  New Posts New Posts RSS Feed - Fuel vent belching gas ???
MMT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MMT Quote  Post ReplyReply Direct Link To This Post Topic: Fuel vent belching gas ???
    Posted: September-18-2011 at 9:27pm
I bought my Tique in pieces 81 Tique and finally got it in the water about a month ago. Absolutely no issues at all, except that when it's full of gas the vent belches gas out on the back of the hull into the lake.
Is there supposed to be some sort of baffle or valve in the vent hose to prevent this from happening?
Thanks,
Kent
Luchog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2011 at 9:45pm
Mine does the same thing, ---wrong idea/bad suggestion edited for future readers----
add a high loop on the hose to the vent
MMT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MMT Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2011 at 9:53pm
I can't really high loop it. The glass is directly above it now. I was wondering if I could find some sort of petroleum resistant foam to pack in the hose, in a spot where it couldn't get back into the tank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2011 at 10:59pm
I'm not sure I follow your idea.
And then I though on the one way valve i suggested earlier, that would work for not letting water in, not fuel out, so dischard that idea.
sweet77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sweet77 Quote  Post ReplyReply Direct Link To This Post Posted: September-19-2011 at 12:02am
i just don't fill my boat completely up. i filled up one night and the next day my house and garage smelled like gas. it was horrible so i siphoned the excess fuel out never had anymore trouble
76 Nautique
"If you do what you always did,You'll get what you always got!"
"An empty wagon makes t
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-19-2011 at 12:45am
Kent isn't following the idea!!
Kent,
High loop the vent hose!! It works!!! Do you want a picture?? Get a longer vent hose - like about 5' longer. From the tank make a big loop and strap it to the underside of the aft deck before going to the through hull.
BTW, not overfilling the tank helps too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: September-19-2011 at 9:25am
Pete, double up on the meds, you've been edgy lately
MMT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MMT Quote  Post ReplyReply Direct Link To This Post Posted: September-19-2011 at 10:12am
I follow. Lol. Thanks pete i will give that a try.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: September-19-2011 at 10:30am
I thought for a minute 79 was filling in for you Pete
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: September-19-2011 at 12:11pm
When it's happening crack open the fill cap, it will stop the siphon/belching.
M3Fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M3Fan Quote  Post ReplyReply Direct Link To This Post Posted: September-19-2011 at 12:35pm
How about adding a fuel/air separator?
2016 SN 200 OB 5.3L DI
https://forum.fifteenoff.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-19-2011 at 1:27pm
Eric,
If I was taking his meds, I wouldn't be able to write at all!!
MMT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MMT Quote  Post ReplyReply Direct Link To This Post Posted: September-19-2011 at 7:03pm
Its not from pressure building up, it is when i am accelerating.
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: September-19-2011 at 9:26pm
That's because the gas sloshes to the back and pushes the fuel up the line. Adding the suggested loop gives the gas farther to travel without spilling out.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-19-2011 at 10:55pm
Greg,
Yes!!!! It worked for me on my Tique.
Joel, there's no vertical room between the tank and the deck to get one of the "check valve air/fuel separators" in there. They need to be installed vertically and there just isn't the room.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2011 at 1:06pm
I didn't read the original post very well. Apparently i've never had my gas tank that full...
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2011 at 2:31pm
Actually, it is pressure. HW's point is to add a second vent for air.
1988 BFN-sold
martin 74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote martin 74 Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2011 at 2:33pm
High loop the vent hose Get a longer vent hose - like about 5' longer. From the tank make a big loop and strap it to the underside of the aft deck before going to the through hull.
Great idea for many of us with vinyl graphics on the transom. I'm doing this ASAP. I never wanted to redo the graphics back there thinking gas leakage would be a reoccurring problem when trailering and backing down the ramp.... Plus it's much safer with less smell.
The way gas prices have been fluctuating I have been filling up more when gas is cheaper.
A lot of smart folks on this site.
Thanks
Rich
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2011 at 2:38pm
Just make sure the loop is horizontal, not vertical. You cannot have trap like under your sink, otherwise it will fill with gas or water and no longer vent.
Keeganino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2011 at 12:30am
I have this problem too. One more winter project to add to the list. Easy fix too. Right now I try to never fill up much more than 3/4 tank.
1973 Skier
