  New Posts New Posts RSS Feed - 1997 SN Soft Floor
1997 SN Soft Floor
AussieNorts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AussieNorts Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2011 at 11:39pm
So I dug deeper this morning and there was more water down by the hull, i sucked it all out and then dug out the foam to the stringers on the sides and forward and back till I hit a cross member. There water seemed to be contained to that compartment as I dug next the the cross member and there was no water.
So I am thinking I will let this dry out and then pour the foam and patch up, you think I am doing this right guys? Sure do not want to have to go back down there to fix anything.
Steve
Correct craft.....is there any other boat?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: September-03-2011 at 11:10am
Steve, I think you're on the right track. Glad you took the advice here and dug deeper. Has any more water seeped through the foam as it sits? Is the new foam pourable I guess? If not then you could always cram pieces of those 'pool noodles' in there and fill the gap with the foam in a can.
I'd work on the hole you cut into a form it to more of an oval shape and then bevel the edges so when you lay down your new glass you have a simple shape to follow and so the repair will lay down into the removed portion like a 'plug'.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AussieNorts Quote  Post ReplyReply Direct Link To This Post Posted: September-05-2011 at 1:53am
Tim,
No more water seems ed seep from the foam, I have dug forward and aft of the hole as far as I can, seem to have hit some cross members. I noticed a little moisture the next morning, I just vac it up and then hit the area with heat gun for about ten minutes, I am going to keep the area open to air out for at least 5 days. Then I am going to pour the foam and patch, hope this is all good as I want to get the new carpet in.
KRoundy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: September-06-2011 at 12:44am
Sounds good. Keep us informed as you progress. Keep posting pictures for those of us learning as you go. :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote AussieNorts Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2011 at 7:29am
Guys,
Well I have finally had to look further under the floor as there was still some water there seeping through the foam. I have cut holes along the main stringer between it and the secondary. F}Refer to this picture of the two holes.
The next images show down under the floor at the ends where i have dug out the foam right o=up to the `crossmembers` (sorry not sure what else to call them, they seem to rum between the main and secoudary. Anyway down under there where the water has been sitting it has penetrated the glass, I have delamination on part of one cross member, the glass has has soften in areas under there. I am not sure what to do now. I hope masters with the knowledge here would like to chime in. Here are the other pics.
I hope the pics explain a little of what i am going through, not very good at the moment, I am going to seek some help, I think the repairs are now going to be major right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2011 at 10:24am
Steven - Good thing you don't have wood stringers!
You can just grind the delamination & build the glass back up to thickness.
This is an example of how a snall spot on the surface can lead to a big mess underneath.
Good luck
lewy2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2011 at 10:54am
Steve I cant see the delamination clearly in those pictures I can see what appears to be a air bubble in the original layup around what you are calling "cross members". Just grind that out and any other soft parts around it. Then re apply some more resin and matt.
You have probably dug in deeper than you wanted to already with our season approaching fast. I guess you could remove the complete floor and foam but I would be closing up (Do a tool count first ) and sending the patient to recover in a warm enviroment. Bring on summer
89 Ski
Liledgy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Liledgy Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2011 at 12:10pm
Great pics, and +1 on the wooden stringers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2011 at 8:06pm
I 2nd on Chris suggestion. Remove the delam removing minimal material in a circular pattern by taper sanding as best as you can. Tap test the area with a heavy coin or end of a folded up pocket knife to be sure you've got it all. A dull thud means you still have delam in there. layer up the repair with the smallest ply first then get bigger as you go over lapping the prior one. Doing this ensures multiple layers adhering to the hull instead of just one.
Lewy looks to me like it's the "egg" or "pimple" in the picture is his delamination.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AussieNorts Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2011 at 8:52pm
Where the `egg or pimple` as you mention is in these picture is where i noticed mooisture under the glass. I have to post another picture showing the delamination better. I hope this is all i need to do, if the water has gotten underneath the `crossmembers` where else would it have gotten into. I hope these pics help anyone with soft floor in a 93+ boat. There can be trouble under there. I will take some more pics and post tonight when i get home. Thanks again for all the input on here guys i truly appreciate it.
I have pulled my windshield apart and had it all powder coated at my work, came up great!! I am having trouble sourcing new screws for the windshield
I have taken some pics of the screw:
Does anyone here think they could help me source these screws in black, neally impossible for me to source in Australia. I hope someone can help me.
I will post tonight when home guys.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AussieNorts Quote  Post ReplyReply Direct Link To This Post Posted: September-12-2011 at 7:50am
OK So i have taken a couple more pics for you to show the delamination, what I have taken today is the other side of the cross member, in the smaller hole in the first picture i posted of the floor. This are is delaminated alot worse than in the other hole towards the stern. This area has a small hole i suppose under the cross member that i have shown by sticking my finger into.
Hope these make it clearer:
Thankyou again for all the help and comments on here you guys are great, well I hope i only still have to grind off the bad material and re lay I should use epoxy mat and resin to do this? Thanks again
Steve
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: September-12-2011 at 5:10pm
Yes on the epoxy.
Going on Mark's(Lewy) comments, I'd button it up as well. Then you can plan for next winter because a floor/stringer project sucks when every day is nicer than the last, and it's not a project that lends itself to being in a hurry.
Are the stringers sound? And if you do button it up, it'll be interesting to see if you have a list.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: September-12-2011 at 6:22pm
Maybe it is just me, but is that really delamination? Or, is that an area you cut out? I am just wondering where the material went. I see fibers lying there, but that's the way things look from a cut-gun I think. Is the area "soft" or does it just look bad. What does the tap-test tell you is going on?
You are making me weak in the knees. I sure hope that I don't have to do this to my 1993 Ski.
storm34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: September-12-2011 at 6:37pm
Kevin, I'm in the same situation as you on this topic and have been following closely. I'm sure many fins have been dropped on our floor creating soft spots in high traffic places. My plan is to do as listed above for the entire floor, then refoam and use glass, mat and Biax.
I'll wait a few years till we need to replace carpet but would like to weigh the boat in the mean time to see if she's overweight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: September-12-2011 at 8:16pm
storm34, any idea what should a naked 1993 Ski Nautique hull should weigh? My carpet is out now, so if I'm going to do this now is the time. I'd rather not tear out the floor, but these photos have me rethinking my strategy. I got a 1993 because I didn't want to do a huge fiberglass job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AussieNorts Quote  Post ReplyReply Direct Link To This Post Posted: September-13-2011 at 1:08am
Kevin,
I have not removed any material other than the foam, the matt may have been roughed up a bit when removing the foam but not that much. I believe the glass has deterioated due to the moisture. The area is not soft I have not done the tap test as yet. I believe i will just sand back to good material and re matt and glass, pour the foam and get the hell out of there!!!! You are so right Mark I just want to take it to the lake!!!
Mark I have mentioned before that my partners family are all from Tamworth, I believe we are meant to come down for christmas , maybe we could catch up. Was thinking of putting the boat on a train down there so I can go ride on keepit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: September-13-2011 at 3:13am
Well crud. I'm glad that you are paving the way for me.
Rough 1993 Ski soft floor
I have some new questions:
1. How do you know the rest of your foam isn't wet where you have not cut out the floor?
2. What are you using to cut out the floor? I did my small cut with a razor blade, but that's not a process that will work for much more than a small area.
3. I notice that you are not cutting out the floor on top of the stringers. I agree with this concept since the floor is attached to the top of the stringer. How are you going to lay down fiberglass in those holes you have cut and "reattach"?
4. Those of your suggesting "sanding in", what type of sanding are you talking about? Is this sandpaper? A tool of some sort?
That's enough questions for now. I'm going to go get a beer and wait for replies.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: September-13-2011 at 3:20am
Oh, and I think I have a source for those screws! Let me have a look for you and I'll let you know. I know exactly which screws you are talking about. I have a labeled baggie full of them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AussieNorts Quote  Post ReplyReply Direct Link To This Post Posted: September-13-2011 at 4:30am
I have done some small cuts on the starboard side and there seems to be no moisture, but I would have to dig to the hull again to be sure, do not think i will be doing that before summer. I used a diamond tipped continious rim cutting blade for my grinder. I have to `taper the edges of the holes alot more yet then i will use strand and epoxy resin. Based on what i know and information here i just `step up each layer up the taper` applying approx 7 layers of strand with resin. I hope that is right. The sanding comment i am not too sure about, i think i would need to grind those areas just not sure if i will be able to get my grinder into there, a dremel would probably be better.
Really Kevin?, you think you can source new screws in black for me? You would be a lifesaver!! What about the rubber seal that was under the windshield any thoughts on where to get that, I have sourced most parts from Taylormade in Australia or US but the screws and that seal are nowwhere to be found. I read on here a thread about using powdercoat or not on windshields, well i have just done mine at my factory down our paintline. My operator told me that it needed to be epoxy primed first before the powdercoat, she did that and they all look great. I had them sandblasted first. I also did the vents under the windshield and the tower, all look amazing.
I will post pics if anyone is interested in seeing the powdercoat, They are not on the boat yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: September-13-2011 at 9:20am
I suspect that is an area that wasn't rolled out well in the first place. Note the foam that's 'under' the glass. All of that nastiness has to go away for new material to stick.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: September-15-2011 at 2:39am
Here's another question. WHAT are those cross-member pieces? Those vertical walls all are structural pieces. I'm just surprised to see that they go fore-aft as well as side-to-side.
Does anybody have something akin to a structural diagram for a Ski Nautique in the composite era?
I hope to go shopping for black screws tomorrow, but I need to know: Where did these screws come from? The smaller ones are for the windshield frame, right? Are the larger ones the screws that go into the hull?
And - sorry, but I do not have source for new rubber seals.
Email me directly at kevin dot roundhill at gmail dot com.
Kevin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: September-15-2011 at 12:49pm
Those screws look pretty basic, you can't find them on McMasterCarr's website?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-15-2011 at 12:57pm
black oxide 18-8 stainless screws at McMaster
Go to "pan head phillips" and scroll down the page.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: September-29-2011 at 4:27pm
How do you know what screw size that we have?
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: September-29-2011 at 4:32pm
hours and hours in front the screen reading CCF!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-29-2011 at 5:03pm
By measuring the diameter. McMaster will have a chart showing the size of #6, #8, #10, etc. But, here it is!!
#6 is .138"
#8 is .164"
#10 is .190"
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: September-30-2011 at 9:54am
isolated case?
Luchog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: September-30-2011 at 11:38am
and those with the composite hulls shall fear... water again!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: September-30-2011 at 2:25pm
I would think added weight is the only problem in a composite hull? or is there other concern? like water will rot something? will the glass loose strenght?
If you are a skier might concern the weigth thing as being heavier might affect the wake size! but as a wakeboarder It would be a plus!!!
only donwside is the increased fuel consumption...
mdvalant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdvalant Quote  Post ReplyReply Direct Link To This Post Posted: September-30-2011 at 3:21pm
Has anyone ever thought of placing a really fine screen about 1/4" off the hull and then laying foam on top? Then you could possible add some drain holes through the stringers to get the water out/let it drain? I guess those drain holes would then fill up from the bilge though...hmm.
I remember Chris Mars talking about how interesting it'll be in a couple years (a couple years ago) when we have people starting to tear up the composite boats. Thought it'd be a lot farther down the road than it has been.
'90 Ski (sold)
'00 Sport
