  New Posts New Posts RSS Feed - Marine DUI distributor
surroundsound64 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote surroundsound64 Quote  Post ReplyReply Direct Link To This Post Topic: Marine DUI distributor
    Posted: July-07-2011 at 2:10am
I'm always fighting with my ignition. I've done several different EI conversions and always gone back to points which soon give me headaches again. I'm looking at doing a HEI style conversions and wondered if any of you have any experience with the marine performance guys. Here is a link below. Also, I have a chevy, NOT a ford.
http://www.performancedistributors.com/marinedui.htm
1981 Ski Nautique
2000 SAN
Looking for a 2000-2006 SAN
84SN2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 84SN2001 Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2011 at 2:23am
switched mine to HEI! all I can say is awsome. This winter when I do my re-build to 383 Im going with a DUI, HEI system.   I was very lucky when I got my boat, it came with a PCM 350 from factory and im a chevy guy too!        let me know how it goes for you. Also remember to get the right rotation for the cam gear for the new distributer. I.E. left hand or riht hand rotation,
Waterdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2011 at 10:26am
I had a DUI in a Ski-tique (chevy) very happy with it. The distributor turns the same way std. or reverse rotation (if its gear to gear drive) Most small block chevys are gear to gear timing sets.
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 84SN2001 Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2011 at 10:38am
If its not gear to gear drive what ele'se would it be? If im correct, dont all cams have a gear for the diss, and timing?   Not unless im getting confused!! ; )     If so I LOVE learning from all you older bucks on this web site       I think that im the youngest buck on this website trying to give out info and so far it hasent even compared to all the experience, knowledge and wisdom as some of these other guys!!!    I've got lots to learn about these old boats, BUT an engine is an engine "Chevy 350"
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2011 at 10:46am
Typical Chevy RH cam drive
Typical LH drive
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote 84SN2001 Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2011 at 11:24am
Sorry if I got the drive wrong, But Im talking about the cam gear that connects to the distributer. Not the one that connects to the crank shaft. I like the pics tho, cant wait to show the pics this winter of the re-build to the 383, then come up to Lanier and have a small 2-6 boat reunion in OCT       Hope so any way. And maybee your son will take leave from Calli
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2011 at 11:25am
Try searching on here for "DUI" or "Performance Distributors". Several here have them and like them a lot- I run them in 2 of my boats.
Im not aware of any other marine rated HEI style distributors, FYI.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2011 at 11:28am
Look back at what Waterdog said and then study those pics a little longer. We agree that the front of the cam will be turning the same way as the back of it?
1988 BFN-sold
connorssons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote connorssons Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2011 at 11:33am
Just purchased one for my 383 stroker real nice people to deal with. if you get one buy the wires thay offer also, pricey 100 bones but worth the cash jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote 84SN2001 Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2011 at 11:47am
Im confused then!   why would a ford or a chevy be any diff on the way the motor turns? Dont they all turn the same way? Isnt the reason why they turn right hand "I think" is because when pulling skiers with no one elese on the boat is for ballance. Because if you had left hand with no one elese on the boat the boat would want to pull to the right. Or did I get that all backwards? Thats why you always dock on the left side of the boat because its eaiser!
Connorssons, was the 383 for your boat? if so I would love to talk to you about the conversion!
Post Options Post Options   Thanks (0) Thanks(0)   Quote connorssons Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2011 at 11:56am
Hay 84 2001! my 383 is reg rotation for my separator hooked to a mercruiser out drive. check out my rebuild posts 75 sep rebuild. if you have any questions you can call 269 506 1249 jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2011 at 12:12pm
Ford and Chevy took different approaches on how to build a reverse rotation engine. Fords use a chain and spin the cam backwards (same direction as the crank). Chevies use a gear/gear drive so the crank and cam spin in opposite directions. That means that RR Chevies have a unique timing set, but use the same distributor gear as a LH engine. Fords use generic timing sets and special RR distributor gears.
CC has generally used RH props in order to offset the weight of the driver at speed. It has nothing to do with what side of the dock they would prefer you to park on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote surroundsound64 Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2011 at 12:46pm
Thanks guys! That's exactly what I wanted to know!!!! And thanks Buffalo for the pics. That also confirmed another question I had. I have a RR engine but was pretty sure they used a gear driven cam so the distributor turns the standard clockwise way as a regular SBC.
I'll let y'all know how it turns out!
1981 Ski Nautique
2000 SAN
