?
lank ![]() Newbie ![]() Joined: August-15-2010 Location: Indiana Status: Offline Points: 19 |
Hi, A few questions on the pylon: What is the overall length? From what model did it come? Can you post a picture?
Thanks, Tim |
mdvalant ![]() Grand Poobah ![]() ![]() Joined: May-06-2009 Location: Bellevue, IA Status: Offline Points: 2059 |
Can you guys not read?
It is a stock pylon and prop from the 1996 correct craft ski nautique. |
Hawktique ![]() Senior Member ![]() ![]() Joined: June-27-2009 Location: Iowa Status: Offline Points: 456 |
"A Veteran is someone who at one point in his life, wrote a blank check made payable to: 'The United States of America,' for an amount of 'up to, and including his life." Semper Fi
