converting to electronic ignition |
yanivsai
Newbie Joined: December-04-2005 Location: Israel Status: Offline Points: 39 |
Posted: May-30-2006 at 7:06am |
hello boys
i have 1982 sn,how can i know what dist' i have,left or right ? |
RH if it's a stock motor and has been replace with a conventional model, look for a tag or number stamped into the house below the cab on the outside, and if you got the cash replace the whole dist with a mallory YLM-554-CV or YLU-554-CV. Mallory has just started to renumber there marine line of parts but summit racing still has the older numbers
yanivsai
thanks chris
i read the mallory ylm\ylu specification and it looks good,but both of them are Counterclockwise so whats the difference ? are they better then electronic ? if my ang is Rh so the dist' is Counterclockwise ? thanks yaniv |
it doesn't matter on the rotation a std or rev rotation engine both spin CCW. and they are both electronic, the YLM is cheaper and uses a magnetic pick-up and the YLU uses an optical pick-up and both will be much more reliable than a conversion kit.
