  New Posts New Posts RSS Feed - Reversing Engine Rotation?
Andrew McBride View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew McBride Quote  Post ReplyReply Direct Link To This Post Topic: Reversing Engine Rotation?
    Posted: June-14-2006 at 1:49pm
I found an excellent built 351W that is for sale, but the engine is reverse rotation and I need standard. What parts will I need to swap the rotation? I have heard of guys doing this, but I am not real sure.
Thanks, Andrew
Andrew McBride
83' Ski Nautique
"Under Construction"
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2006 at 1:52pm
Reverse rotation is more technically correct for your boat, why mess with it?
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2006 at 2:08pm
Your boat came with a reverse rotaion engine from the factory.
So if it is now a standard rotation engine then the only things that will swap are the exhaust and intake manifolds, alt,and rwp.
What makes you think it's a standard rotation engine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew McBride Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2006 at 6:40pm
The prop says RH rotation. Thats why I think it is RH. I spoke with a tech from CC and he said that some were standard and some were reverse.
Andrew McBride
83' Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew McBride Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2006 at 6:42pm
No its Standard RH.
I am just asking what I need to do to reverse an engine.
Andrew McBride
83' Ski Nautique
bwooton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bwooton Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2006 at 6:46pm
Just index the velvet drive to accept a reverse rotation engine. its easy and a lot cheaper. the manual in the ref section will tell you exactly how to do it.
Thanks Bobby
there's no replacement for displacement
Post Options Post Options   Thanks (0) Thanks(0)   Quote bwooton Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2006 at 6:48pm
you can index the trans to accept a reverse rotation engine. the manual in the ref section will explain how.
Thanks Bobby
nuttyskier2002 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuttyskier2002 Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2006 at 4:36am
Andrew, if your motor turns a RH prop then is is a reverse rotating engine and not a standard. You have to remember that if you are looking at the engine from the rear, a reverse rotating engine turns clockwise. The same engine when looked at from the front turns counter-clockwise. This confuses many people. The engine you found will be a direct replacement.
Former boats:
88 Ski Centurion Tru Trac II
59 Chris Craft Capri (woody)
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2006 at 6:42am
Originally posted by Andrew McBride Andrew McBride wrote:
No its Standard RH.
Whatever, put it in backwards.
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2006 at 9:35am
It's STANDARD for the boat or a CC in that they where all reverse rotation engines from the factory until the 90's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew McBride Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2006 at 9:45am
What your saying makes perfect sense. So many of the these so-called correct craft guys tell me so many different stories about the boats in the 80's. What your saying makes sense.
Also, I have asked this question a couple times on this board and everyone gives me a different rotation.
Andrew McBride
83' Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2006 at 9:50am
Don't get hung up on LH-RH talk, your getting good info here. The engine your boat came with was "reverse rotation". Reverse in relation to a standard automotive configuration. If you have found a reverse rotation motor your in the clear. If not you would need a different prop and to index the pump. Its all good, bask in the glory of your new found engine..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew McBride Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2006 at 9:55am
No its Standard RH.
I appreciate your input. I wasn't wanting to argue on the topic, I was just looking for a answer that was right. A lot of guys just post up answers and have no clue. Your answer was short and I have no idea if you know the right info.
It is unreal how many different answers people have told me. I thought someone from correct craft would actually know his own stuff.
I would agree with you guys that RR engine is the one I need. It is now ordered.
Andrew McBride
83' Ski Nautique
rmcdonald View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmcdonald Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2006 at 10:37am
Hi Andrew
Don't want to get into a debate about which rotation is correct for you boat, but to answer you original question.
To change the rotation of that engine, you would need to buy a starter motor that runs in the oposite direction, new cam that has the lobes ground in the correct way and pretty sure you will require a some modifications.
Here is another option that you have.
Buy a prop that rotates in the new direction
Index the pump on the front of the Velvet Drive
To work in the new direction of the engine.
To index the pump for oposite direction is well documented in the Velvet drive manual in the Refernce section of this site.
Regards
Rob McDonald
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmcdonald Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2006 at 10:38am
Hi Andrew
That last post should have read
Some Modifications or a new distributer
Regards
Rob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew McBride Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2006 at 9:55am
Thanks again for everyones help. I am going to post some updates this evening on the boat.
Andrew McBride
83' Ski Nautique
stang72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stang72 Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2006 at 1:05pm
Like nuttyskier mentioned...if it spins a RH prop...it is a reverse rotation. Looking from the stern , it turns right hand and that is a RR.
So if you are getting a RR engine , you should be just fine.
stang
Face plants are not that funny when it's you face!
The Super Air
GrandSlam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GrandSlam Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2006 at 2:37pm
You guys are getting me confused (sometimes that’s not hard to do).   All right, looking at the engine from the front of the engine (belts, alternator, water pump) toward the stern of the boat, counter clockwise rotation is “left hand” rotation – am I straight here? Then looking at the stern of the boat clockwise rotation of the prop is “right handed” prop??? I do not know, I am asking. I understand that my ’89 Fish Nautique 351 has a “left hand” rotation engine, but is turning a “right handed” prop, if so what is the significance? I am going to look at this stuff tomorrow. Have a great weekend,   Jerry
Jerry Troy
USCG Master, 100GT
1989 23' Fish Nautique
1992 47' Jersey SF
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2006 at 2:48pm
I think early 90s they started using LH engines and having the trans switch the rotation to RH, thus still turning a RH prop on a standard LH engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stang72 Quote  Post ReplyReply Direct Link To This Post Posted: June-17-2006 at 12:40am
According to the shop manuals I have...rotation is determined by looking from the stern...Rev Rotation or right hand turns to the right when standing behind the boat.CCW if looking front the front(at the belts etc).
Now I don't know about the tranny switching the rotation....het now I am confused too!
stang
The Super Air
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmcdonald Quote  Post ReplyReply Direct Link To This Post Posted: June-17-2006 at 12:07pm
Hi All
This is probably going to confuse everyone but here it goes.
Engine Rotation:
This is determined by looking at the front of the Engine as in the Water pump.
Clock Wise is CW or RH
Counter Clock Wise is CCW or LH.
Borg Warner Pump Index Rotation.
This is only for older 71C gear boxes.
You index the Hydraulic pump on the Gearbox to match the rotation of the Engine.
Your pump index rotation is viewed looking at the pump.
The reason that it is determined in this way is that in some applications the gearbox is attached to the front of the engine and not the
Fly wheel
Prop Rotation is view from the Stern.
A prop that rotates Clock wise is right hand Prop.
A prop that rotates Counter Clock wise is a left hand Prop
So to put it all together.
Engine Rotation that is Clock wise ( or RH )
Requires the Gearbox pump to be indexed to RH and requires a left hand prop.
Engine Rotation that is Counter Clock Wise ( or LH )
Requires the Gearbox pump to be indexed to LH
and requires a Right hand prop.
The Borg Warner Gearbox manual in the Reference section has a chart which shows
Gearbox model numbers
Engine rotation
Gearbox pump indexing
and required prop
I hope this has made some sense.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stang72 Quote  Post ReplyReply Direct Link To This Post Posted: June-17-2006 at 10:23pm
well I have to disagree and agree(at least from the perspective of what I am reading and what my engines do)...I have two complete manufacturers shop manuals...for my 312 and the 302/351.
Both manuals state that the rotation is engine determined by looking from the back of the engine(stern) .
So...looking from the back ,a reverse rotation engine spins to the right (CW) and does use a rh prop, standard rotation engines turn left(CCW) and use a LH prop.
Hope that adds to the Making sense part
stang
The Super Air
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmcdonald Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2006 at 12:03am
Hi All
This is where the problem lies.
Whether you view the engine rotation from the front of the engine or from the rear looking at the fly wheel.
EG: A Clock Wise rotation viewed from the front of the engine is also Counter Clock wise when viewed from the Fly Wheel.
This is why the Borg Warner Gearbox manual gives you a chart and also tells you how to view engine rotation, so you can correctly index the pump on the front of gearbox pump. irespective of how the engine manufacture determines rotation.
Regards
Rob
Fook_U View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fook_U Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2006 at 11:46pm
just look at your car motor and see which way it turns. They are almost all left handed right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2006 at 6:29am
<removed mistaken comment>
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote GrandSlam Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2006 at 9:12am
I am hopelessly confused. How do you download the manuals in the reference section? Maybe a picture will help. I have been able to view/print the brochures, but have not been able to view the manuals. Thanks, Jerry
Jerry Troy
USCG Master, 100GT
1992 47' Jersey SF
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuttyskier2002 Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2006 at 11:24am
Just click on the manual and allow your computer to open it and display. Then in the upper left hand corner click on "File" then "save as" and designate a drive and folder to save it in. It's a pdf type file which stands for picture document file (I think). Hope this helps. The transmission manuals (there are two of them) will clear this all up for you and alleviate any confusion.
Former boats:
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2006 at 1:38pm
Originally posted by rmcdonald rmcdonald wrote:
Engine Rotation:
this is completely wrong and ass backwards.
long story short if you own a correct craft and it has a 1:1 transmission then you have a reverse rotation engine RH from the factory,
If it's an older model with an I/O or you have a 1.23:1 transmission then it's conventional rotation LH or automotive rotation.
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2006 at 10:14pm
Well, I have to say that rmcdonald's post is accurate in some places and not others. If you take the time to read the referenced pages of the BW installation manual he refers to it explains it pretty well.
It may sound ass backwards but read it a few times and it's the way that Borg Warner says to figure out the right way to set up the transmission. They even say that it may not agree with how the engine people talk about the direction of rotation.
It goes against the logic that the typical CC owner might have. Why's that you ask? Because CC calls our engines reverse rotation(opposite of a car engine). This is determined by looking from the rear toward the front. This gives you a right hand rotation engine. We also have a prop that is right hand turning.
Now to get to the confusing part, the BW 71 series 1:1 transmission needs to be set up for what Borg Warner calls left hand rotation for our right hand rotating engines because they look from the front towards the rear.
No matter how you look at this it's confusing. Just search through past posts and look for people who put their trans in oriented the wrong way and had a boat that moved equally well in forward, neutral or reverse. It went nowhere at all.
Now swap that pump around to what seems backwards and what happens? The boat goes the way it is supposed to. It now has forward, neutral and reverse instead of neutral only
So like rmcdonald said it's confusing but if you sit and read old posts, read the installation manual or learned it the hard way by installing a transmission with the pump oriented wrong maybe it will save you some trouble in the future.
There is a lot of misunderstanding with these transmissions, some people think you can reorient the pump and make your left hand rotation engine turn a right hand rotation prop. It won't work, once again you will have a boat that runs great in neutral so matter what you do with the shifter. It sure would be nice if you could, then we wouldn't have to buy right hand rotating engines or the parts that you need for them. Life would be a lot simpler.
I only happen to know this transmission stuff because I may have learned by screwing it up in the past and having to figure out why.
So take some time and do some reading and no matter how you figure out and understand what's right it will save you some headaches down the road sometime when you are doing transmission work or having it done.
The simplest most foolproof way is to orient the pump so the little arrow next to the word TOP is pointing the way the engine rotates.
keno
Post Options Post Options   Thanks (0) Thanks(0)   Quote stang72 Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2006 at 10:28pm
I hope Andrews question has been answered.
It certainly appears to me that if he is purchasing a reverse rotation engine , then he should not need to change anything with the tranny(considering a RH prop was on the shaft).
stang
The Super Air
