Deposit on another 86 |
Post Reply | Page <1234> |
wakeboardin2k4
Platinum Member Joined: December-14-2006 Location: Hopatcong, NJ Status: Offline Points: 1117 |
So if anyone's interested in the boat I am taking offers. I'm on vacation down in south Carolina and there is a guy making me an offer. If anyone's interested, nows your chance.
Tighten the manifolds bolts back there and go wakeboarding already, you wont hear or smell it from the end of the rope.
Bri892001
Yup, the PO of my boat had done that. I think he was trying to deal with a carb that was leaking fuel through the booster and therefore running too rich. I replaced with the normal plugs and then had the carb rebuilt. Sounds like a different problem here though. |
wakeboardin2k4
HW- All new champion 401s in there. Had the NGK equivalent in there before and was doing the same thing. Tim- I'll get my PB blaster ready and swap the gasket. |
Eric, if youre getting some ticking and a hot spot on the thermometer, then I would bet you have a small exhaust leak. Get a new gasket on there and then recheck it.
Boat looks great, by the way! |
Check which spark plugs are in it, all of them. Some new owners on here have reported buying a boat with progressively hotter plugs toward the rear to burn the richer fuel mixture, seems hokey to me but something worth quicking checking.
Nautique2001
Eric, I have the gray gel coat repair, not blue.
That's a great top end. I get close to 46 MPH (GPS) with about 100 hours on the motor and the ACME 540. You'll have to give me some sanding guidance for my transom. Ken |
wakeboardin2k4
Update, with a few questions
Done wetsanding, boat came out great. I took the boat out yesterday and it ran exactly what it should, a little faster than I expected. With just me in the boat and a 1/4 tank of fuel I bounced it to 46.8 on iPhone gps speedometer. Consistently ran 46. Here's what I have for questions. I have a weird rubber burning smell/puff of smoke when I open up the motorbox after going around the lake at any speed above 1500 Rpms. It has nothing to do with the belts, It appears to be predominantly coming from cylinder 8 area. I brough my infared temp gun out with me yesterday and the topside of the "header" part of the manifold is getting to about 330+ - a few degrees. When I say top side of the "header", I'm shooting the laser temp gun down between the gap between the valve cover and the manifold at the part of the manifold before any water gets to it. To me 330 doesn't seem like that much, but it seems to be 80-100 degrees hotter than any other part of the manifold at any other cylinder. Is 330 enough to be melting the exhaust manifold gasket? I do hear a slight tick on that side of the motor that I dint hear on the other side of the motor. But it's not loud enough that I'm definitively thinking manifold gasket. Thanks guys Eric |
C-Bass
Awesome work. Looks great.
Donald80SN
Wow
Great effort. Looks great. Donald |
wakeboardin2k4
Thanks Ken, I hope youre right! You didn't miss the post about running the boat on the lake. This week will be the lake test. Engine fires right up on the hose but I still need to see how the trans does.
I remember us talking about you purchasing some gelcoat for your 86 but I cant remember did you purchase the blue or the grey gel? |
Nautique2001
By the way, I might have missed the post, but did you run your boat around the lake? Any concerns with engine/transmission performance? Ken
Nautique2001
Amazing work, Eric. All that sanding probably increased the value $2,000. Very nice shine going on there. I think you're going to make some money off this boat, my friend. Can't wait to see the final product. Ken
wakeboardin2k4
In my dreams Chris!
Brian- lower the nose of the trailer to the ground. Block the rear at that point with the as$ as high as possible. Then bring the nose of the trailer up as high as possible. Block the nose and bring the trailer back down. Inch it out till you hit a crossbeam then lift the nose with a bottle jack and re block appropriately till it's out. Pain in the butt but as you saw I needed a trailer to pick up that barracuda in ct |
Bri892001
Very nice! BTW, how did you get it off of the trailer and onto the blocks like that?
storm34
Looks awesome Eric, can't wait to see it at Green Lake in a few weeks
wakeboardin2k4
Thanks Pete, Its a lot less work than repainting or regeling!
Eric,
Some don't appreciate the work it takes to bring old glass back to life but most here do. Keep up the good work! |
wakeboardin2k4
Heres an update. Finished one side. Haven't glossed and waxed it yet but these pictures are with the finess-it. I got the whole other side to do before a final waxing of the boat.
Here are a few pictures of the side thats done and a few of the side that is being done next just for a good comparison of what it started as and where its at now. The lighting sucks because the boats in the shade and doesn't do justice to how bad the boat looked before or how nice it looks now. Im looking forward to seeing it on the water soon! Tim- I know when i stopped by your house after purchasing the boat we talked about the deck being very chalky and whether it would require wetsanding or not. Super duty compound has so far done a nice job of bringing it back. It wont look perfect or like it did in 86 or like it would if i sanded it but darn good for 25 years later. |
wakeboardin2k4
I've only been doing the bottom blue section with wetsanding. Which I've been doing by hand. For this boat I'll be sticking with by hand. The next project I'll invest in one of those water enducing DA sanders to see how it works. The plan for the stripe and upper blue is just a series of compounds and wax. They're pretty good. I'll leave the decals on and buff over them slowly. Hopefully they hold together. I appreciate the compliments guys. Should be done sanding by end of next week with an after work session each day. |
Jllogan
I used this bad boy with a 500 grit foam pad for the wet sanding. http://www.festoolusa.com/products/rotex-sanders/ro-150-feq-rotex-sander-571810.html
Also I took all my decals off becuase I wanted to replace them and thought this would be a good opportunity to do the best job by them not being in the way |
C-Bass
Eric...is that by hand or with a DA sander? Looks great so far! Love the reverse gels, especially that blue. Probably my favorite 2001 color combo.
One other question...how do you manage to go around the decals, or do you just go right over them with the sanding? |
Jllogan
AHH SPAM!! Eric,
Your pics are like deja vu, That is what I have been doing the last two weeks. I wet sanded for days and then started using the yachtbrite rubbing compound it worked really well. The next step is their gelcoat polish. Its not supposed to be a wax but a polish sealer. Do you think it would be beneficial or harmful to wax over that polish? Here is a before and after the compound, it worked really well. |
wakeboardin2k4
Get out of my thread you dirty spam diarrhea
nike air max 2011
Newbie Joined: June-09-2011 Status: Offline Points: 2 |
You can find cheap and discount nike air max 2011, nike shox torch, air jordan 2010, jordan retro shoes, new jordan shoes 2010 here.You are welcomed to visit :http://www.nikejordanlink.com.
nike air max 2011
nike air max 2011 is the most successful in recent years, a shoe. Not only because of the quality and 100% price guarantee and also we supply all nike shox welcomed by many customers from around the world, they often found that the length of the right to run. air jordan 2010 as the world's most popular shoes, its unique appearance, quiet feel, can show you better have a good taste, at the same time, nike shox torch can slso support cutting breathable, flexible design, open cage net cage covered by combination of insole molds to your feet in the quiet and the shape of the foot support. new jordan shoes 2010, jordan retro shoescan increase the length of the quiet end of the degree. The new damping system, combined with a suitable natural gait movement works, all are designed to bring you the most tranquil experience.Welcome to visit us:http://www.nikejordanlink.com .
skicat2001
Platinum Member Joined: November-24-2008 Location: Ft. Worth TX Status: Offline Points: 1950 |
Looking good there. Looks like you are enjoying the new quite well..
1985 CC 2001-SOLD
Lee Michael Johnson |
wakeboardin2k4
Here are some pictures from last night and tonights work.
It was slow going at first deciding which grit to go down to. Eventually I decided 400 was good. 400,600,1000,1500 grit paper. These pictures are with super duty compound and a quick coat of wax. I still have to do the finishing steps but I want to do all the finesse-it and wax at one time since ill be slinging compound and sky blue gelcoat liquid for the next week after work. |
wakeboardin2k4
Cool, thanks Tim. 320 got it smooth and got rid of the oxidation.
Eric, go as far as you need to smooth the area of the crack- to the point you cant feel it with your fingernail anymore. Hopefully by then youre throught the oxidation as well. Smoothing it out and restoring the color is as good as you can do- from more than a few feet away it will be way tougher to see them.
I think I went down to 320 on the deck of my '90. |
