Ski Supreme Knowledge base? |
mdvalant
Posted: August-02-2011 at 4:54pm |
My buddy that was looking at inboards picked up a 1985 Ski Supreme!
351w 240 hp just like most of us. I'm sure he is lurking around here somewhere following our threads. He is a Nautique fan...but couldn't afford one just yet. Who knows what kind of prop is great on this boat? I'm clueless. Sent an email to ACME to see what they think. Looks like a fun little boat, it had a stringer rebuild from bottom up, new floor, new carpet, wet sand and trailer had been sand blasted and painted to look new as well. Right now he is struggling with a problem like most of us have seen, after the boat gets hot it has a hard time starting. Coil, Solenoid, EI conversion, running lean, carb issues, etc etc... Trying to help him out best I can, it's also his first inboard. Taking him out on a training session this weekend! |
Most likely a Acme 541 is the way to go (LH version of the 540). Hard restart when hot... take a look down the throat of the carb after shut down and see if its dripping. I bet it is = rebuild carb.
mdvalant
Thanks Tim!
Just talked to him about that. No fuel dripping, full carb rebuild last year (that I was unaware of) We'll check out the 541! Anything else for the hot start? |
surroundsound64
Senior Member Joined: June-22-2005 Location: United States Status: Offline Points: 151 |
They are good boats. Probably my second choice behind a CC. I skied behind a 93 with a LT1. That thing would get.
You might have him take some fuel injection hose , slit it open and wrap it around the metal fuel line going to the carb. Seemed to help my vapor lock problem by giving it a little insulation. |
1981 Ski Nautique
2000 SAN Looking for a 2000-2006 SAN |
MIskier
Senior Member Joined: July-29-2011 Location: Gulfcoast Status: Offline Points: 144 |
Try AMskierboats.com Ron Tanis who worked for and owned American skier for years was a design engineer for ski supreme for a few years. He is one of the most knowledgeable guys around when it comes to ski boats in general and will be more than willing to answer any questions he can.
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3357 |
An 85 wood-based supreme? must have been an early year model i suspect?
Now prop depends what you want to do with the boat. Actually, a later vintage (87 and newer) 3 blade Federal 13x13 is not bad at all on that boat, very nice 26-36 mph ski wake and all-around prop. I tried a 4 blade acme, forget the model, but the roost was prohibitive. Very narrow propwash and high roost. I run a 4 blade OJ 4 Force 13x13, The holeshot is fabulous, and the propwash is very spread out vs the acme, the wake is very low and void of roost. Great 28-36 mph ski wake. If you don't want to eff around, just get one of these. Load the boat as light as you can, else the side spray is high and a pita when its windy at shortline. |
mdvalant
Thanks Tom, have any idea what size shaft is on them? I'm assuming 1" but you never know...
He will probably NEVER slalom ski competitively behind it, and if he does it'll be simply for a fun ski run. Comments are still appreciated. Thanks for all the help guys, keep it coming! |
storm34
Nice boat from what I have seen! I believe they have the deck that goes down to the floor like the 80's supra boats had. Makes them seem a little smaller inside but give a nice clean look.
Whats he going to do with it Mike? Please tell me he's not putting a tower on it! |
Yes, 1" shaft on those.
I only recall seeing a 1 1/8 shaft used with a 1:1 tranny on the Sangers. |
mdvalant
I'm working on getting some pics of his new ride up here soon...
mdvalant
By the way Chris, no, no tower that I know of...
mrwillya
Newbie Joined: August-04-2011 Location: Iowa Status: Offline Points: 33 |
Hi there...I'm mdvalant's buddy with the Ski Supreme, here are a few pics.....no Nautique, but a good first ski boat!
mrwillya
Yikes...will have to resize those later!
bkhallpass
At the time that boat was built, Supreme's were every bit as desirable as a CC, and honestly had a better water ski wake. There were features about the CC that were great as well. But, point is, that Supreme should serve you well. BKH
Livin' the Dream
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1772 |
nice looking boat!
Liledgy
Groupie Joined: July-13-2011 Location: Midwest Status: Offline Points: 52 |
The hull is a MC clone minus the slot.
mrwillya
Thanks, will be taking this thing to the Mississippi tomorrow. This will be my second time out, and I'm just hoping I don't have a repeat of the no starting incident!
Tonight I'm insulating the gas lines and replacing a seal in the carb that was leaking fueling into the engine compartment. So maybe the insulating will clear up the potential vapour lock. I'll be getting my official inboard boat driving lesson too! |
Don't bother with the insulation, there is no vapor lock on those boats. Its either getting gas, or it isn't.
Describe the symptom in delail... |
I have agreed with Tom and commented on it several times. Our engines run cool compared to autos. We have millions of gallons of water available to cool or engines. We are not talking about a stretched black colored limo with a 220 T stat, sitting out in the Los Vegas sun with the AC on full blast!!! DO NOT listen to an auto mechanic (sorry, they call themselves "techs" now!!!) Jeremy, What seal is leaking fuel? |
sweet77
Gold Member Joined: January-06-2011 Location: Florida Status: Offline Points: 666 |
So then how did the insulation help larry? i would guess his engine would have to create more heat than ours to cause it to vapor lock? im just trying to understand.does the Liquid fuel turn to a "VAPOR" like freon does causing the boat to run basically on fumes? |
mrwillya
I took the Supreme out and drove it for about an hour straight, we stopped and swam for about 45 minutes, hopped in the boat and it wouldn't start. We assumed I flooded it, but we checked the plugs and they were dry (and very white, lean?). We also checked the spark and were getting that (otherwise I assumed the plugs would have been wet). Gas was going into the carb fine when I pumped it.
It finally started after 30 mins of tinkering (all unsuccessful). I finally got ticked and pumped it like 5 times (in anger) and it started. I'm not sure if it was timing or the pumping that actually got her going. Drove her all the way back for 30 mins, shut it off for 20 mins and she started just fine. |
mrwillya
The "fuel bowl screw gasket" part #108-2-20 Number 2 on this exploded view: http://www.holley.com/HolleyCatalog/Catalog.asp?pageNumber=64 |
sweet77
Jeremy,
Number one, you need to learn how to post links on CCfan. It's a little different than other sites!! I went to the Holley site and could not find the part that's leaking. Considering your issues as posted, I feel you have other problems and you should consider a complete carb rebuild. If you have a gasket leaking on the fuel bowl, you have TOO much fuel and the needle/seat/float is screwed up. Please, get help!! I feel it's over your head but, listen to what the experts tell you!! BTW, you never answered my question - are you listening to auto guys?? They really have no clue of what's going on under the dog house of a marine engine. Get help some place else - it sounds like you could need it but, also help here is fantastic!!!!! |
skicat2001
Platinum Member Joined: November-24-2008 Location: Ft. Worth TX Status: Offline Points: 1950 |
That is a nice looking Ski Supreme. Hope you get that issue fixed, and welcome to CC fan.
I remeber when I went to ski school up on Possum Kingdom lake at Camp Grady Spruce, all they had where Ski Supreme's. They where lots of fun and enjoyed learining how to ski behind them. Enjoy the boat Ski Cat 2001 |
1985 CC 2001-SOLD
Lee Michael Johnson |
mrwillya
First off, I appreciate the vote of confidence. I've happen to rebuild several carbs in my lifetime. =) Second it was professionally rebuilt last year. If I was leaking fuel into the bowl, wouldn't it be flooded with too much fuel, thus wet plugs? I'm listening to the different posts that I searched for on this website. |
surroundsound64
Thanks for your assumption, I'm not an auto mechanic. To continue, do you not realize it takes very little heat to vaporize fuel? Perhaps if it was turbine fuel (also known as kerosine or diesel, for the "boat tech") there wouldn't be enough to vaporize it. Next, put a thermometer under the hood of your boat vs hood of your car. A car's engine is completely open on the bottom! Your boat is practically sealed when the hatch is down, thus the reason for a blower to clear the fuel. I will give you this, Pete, we do have access to an unlimited supply of cooling water. But riddle me this battman, exactly where does that water cool the fuel? I can't find a single heat exchanger on my boat like I can on my JT15. Then finally, have you ever noticed how the temperature of your engine increases after shut off? Especially with the hatch down, again because there is NO ventilation like on your car. It is because of this the fuel in your metal fuel line can vaporize. It takes very little heat to cause this problem. Everyone is welcome to do what they want, take my advice, or don't. Frankly I don't care, it's your boat. And Pete, you often give good advice, like your alignment video. Top notch. However, you also act like a prick a good bit of the time. Sincerely yours, the "auto mechanic". |
1981 Ski Nautique
From the "prick": I'm very happy that you found out the problem with your engine! |
Larry,
I'm sorry you feel that way about me. Yes, sometimes when needed I can be on the abrupt side. A good example would be when someone posts a dangerous situation with say using auto parts. Other times I feel it's just a communication problem. It can be real difficult to express feelings/emotions in the written word and I'm by no means an expert with it. Thankfully someone came up with the great idea with the "emocicons" and I try to use them whenever I can. |
Egad
