  New Posts New Posts RSS Feed - Decal application q's
Nevergrew View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nevergrew Quote  Post ReplyReply Direct Link To This Post Topic: Decal application q's
    Posted: August-07-2011 at 7:41pm
Hi guys,
Just need to confirm a few things before I jump in and apply the big Ski Nautique stickers.
The gelcoat has just been restored to a shine with the two last passes being a combined cutters/polisher and wax. Do I need to clean the surface back to original gel (wax/grease remover) to insure the decals stick? Or are they okay to go on top of a polished surface?
I've read that a little soap added to some water will help, how much water should I put on the surface? A light coating or a bit?
And finally, what method of applying should be used? and what tool is best to use for bubble removal?
Thanks all in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-07-2011 at 8:22pm
Justin,
My suggestion is to dewax that area where you are doing the decals. and then go over it with wax.
KRoundy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: August-07-2011 at 9:20pm
I agree. Don't put the decals on top of wax.
TX Foilhead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2011 at 12:47am
I just did mine, no wax they should go on after the the last step of polish. I would try an acetone wipe and then wash with vinegar and water . I washed withe vinegar after every change of polish, then waxed after the application. I did it dry, and will be redoing some of them wet next time. There are tons of vids about the process on YouTube. If you do them dry once they touch the boat, that's it. I was fortunate that most of the mistakes only bother me, but that's enough for me to redo them.
dwcar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwcar Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2011 at 1:22am
No wax. Mix a little soap and water in a spray bottle to apply. Use a credit card or small rubber squeegee to smooth out bubbles. Use lots the soapy water on top of the decals with your cc or squeegee
83Ski
OverMyHead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2011 at 3:28am
A sponge works Ok for water application also. kind of pat it so it is a little bubbly. A wallpaper sgueegy or similar has rounder edges than a credit card and does not catch the decal as much making it easier to push bubbles. This is what works for me. I lettered a few ambulances with some large graphics. Measure and tape the decals in place before removing the backing. When you are happy tape reference marks for the corners of the paper decal sheet. Remove the sheets, now get the surfacce wet, place the sheet properly and smooth from the center out removing all bubbles. let dry awhile 5-10 min before you remove the paper.
1987 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nevergrew Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2011 at 7:14am
Much appreciated gents, thanks !
Got it covered now
