  New Posts New Posts RSS Feed - Starter hanging
Starter hanging
martini View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote martini Quote  Post ReplyReply Direct Link To This Post Topic: Starter hanging
    Posted: May-25-2006 at 10:36am
A brief history. 83 Ski Nautique with 351PCM. New starter, new battery, new battery cables(including the cable to the starter), new ignition switch, wired correctly.
I am going through several starter solenoids due to an intermittent problem where the solenoid hangs, causing the starter to continually crank the engine until the battery is disconnected from the electrical circuit. I am getting 14.5 volts from the alternator and 14.2volts at the battery. All electrical contections have been cleaned.
The problem occurs after running the engine(ie, normal use when going to the lake) and stopping for awhile(last night, it sat for about 30minutes after our sets). I hit the starter and the problem occurs again. Disconnected the battery and tapped the solenoid, which released the starter, was able to restart after that.
Does anyone have any suggestions as to what might cause this problem? Could it be a wire that might have faulty insulation? Exposed when things get warm from running the engine. A bad ground? All other engine accessories work flawlessly. Could a worn ring gear on the flywheel cause the hanging/constant start problem?
This is driving me crazy! On previous solenoids I can see what appears to be a spot(similar to what a weld would like on sheet metal from the opposite side of the weld)on the back plate. Too much current? Any suggestions welcome, testing procedures, anything!
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2006 at 12:16pm
Stop using marine Deep Cycle battery, its for fish motors. Too much internal resistance results in low voltage at rated amps, thus sloppy engagement of the contacts, arcing them together.
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote martini Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2006 at 12:46pm
Don't have a deep cycle, it is a marine starting battery. What next?
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2006 at 1:56pm
Go to radio shack and get a relay which you can hook to the ignition wire that will send exactly 12 volts to the starter.
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2006 at 2:22pm
what's the CCA rating of your battery? and what gauge cables do you have running from the battery to the solenoid, and the soleniod to the starter.
You need atleast 550 or is it 650 CCA's for the battery and if your using 2 gauge or smaller cables replace with a larger CCA rated battery and 0 or 0/2 battery cables. Once the solenoid get's arched once it's going to cause you problems from there on. Seems odd that you have been able to use the solenoid after it has arched.
Post Options Post Options   Thanks (0) Thanks(0)   Quote martini Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2006 at 3:44pm
750 CCA on the battery and the cables are 2 gauge, both + and - and starting. I would agree with the oddity of it getting stuck and then being able to reuse. It will eventually fail completely I am sure. The previous ones did. So, I need to step up the battery cable size and get a higher CCA battery or one or the other?
nautique1980 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nautique1980 Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2006 at 5:42pm
I have this same problem. I put three solenoids on last summer and this year it did the same thing.I have know idea. Ive put new cables and a new battery (650 CCA) in and it still does this every now and then.
Martinique87 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Martinique87 Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2006 at 9:02pm
I know you mentioned you have a new starter, did you add it or did the previous owner?
I had this prpoblem as well. After my third solenoid locked up the starter would not no longer disengage completly from the flywheel. I assumed the solenoid was messing up my starter, but turned out to be the other way around.
When I brough my starter in to replace it Woody at southeast correctcraft said that it was not a true marine starter, even though it was rebuilt and sold as "marine" by a local company. Once I replaced the starter and installed my fourth solenoid (marine) the probelm went away.
Can't explain exactly what had been going on but glad its fixed. This electrical stuff is still mysterious fo rme. Jeff Kostis....where are you man,this is your specailty!
JEFF KOSTIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JEFF KOSTIS Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2006 at 10:34pm
    Several things to check, first, are you sure the starter is not just staying engaged to the flywheel and spinning?? If you shut the key off when it acts up, does it kill the engine, or does it keep on cranking asuming the solenoid is bridged. Also, be sure your new solenoid is a true starter solenoid and not a continuous duty coil stle solenoid as the look identical. Starter solenoids coils draw about 5-7 amps roughly on those styles which are designed to be engaged only for a few minutes before the coil burns out. This causes a harder "throw" and pressure to the contacts making able to handle more current and allowing low voltage engagement with a weak battery.. A continuous duty solenoid has a higher resistance coil which draws only 1-2 amps or so, alowing it to be on continuously without burning up the coil, but has less "throw" and pressure making its current rating about half. Continuous solenoids are not meant for super high current starting. You cant tell the two apart by looking at them.
    Enough on solenoids, you dont have to change the batt cables to larger ones as this will make no difference. In fact, larger cables will cause the starter to draw more current than smaller cables. Remember, the starter is a DC motor, not a AC motor.
     Good luck!!!
                                  Jeff....
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2006 at 8:55am
The starter will not draw any more current than what the field coils are designed to draw. By using undersizes cables you prevent the field coild from drawing the amount of current it needs to operate properly. The 750CCA battery is fine put I do not agree with the 2 gauge cables they need to be 0/2 marine cables. I would also bet that your cables are pretty hot after you crank the engine which is another sign of undersize cables.
Post Options Post Options   Thanks (0) Thanks(0)   Quote martini Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2006 at 9:55am
m87, brand new(not rebuilt, not reman) starter I installed.
JK, It will continue to turn the starter over with key off.
79N,The cables are in fact marine grade but are 2 gauge as I indcated before. I will check and see how hot the cables get when cranking. Cable size and length may be the issue here. I read that 2 gauge is good for 3.6' to 6' lengths(correct me if I'm wrong). I believe I am definitely over 6' with my set up. So, I will check cables for temperature and most likely break down and get bigger cables. The starter relay(solenoid) is in fact marine grade from my local CC dealer, so I know it is the right part. All good things to try, I'll let you all know what happens.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2006 at 10:08am
Like TimD sez, add a relay or trace the harness and dash for a voltage drop when under load. Inadequate actuating voltage is at the solenoid/relay, you have all the symtoms. The starter relay wires are marginally sized when everything is new and perfect, it only takes a few ohms to limit the current to the relay and decrease its holding force, arcing the contacts together. The voltage drop won't be apparent until you pull enough amps so don't say "I got 12 volts" and stop looking.
I concur with 79, bigger cables can reduce amps by delivering more power (VA) to the starter....follow me a moment... A DC starter uses less current the faster it spins, so a few volts lost to cables causes low armature rpms and thus more current through the starter, more loss though the cables, less voltage at the starter, less rpms, more the motor looks like a dead short whe it drags.. etc. Then thing heat up quick.
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote martini Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2006 at 10:48am
GS, when you say "indadequate actuating voltage" are you referring to the start(yellow with red stripe) wire that runs from the dash(ignition switch), through the trasmission lock out, up to the starter relay?
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2006 at 11:09am
Correct. your color may vary. Monitor the voltage there when starting then work backwards through the dash, keyswitch then back to the engine and harness and see where the voltage goes higher, it will help isolate where the trouble likely is.
One related test is to unplug the choke for a few starts, the choke has heavy wire near it but it often necks down quick to small gauge wire to the dash and can be responsible for pulling down the whole dash voltage when connections get marginal. Temporarily removing that load can make things behave when things are on the edge due to the less total draw.
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote martini Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2006 at 11:15am
Fun stuff. Looks like I've got some work to do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2006 at 1:49pm
Have you made sure the cables are adjusted right so that when the throttle is in neutral so is the safty switch?
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote martini Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2006 at 2:08pm
TD, are you saying that if the neutral safety switch is partially engaged, that it may cause a momentary drop in voltage? Meaning it isn't getting full contact, but partial contact because of cable mis-adjustment? I suppose I will be able to check for that when I start chasing/testing the wire from the starter relay.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2006 at 2:38pm
If the safety switch is not in the right position, it kills the ignition.
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote martini Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2006 at 3:03pm
yes, I am aware of it's function and I will check cable adjustment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JEFF KOSTIS Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2006 at 10:10pm
    Guys, the neutral safety switch only breaks the circuit to the crank the engine by not allowing 12V to the solenoid. It has nothing to do with ignition or his starter problem.
     Second of all, back to the motor discussion. There is still a confusion between AC and DC motors. Without getting into any lengthy discussions think of this. If a DC motor draws less current the higher the voltage, then take a big batt charger wih a current meter and hook it direct to a starter motor and note the current from switching the charger from 6 to 12 volts and tell me what happens to the current.
     Contacts and solenoids and swithches will handle less current the higher the voltage. A high voltage causes the contacts to "flash" more compares to a lower voltage. Ever see a switch rated at 5 amps at 240vac as well as 10 amps at 120vac???
     As far as your problem martini, I would first start of by buying a cheap 12v light bulb with a socket and pigtail and wire it to the "start" terminal of the ignition key and ground. Then let it hang and watch the bulb when cranking. It should only light when cranking. When the starter acts up, watch the light and see if its out, on, or dim. This will tell you if the solenoid is welded together, or if you might have some other backfeeding issue.
    Good luck!! Sorry so long!!
                                   Jeff...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2006 at 10:39pm
Jeff don't try and apply ohms law to this application and the bullsh*t way of testing if the solenoid is still engaged or not. The starter is still spinnig so it has to have current going to it and you don't need a damn light to tell that it's still has current going to it. Leave the classroom BS in the classroom all you do is confuse the issue and never solve it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JEFF KOSTIS Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2006 at 11:04pm
    79N, you seem to be very hostile in your unwelcomed comments. I feel this is not a positive example to this wonderful site.
    Anyway, to respond to your comment, the purpose of the bulb test is to confirm if the solenoid is actually welding itself together and staying stuck or if the solenoid is still sometimes seeing a voltage to the coil from some other means (backfeeding) and keeping it engaged. You cant sit at the computer and say for sure where the problem is without being there. Besides, its strange all parts are new, and still trouble.
                                 Jeff...
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: May-27-2006 at 7:03am
No Jeff, re-read what was written.
A DC motor draws less current the faster it spins. That is why the components burn out when the starter drags due to improper wires, underrated battery, etc.
Anything that interferes with supplying rated voltage at rated current will produce inadequate rpms and draw more current because the motor behaves more like a short. High current and low voltage due to resistive losses (a function of the square of the current) produces little work and burns up components. A happy starter sees rated voltage at rated current, producing more efficient power for a longer duty cycle.
Your battery charger scenario is faulty and falls apart when once one adds engine load to the starter.
Put a similar energy capacity 6v battery on your boat and a clamp on ammeter, and if the solenoid has enough holding force at that voltage you'll find the starting system puls more amps at 6V than it would at 12 due to the low RPM of the armature.
I am typically on the mark about such things being a schooled electrical engineer for 17 years.
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote JEFF KOSTIS Quote  Post ReplyReply Direct Link To This Post Posted: May-27-2006 at 10:26pm
    Gottaski, DC motors run on the same principal with a execption of permanent magnets or a induced magetic field (Im sure theres a techno name for that). Think of a cordless single speed Makita drill (DC motor) with the circuit breaker in it. This would mean a weak battery would cause the breaker to trip instantly if you kept the drill from turning, and not trip as fast if it were fully charged??
    A DC motor draws the most current when it is not turning. If you kept a 12v motor from turning, it will draw "X" amps at 12 volts. If you reduce the voltage to 6 volts it will draw "Y" amps (less than "X"). Since the motor isnt turning, the voltage and current (watts) gets dumped as heat in the motor since not being tranferred. I think the confusion is the fact that a DC motor will draw more current as it is slowed down by increasing resistance in the load assuming the voltage stays constant.
    Another example is a electric DC vehicle winch. Most being the same as a 12v starter motor, if it draws less current with a higher voltage, then they should be able to run it on 24v, or use a 6v motor and run it at 12v. If the current were to be less, that would mean the motor would run OK??
    Along with this interesting dicussion, and Jbear reading into it, I want to make sure the original person (martini) to post this gets squared away with their boat.
                                Jeff....
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2006 at 7:24am
Yes, Correct. I thought I said that first.
Correct, If in both conditions the motors were stalled, yes. But once the motors are turning that model no longer applies.
Yes, under some conditions a makita drill with a weakened battery can generate more destructive internal heat when stalled if you kept bearing down on the work with the same intensity one did when the battery was fresh. Most people let up as the battery weakens. Typically the breakers are sized to only trip when the motor is stalled AND the battery is fresh, which is a different condition.
Practically the same reason brushed AC motors burn up when someone uses a too-long, small guage extension cord, reduced voltage at the tool but plenty of amps available.
Trying to do the the same work with less voltage requires more current, results in more heat, and it "lets the smoke out" of the tool.
For a a 6V and 12V starter to do the same work (nobody changed the engine design) a 6V starter will pull over twice the amps. Thats why 6V starter systems need honkin big wires. I say over because the resistive losses are 4-times higher than at 12 volts.
And thats why 24V starter systems are more efficient and we'll soon see 48V bus systems in autos.
If you had a voltmeter across a starter motor and applied 12 volts to it, What voltage would it ready initially? very close to 0 volts, because it behaves like a short. The faster it spins, the more internal voltage it has, and the less delta-voltage it has with its source, thus limiting the current.
Yes, confusion is. Motor resistance decreases with less RPMS, not increases.
No, it wouldn't run OK for long.   Internally the different starter's brush area, windings, winding wire guage and other factors are sized appropiately for a given voltage, expected rpm, load and duty cycle.
IF the same starter was on an engine, and your charger supplies the abundant current necessry to turn an engine, yes initial current would be higher at 12 volts but just for a moment till the rpms came up, the short duty cycle in that condition causes no damage. Higher current would be demonstated by the 6V application for a longer period than the spinning 12V condition because its labored, humming low rpm condition pulls more amps for a longer duty cycle, thus burning up armatures, brushes, fields and wires.
You are right on about low holding force of the solenoid, from a low voltage condition, being responsible for the contacts welding closed. We just go to help martini find the root cause.
Are we now saying the same thing but still trying to enlighten each other?
River Rat to Mole
jbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2006 at 12:35pm
Wow. I just love it when you guys talk like this, don't understand a bit of it but know I love it! Excuse me while I head for the Beam.
All I know is that if I ever need to rewire the '80, the cost of an airline ticket for JEFF KOSTIS or Gotta or J_I_H will be well worth it.
BTW; Where are you J_I_H? You usually weight in on these posts.
john
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2006 at 9:21am
Hi all. I just got back from an extended work trip - "yuck". It took two cups of coffee to completely enjoy this thread on this rainy Memorial Day morning. Now that theory has been covered let me make a suggestion that will blow everyone's mind. My advice is to check the ignition timing.
Here's my thinking: My experience with sticking auotmotive selinoid contacts is that they fail due to overheat from extended current draw - not from arcing. Also the overheat may cause the selinoid spring to weaken.
So, put on a fresh starter and selinoid and check your engine timing and ingnition system to ensure your engine starts quickly.
If you have your starter rebulit make sure they replace the complete selinoid. A weak return spring is undetectable.
Fix a selinoid? I can't even spell selinoid!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2006 at 9:26am
on a ford starter they do not have the solenoid attached to the starter like GM starter do.
It's been my experince that when this happens it's do to low current draw, from a bad starter, solenoid, weak battery, undersized cables or corrioded cables or a compination of these.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2006 at 9:41am
79. If he had high resistance in the circuit or a weak battery wouldn't that cause the starter to turn over slowly making the problem recognizable?
By the comments I assume there are no clues as to the source of the problem.
I think my selinoid is built onto or inside my starter. I have never had a Ford starter apart but don't they work the same as a GM starter? Does a Ford starter/selinoid have a return spring somewhere in it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2006 at 4:53pm
There is a big difference on ford's design and GM's design mainly that fords solenoid's/relay are seperate from the motor and GM's are mounted on the motor and are intergrated into the housing. Personally I feel that the 6'+ long 2 ga cable is the main issue. A 2 ga cable would be fine if it was only 2'-4' and not 6'-8'. It's like hooking up a large air compressure with a 50' extension cord and all you end up doing is blowing the fuse.
You have to have enough current to over come the electromotive force before the motor will spin, SO high resistance low voltage closes the contacts on the solenoid but doesn't energize the field coils in the motor enough and arcs the contacts together or keeps them open because there is not a change in the current inside of the solenoid to de-energize it and release the contacts.
It takes a lot more current to get the motor to spin than it does to keep it spinning.
