  New Posts New Posts RSS Feed - help fiberglass mains
lakedog55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lakedog55 Quote  Post ReplyReply Direct Link To This Post Topic: help fiberglass mains
    Posted: April-06-2011 at 1:04pm
Hi,
I have almost finished with secondary's Looks ok, but I would like the mains to be perfect, The main question is Is it better to go ahead and put all the wood in before I start wrapping the mains, Like the bulkheads and the standoffs for the motor cradle and the floor support for the rear deck. Or should I wrap the bottoms or work around the whole stinger. I am clueless right now Picture of the ribs and secondary some small bubbling, but after reading one other post I am doing much better. If anyone would like to give me a call I would be more than happy to listen 352-361-8068
Thanks Mike
Lakedog55
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2011 at 3:44pm
Mike,
I feel now's the time to get all your wood in place so then everything is glassed in as one "unit".
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2011 at 4:19pm
With structural wood stringers like you have gone with, what Pete suggests will work fine..
if you were trying to accomplish structure with glass I would tell you long uninterupted lengths of glass should first be put down the length of the stringers before adding the bulk heads.
So = I am not really adding to this thread.. just making sure anyone who reads it later understands the difference..
Post Options Post Options   Thanks (0) Thanks(0)   Quote lakedog55 Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2011 at 4:55pm
Thanks,
I will most likely put the wood in first, another question . When then floor goes in I am concerened with the area where the floor is so close to the hull on the front two sides , beside the driver s feet and the side of the passenger seat. When beginning on the mains I was going to run a 8" tape and leave most of it on the hull and wrap fro their up and then come back and change my overlap but would like suggestions.
Lakedog55
