#2 trailer work |
Post Reply | Page <1 121314 |
storm34
Monty, I bought my #2 from Al here on the site. When I picked it up he had re wired the whole thing and used silicone to keep the wires in the frame of the trailer. I have to say it's been pretty nice not to have to worry about them and it's all sealed up so no water can get to the connections. Pretty slick if you ask me.
jbear
sticky-backs......OMG...you know what we used to call guys that used those Gary! On the other hand..never seen them used on a trailer before... john |
MartyMabe
Grand Poobah Joined: February-21-2006 Location: High Point,NC Status: Offline Points: 3980 |
13" wheels and tires on the #2 !
Keeganino
That looks much better on the clearance.
1973 Skier |
storm34
Beautiful!!
How is the loading/unloading going? |
DrCC
Grand Poobah Joined: April-12-2004 Location: at home Status: Offline Points: 2868 |
Chris, In ref. to yours (top, this page)
The wiring idea wasn't to seal, but to make the wires not visible. So, while Pete hates silicone, I hate hanging or visible wires. Nice #2 Marty. |
MartyMabe
Chris--Still having issues Driving the boat on the trailer. It keeps coming of the left side bunk, even though I'm trying to scoot over to the middle. Guess maybe that's why they're called "Float-On" trailers.
Just used to 30 years of driving up on that tandem trailer, putting the hook on it and driving out-All in less than 1 minute!! |
Marty,nothing some goofy guides wouldn't stop
MartyMabe
Weight of the #2 CC Trailer is ???
According to the reference section, 450 lbs.
MartyMabe
Thanks Tim ! I looked - must have not overlooked it.
The reason was Saturday-- I winterized the 66. But first took it down to our yard waste facility about 1/2 mile from me-- weighed the truck and boat 6100 lbs total 3900 lbs truck 2200 lbs left then for boat and trailer 1600 lbs boat 450 lbs trailer Got a full tank of fuel- 18 gallons 125 lbs of fuel ? Battery in boat So guess this is about right. Funny thing though about this We weighed the boat and tandem trailer back in the late 70's after we had the boat-- and it weighed 2200 lbs ! |
Marty, that does sound about right. Im not sure I trust the weights listed in the brochures 100%, but the '79 brochure says 450 lbs... the 60's version might be a few lbs lighter since it should have smaller wheels and tires.
MartyMabe
Bump for Newbies
MartyMabe
Another Bump for newbies
This thread seems to be the best repository for #2 trailer info, so I will add a few things. As I mentioned a few pages ago, I replaced the running gear (axles/springs/hubs and all associated hardware) on 2 different '71 #2's a few years ago. I just recently did the same thing on a '70 #2 and rediscovered a few lessons that are probably worth recounting.
First, some measurements from the original components: Axle length (hub face to hub face) = ~66-3/4" Axle length (overall) = ~72" overall Spring seat (center to center) dimension = ~55-1/16" Springs: 30" long, 6-leaf Spring u-bolts: 1/2", 1-7/8" (inside width) x 3-1/2" long Shackles: 4-1/4" x 1-1/4", 1/4" thick, 3" hole center to hole center Bushings: 1/2" ID, hat style (6 per side) Shackle bolts: 1/2" x 3.5" long Frame width at the fenders = ~59" Fender width = 7-5/8" Hubs = 4 lug (bolts) Spindles = 1" Bearings = L44643 (inner and outer) Aside from the hubs/bearings/spindles, I can say that just about NOTHING on this trailer is "standard"! Either the trailer industry has changed a great deal in the last 40 years or CC just did things differently back then- or maybe a bit of both! A few examples: - Axles and springs attach differently on these trailers compared to modern convention. U-bolts go in opposite directions, spring plates were welded to the axle instead of seats, etc. A picture is worth a thousand words: Original (borrowed from Gary): Standard convention: That means that almost no one makes u-bolts that match the originals. I did find some that *might* work from Loadrite. As mentioned earlier in this thread, the 30" double eye springs are also a little bit oddball due to their length. As Marty found, the ones from Surplus Unlimited appear to be about as close to a stock replacement as youre going to get. They have 5 leafs, the proper load capacity (1250 lbs) and also (which you cannot tell from the website) come with 1/2" bushings installed. If youre wanting to upgrade shackles, bolts and bushings while trying to keep the rest of other components in place, the problem is that no one uses (or stocks) all of the 1/2 hardware you will need. Standard trailer stuff is all 9/16" now. As mentioned earlier, the hat bushings from eastern marine are a close match to the originals- though the OD of the bushing was a bit large and had to be filed down to fit the ID of my rear hangers. For the bolts, I would recommend picking something up from the hardware store or McMaster- no one I found sold the fluted/splined bolts purposely suited for this that are 1/2" diameter x 3.5" long. The other option if you need to upgrade all of the shackle hardware is to convert to 9/16", which is now the industry standard. 3.5" shackle bolts are available (usually marked for "slipper" springs... 3" is the industry standard for eye springs). Hat bushings that take up the slop are not available though- so you need to buy some large OD, 9/16" bushings and cut them down to ~3/16" wide to take up the space left on either side of the springs. It was harder than I expected to find something that matched this description at a reasonable cost, but Eastern Marine has them. As far as the axle goes, many options exist for "custom" lengths and spring seat dimensions. My local trailer shop quoted me a Dexter for ~$110. I ended up getting a full kit of a different brand, as the "stock" 67" hub face dimension seemed to work well for my #2. In replacing the axle, the "standard" u-bolt kits can be used, as shown in the picture above. Actually, the full kit included the axle with spring seats welded to our custom dimension, springs, hangers, bolts, shackles, hubs and bearings. For $240 including freight, this seemed like a very reasonable upgrade cost... and much easier than piecing together all of the hard to find pieces from multiple sources to band-aid the original set up. The only thing not included in the kit were the aforementioned bushings that needed to be cut down. The entire reason for starting this whole adventure was the bent spindle we found under our Mustang... no shop would consider replacing/repairing it. We called every place in the phone book within a reasonable drive (both CT and MA) and came up empty. I need to get some "after" pics, but here is the "before", notice the positive camber: The springs that came in the kit used the standard 9/16" bushings, so that is what we installed. They are only 3-leaf springs, but the load rating matches the rest of the hardware (2k lbs) so they work just fine- and gave us quite a boost from the saggy originals. A few more tidbits: -In attempting to avoid buying a new axle, I dug out the original axle from my '78 Ski Tique... and found out it had larger spindles than the earlier #2's! Not sure if the entire axle is rated for 3500 lbs, but it required the same hubs as the #3's and #4's (1-3/8" x 1-1/16"). No 4-lug hubs are available for this spindle size that I could find, so we abandoned that idea, not wanting to buy new wheels and tires. -Original style couplers used on both #2's and #3's in the 60's and early 70's are still available from etrailer. |
storm34
Nice post, Tim!
Looking forward to see the finished product! |
The only thing I can add is in the picture of mine above you can see that the u bolts are heavier than the originals. My spring shop made them up while I waited,they already have them threaded and cut to different lenghts and bend them in a special fixture to fit your springs.
Someday I might upgrade the axle, Tim do you remember what brand it is? Since you did not want to change rims you are still using the 4 hole ones. Do the hubs still use the same size bearings? |
The only thing I can add, is the picture also doesn't show as Tim would say, your old fuggly guide on's!! |
wakeboardin2k4
Platinum Member Joined: December-14-2006 Location: Hopatcong, NJ Status: Offline Points: 1117 |
You're a nerd Tim
Sorry Eric, I know you have high standards when it comes to social media.
Better? Gary, I do notice those u-bolts are a little beefier than the originals now that you mention it. I should have snapped a few pictures of the Mustang #2 before we dissected it. The only other one I have on file is from one of our pending purchases... everything is a little rusty: I should have mentioned that the new axle has the same 1" spindles as the original, so it takes the same hubs and bearings as an original set up. The kit actually came with the Dexter hubs I like: etrailer A few pics I snapped this morning: Fixed camber: New fender clearance: Proving that the 3-leaf springs work just fine: A close up of the shackles and bushings. The 3/16" wide spacers on either side of the springs are the cut down bushings I referenced in my other post- they take the place of the original hat bushings (all new springs Ive seen have their bushings installed flush): Overall shot: Sits much better than before: For reference, the the wheels are 12" and the tires are 12x5.30. 13's look like they would fit without a problem. |
wakeboardin2k4
I'd have intercourse with that sandwich it looks that good |
That does look good,however I just got home Tuesday from having a stint put in. My primary doctor talked me into going to have my heart checked I guess due to family history and age. That part was all out of pocket,cost me about 800,so in the past I was reluctant. I have felt fine,no symptoms etc but it turns out I had an artery 75% clogged. Supposed to take it real easy until Monday. Thanks for the axle info Tim. I assume that spring perch is off when you buy it o that you can weld it on where you need it?
Gary, glad you caught it early and are on the mend! Hopefully Eric heeds your advice on those bacon egg and cheeses.
On the spring seats, I was actually able to specify everything with the trailer shop up front- so the kit came in ready to go. I just called and the axle brand is Tie Down... this looks to be our axle listed at Trailer Parts Depot. I am not sure if Tie Down will always weld the spring seats to your specs prior to shipping or if that was just the way our kit was ordered (my trailer shop got the kit through a company called Franklin... which I suspect may be the same company as trailerparts.com). I think most axles come in with the spring seats still needing to be welded on- and I was glad to avoid the hassle and expense of doing that, in this case. |
cbdenco
Groupie Joined: September-14-2013 Location: Denver Status: Offline Points: 66 |
A couple of '63 reference pics. Serial No. 2-1060
Gary, Best wishes from the Brainard family. You'll be fine - You're too tough from climbing all those poles before the buckets!!! |
Thanks Pete
john b
Grand Poobah Joined: July-06-2011 Location: lake Sweeny Status: Offline Points: 3241 |
Gary, I'm so glad you caught it during a check up. I hope you are doing well. I suggest to everyone that they get check ups even if they feel fine. $800 is a small price to pay for your health and some are lucky enough to have it covered by insurance and still don't do it. 3 years ago I had a heart attack and really had no indication of a problem before hand. I had ridden a 60 mile bike ride 2 weeks before without problems. I now have two stents and the blood flows backwards through one of my primary arteries. Im now on meds for it and feel pretty good, it's still pumping like a Jabsco. Give me a call for lunch sometime, maybe a nice salad for the two of us. |
MartyMabe
Thanks Marty,today I feel as good as before I went in. I would think that stuff would be too slippery,the carpet also keeps the the boat in place
MartyMabe
Bump...... Seems like that time of year is upon us
