  New Posts New Posts RSS Feed - Stern/Anchor light
Stern/Anchor light
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Topic: Stern/Anchor light
    Posted: July-02-2004 at 1:42pm
I am not getting any power to the stern/anchor light at the back of my 2000 Sport Nautique. I have checked the circuit breakers under the dash. I put a multimeter on the connections for the light but am not getting any juice. Any suggestions as to where to look to find the problem in the wiring?
77stang View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 77stang Quote  Post ReplyReply Direct Link To This Post Posted: July-02-2004 at 3:14pm
check for continuity in the ground wire
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: July-02-2004 at 5:17pm
Remove the light base and check the wire connections for corrosion. Also check that the circuit breaker is not faulty (briefly jumper across the circuit breaker).
