  New Posts New Posts RSS Feed - Rough 1993 Ski soft floor
KRoundy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Topic: Rough 1993 Ski soft floor
    Posted: September-13-2011 at 2:56am
I am freaking out tonight. I need your help to talk me off the ledge.
With apologies to my good friend in Australia, I thought I'd make my own version of this topic. I'm in the same boat as he is (pun intended). I mentioned before my little crack in the floor and if you've followed the 1997 SN soft floor thread (1997 SN soft floor) you can see where this is going.
I took these pictures literally minutes ago. Here is the crack cut out:
The water you can find by pressing on the foam:
Guys (and gals?), to be honest I'm feeling very overwhelmed at the moment. How am I going to do this? If you look at the pictures of my floor, I think you can see the spots where the foam is dark, which means it is wet (when I peeled back the floor the first layer of foam is really black, likely mold, maybe 1/2 inch or so).
I wonder if I can do this with my shady tree mechanic skills. What if I have to cut out the entire floor? I thought in a 1993 that I would not have to do this, but I'm guessing the entire underside of my boat is wet. Isn't the entire floor part of the structure of the boat? Isn't the floor bonded to the composite stringers? How does that work? Can I do this or am I just in way, way over my head? HELP!!!!
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: September-13-2011 at 9:44am
That crack in the floor is about where I keep my anchor. Maybe that's how it got there?
Seeing water that close to the surface means there will be more below. Don't give yourself a coronary though.
Here's what I'd do for both of these threads/boats assuming you have winter on the way:
I would carefully support the boat on 4 or 5 points paying special attention to leveling the mains. The 5th point would be under the keel towards the front.
Then I'd measure eveything and maybe make some templates so I could put everything back where it goes. From there, cut the floor out with a cut-off tool or a small circular saw set shallow and cut the floor out and remove the wet foam. I'd be very careful not to cut into the framework below.
After all is cleaned up and prepped for new material(and assuming the structural parts are still structural), pour in the foam-level it, and put in a new floor. The key here is to make the new floor water tight and tough enough to take some abuse.
Of course it's more complicated for an open bow, and I left out some details. All in all though, this should be much easier than a full stringer job.
And yes, the floor is structural. It ties the boat together above the lower structure.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: September-13-2011 at 9:54am
Greg, there is no way possible to make these floors water tight, these are some of the first plastic boats we are seeing but are starting to pop up and have a feeling there will be more to come. time will tell
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: September-13-2011 at 9:56am
Call me foolish, but I'm not willing to concede that yet. We'll see when I cut back into mine.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: September-13-2011 at 11:23am
No heart attack needed, it has a little water and some soft foam, it is not like the seats are going to pull out or the engine is going to come unattached from the stringers. While the issue isnt exactly cosmetic, it is not the end of the world. Like greg said remove what isnt solid and dry and replace. Worst case scenario you do a horrible job and "gasp" the floor isnt perfectly level, or next time it needs new carpet it needs to be shored up again.. but no safety issues and no resale issues beyond what it is right now. If I had all the materials on hand I would be surprised it if took 3 weekends.. one to remove and dry one to foam, level, glass, one to recarpet and install interior.
If it scares you this is not a job I would worry about farming out to a competent boat shop.. unlike a stringer job where there arent very many places I would trust for such a job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: September-13-2011 at 11:52pm
I'm going to dig into this area that I discovered and see what I find. I'm feeling better today after sleeping on it. It is just foam and fiberglass. I'll work on supporting the boat better (more evenly) and start cutting away. It will feel great when this is done and I KNOW that the boat is solid and dry underneath.
Dreaming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: September-14-2011 at 1:33am
Kevin - a couple of helpful hints for later...   when you cut out the glass and the foam, cut the glass big enough to work easily, but if you can, leave some glass for the patch to cling to.   since you're pouring back foam, the foam will support the center of the glass patch, but will also expand into the areas that are void spaces under the floor.   When you get ready to patch, sand the floor back at a shallow enough angle that you can see each layer of glass.   you'll want to try and patch layer for layer if you can, starting with a small patch that overlaps the old glass by about an inch. each layer patch will get an inch bigger, like laying a reverse cone (if the area is circular). Post lots of pictures! I am sure they will be helpful for the next guy who embarks on this repair!
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: September-14-2011 at 9:50am
to many variables on a boats history, i probably was refering to some of these 100 hour a year boats, weighed down, left out in the rain and never having the drain plug pulled....from what Ive seen it would be the majority.
someone pulled a boo boo in for a second go around, I watered my asphalt draining it for about 20 minutes...those are the ones im talking about
storm34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: September-14-2011 at 5:37pm
Well the good thing is that you can be one of the first (if not THE first) to go through and remove all the foam and put it back together on a composite boat.
I'd love to dig into our 96 and see whats under the floor just because I'm curious to how these things are holding up.
You already have everything out of the boat anyway, so why not tackle this project now?!
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: September-14-2011 at 10:11pm
storm34, this is a good point. I showed the problem to my mom yesterday and she said, "Well, good thing you found out now when it is easy to get to." Moms are so smart. :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: September-15-2011 at 10:53am
I was curious as to the condition of the foam in my '89. It wasn't unusual to get some water pooling around the drivers seat when surfing - I still can't figure out where it comes from (sealed the rub rail already).
So last weekend I removed the drivers seat, used a long 3/8 drill bit & drilled thru the floor (next to stringer), down to the hull (stopped at the hull, of course.). The foam came up bone dry, also used a wood stick as a probe & also no moisture at all.
I refoamed with great stuff & epoxied the spot.
Now I can sleep better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: September-15-2011 at 2:52pm
Kevin, I'm afraid you are entering uncharted territory (at least I've not seen this done yet.)
There are a few diagrams from the 39 brochure I believe, but nothing substantial.
As mentioned above, it should be a relatively quick process to take the old floor up, remove the foam and get the new stuff back in the boat. If you haven't had any experience with glass before it's a really simple process.
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: September-15-2011 at 7:21pm
Hey Kevin, can't remember if you are going to have to reupholster but I saw a 90-93 motor box skin listed on Christine's in the clearance section. Scroll about half way down.
Might be worth a look.
Christine's
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: October-01-2011 at 1:37pm
storm34, thanks! I had not seen that.
I'm into it now. Of course, I'm now thinking about the foam/no-foam issue. If I leave the foam out of my boat, how do I lay the floor back down? Doesn't the fiberglass need to "lay" on something to set up flat? Also, for anybody who has ever taken the foam out of their boat can you tell me if it is louder? I know that seems like a strange question, because boats are just noisy objects to begin with, but I'm curious. I'm leaning towards putting foam back in. My boat will never sit out in the rain or stay on the water for months unless I suddenly become rich and buy a home on a lake.
Of note, not all of the foam is wet. The top 2" is wet, but down near the hull some of the foam really seems to just be dry. I'm definitely pulling out a lot of wet foam, but not ALL of it is wet.
Good news: I found a trailer. Going to go pick it up in a couple of weeks. :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: October-01-2011 at 2:07pm
Dude you are going to foam your boat.. and then fiberglass over the foam. The foam/no foam debate has nothing to do with a 93 plus boat. you have a small repair to do pull out what is wet, foam over it, level the foam, and fiberglass over it.
To make that boat no foam you would remove all foam and then need to put down a deck of some sort.. what would you use.. plywood.. no coosa.. it would be rediculously expensive and a ton more effort to get you what you have now which is an all composite boat.
Luchog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: October-01-2011 at 5:11pm
you could laminate the floor over a glass like hassbeen showed on his build and then attach it to the boat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: October-02-2011 at 2:11am
OK. New question:
Why isn't my floor flat underneath? This was not something I expected. As I dug into my little hole (it is about 6" wide and a foot long now) I discovered that my floor has channels, if you will, and thicker areas all over the place up front. I thought the floor was just a thin layer of glass laid flat over the stringers. It is not.
The channels run side to side and fore-aft. Essentially it is a "T" shaped structure were the top of the T is my floor.
Is this COMPLETELY different than a pre-1993 boat?
AussieNorts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AussieNorts Quote  Post ReplyReply Direct Link To This Post Posted: October-02-2011 at 8:43pm
Kevin,
That is a new one for me, from what i saw underneath mine the floor looked flat. Just layed on top of the stringers, however i did not dig as aft as you.
Correct craft.....is there any other boat?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: October-02-2011 at 10:27pm
Pictures please.... I would exPect some structure for the seats to attach to under there, the pre 93 boats had plywood to screw into up front.
lewy2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: October-02-2011 at 11:51pm
Kevin this picture from the 97 brochure which shows the jig holding the stringers in place gives you a bit of an idea what is below the floor. Aussie also found some cross bracing between the stringers. Get some pictures while you have the foam out.
89 Ski
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: October-03-2011 at 1:46am
Let me see if I can get my camera down there to take some pictures. It will be hard, but I think I can figure out a way to do it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: October-03-2011 at 2:37am
Here is the hole I have cut in my boat floor in search of wet foam under the crack that had been created by the seat frame.
I poked my camera down in the cut out. This is what the view looks like looking forward towards the bow. The "ridge" on the right (looks like it is in the center in this photo) is attached to the floor. It is sort of an upside-down U, although I can't get to the other side of the U because of the frame (wall on the right).
This is looking aft. You can see the ridge here on the left. You'll also see on the right the front end of a composite stringer. More on that in a second. You can also see a ridge right in front of you that runs side to side, and there is a thick section of floor just aft of that ridge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: October-03-2011 at 2:52am
For the curious, the nose (for lack of a better term) of the ICS is plainly seen here:
This is a view of the thick area which is under my knees in the photo above. And yes, this area doesn't flex at all. It might be reinforcement for seats, but seems a little aft for that. It would more likely be where you place your feet. As far back as I have felt thus far the floor stays thick. If the "regular" floor (what I have cut out) is about 1/16" thick or so, I'd say that the built-up area is about 1/4" thick. So it is quite significant.
Steve from Australia - what do you use to dig out foam? It is not easy to get out of there.
Some of the foam is what I'd call dry, but much of it is still wet too.
I have poked a screwdriver into the foam going aft and it sunk to the handle, so I have a ways aft to go before I get to a brace that goes side to side.
Some more shots:
A view to the side (inside towards the middle):
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: October-03-2011 at 3:06am
Any thoughts about what I should do next? I'm thinking of trying to chip out as much foam as I can from here going aft and see if the floor gets "thin" again at some point. I will keep plugging away going forward as well and hope to find only dry foam or the bow of my boat at some point.
The hard part is that I don't know where else I should dig now. I have other spots where the floor flexes. Should I cut in there and see what I find or ignore it?
By the way, once I scrape away the foam the glass looks good. It is glass after all, so it can say wet forever with no ill effects.
Just to be clear, my main concern is that I don't know if I should venture into this floor too much with all these ridges and thick areas. What if that thick area is honeycomb or something like that? I'd hate to slice into that.
I also created a picture with more explanation of what you are looking at.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AussieNorts Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2011 at 12:06am
Kevin,
I would not worry too much about the other soft spots, it can seem soft, but what i noticed was that some of those areas in my boat is where the floor was not glued to stringer anymore. I used a small gardening spade about 4inch wide, it seemed to work well, if you have no delam of glass under there i would dig aft and forward till you hit a crossmember and if still no delam, pour the foam and stitch it up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2011 at 5:56pm
A gardening spade sounds like a really good idea! Thanks for that.
This crack was the only area where there was an open wound in the floor. The other holes we all there only for screws, and they had screws in them so I am assuming that most of those didn't let water in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2011 at 9:56pm
Kevin - check this post....might be something for you if you could make the distance work
Slipping transmission thread
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: October-10-2011 at 12:41am
I finally got a chance to dig into my foam a little more tonight. It's kind of weird and I'm looking for more thoughts from the experts here. The foam is wet, but not soaked. Is ANY wet foam bad? I'm beginning to wonder if this is worth the effort. The foam is still rigid and is quite hard to dig out because I'm working in such a small area.
The floor in my boat appears to be quite thick in many places. There are 3" disks (for lack of a better word) where the floor is thin. The problem is that there is no way I could dig out all the foam with a tiny three-inch hole as my access point.
Do I need to go after ALL the water? If the foam is still rigid, but still wet, is that a real problem?
uk1979 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: October-10-2011 at 8:59pm
I wonder if you where to rig up a shop vac to the hole seal all around the pipe and switch on for a while it would draw the moisture out the foam into the void which can then be soaked up with rags.
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: October-10-2011 at 9:20pm
Wow. That's an interesting idea. I don't think you'd ever get all the water doing that, and it might take a really long time since the water essentially leeches very slowly in the foam. Still, it might be worth a try just to see what happens.
