  New Posts New Posts RSS Feed - Foam vs. No foam
Foam vs. No foam
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2011 at 12:40pm
Agreed, thicken your skin that was just good old fashioned salesman bashing!
The layup in the non foamed areas of my 83 was thicker than in the originally foamed areas
This likely had more to do with the proximity to keel, larger span between stringers, relative flatness of the area in question, etc. than the simple fact that the area wasn’t foamed but nonetheless the bilge where I cut through for the paddle wheel was 3x thicker than the area forward between the stringers that I cut through due to carelessness.
I dont disagree that the layup on a skiboat is in general considerably more substancial than is required by the loading seen on the hull during normal use.. however I tend to not discount the abnoral situations very quickly. I am not sure that I wouldnt possibly see a rock, log, or worse at some point (hopefully not at speed but it can't be ruled out).   Even a broken or poorly designed trailer or hoist bunk can provide significantly larger point loading than a boat sees in normal use.
My position remains that you dont need no rottin, stinkin foam.. but if you simply remove it and dont give any thought to replaceing the benefits it supplies you may (although likely not on most of these boats) someday regret it..
MIskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MIskier Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2011 at 12:34pm
BTW, pulling a thru-hull to see the lay up isn't the greatest idea. Decent boat builders will build up the area with a couple more layers of glass. [/QUOTE]
Yes that is correct, but it does give a fair idea of what the hull thickness is on a given boat.
2006 MasterCraft PS 190
1986 CC Ski Nautique 2001
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2011 at 12:25pm
Bashing is part of competition. The salesman I refer to was actualy a sales rep from Mastercraft and our conversation started out with him telling me how Malibu and Nautique were poor quality boats compared to a Mastercraft, he was bashing. When I told him I owned a fairly new Malibu, he backed off, but I told him he wasn't hurting my feelings and I wanted him to show me why he thought his boats were better. He went on for a half hour. I was impressed with the thick plug he showed me and I asked him if maybe due to all that weight from the thickness of the hull was the reason why the Pro Stars are so slow out of the hole and at top end. He actually told me they were designed to be slow as ski boats don't need to be fast. Tim, I think that was the Sunday after the Saturday that you guys were eating Cheezits in his boats.
Anyone ever try putting a match to a pool noodle?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2011 at 12:24pm
Nobody bashed MC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MIskier Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2011 at 12:15pm
On a 20+ year old boat?! I highly doubt that got saved during the move.
Haha very funny you're all so original with your MC bashing.
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2011 at 11:52am
Some guys prefer heavy hotties with lots of floatation, what can you do? But they do tend to retain water.
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2011 at 11:32am
Originally posted by Riley Riley wrote:
Pete, the MC salesman at the Boston show showed me a cut out from the bottom of a hull and it was about 3/4" or maybe even an inch thick.     Course, as you note, maybe they build them up around their through hulls and that's not a good representation of how thick their hulls are, although that's the claim he was making.
Ha, it sounds like that salesman was... a salesman.
Ive dissected a few CC's and the hull thickness can approach 1/2" or more in a few places- namely the keel, or around certain through hull hardware. Most areas of the hull are much thinner- between 1/8" and 1/4", generally speaking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2011 at 11:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2011 at 9:43am
Originally posted by BuffaloBFN BuffaloBFN wrote:
I'd luv to see the lam schedule for an 88 BFN. How does one get that info? And don't say 'Ancient Chinese secret'.
Originally posted by MIskier MIskier wrote:
That is not something that you will be able to get a hold of, but if you pull out a thru-hull fitting you can see your hull thickness.
What's the big problem with getting the layup? Maybe with a MC since they don't want people to know just how thin their hulls are???!!
Greg, all that's needed is to call Dave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MIskier Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2011 at 2:15am
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2011 at 2:12am
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote MIskier Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2011 at 2:04am
Correct Crafts, there are plenty of production boats out there that have had little structural calcs done on them. MC and CC though are way over built if you ever look at a lam schedule for one of them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2011 at 2:01am
You're talking CC's or boats in general?
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote MIskier Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2011 at 1:53am
Not really the boats have been built lighter over the years, but never to the point that hull loads would become an issue unless you enjoy regularly parking your boat on rock piles.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2011 at 1:37am
FWIW-That topic has been beaten long past when the horse looked like a horse around here.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2011 at 1:36am
There are some definite trade offs to be considered when re foaming a boat.
1) It does serve as to add some structural integrity to the boat, but these boats are overbuilt for the types of hull loads that they encounter.
2) Does help quiet the boat down while underway.
3) Most importantly is the added buoyancy that it gives the hull. When originally designed these boats had to be able to pass a level flotation test. Without the foam in the hull if there is a catastrophic breach of the hull your boat will not be able to survive fully swamped.
Lemme just say
Is there a year range or cut-off point for the second part of # 1?
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote MIskier Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2011 at 1:11am
peter1234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter1234 Quote  Post ReplyReply Direct Link To This Post Posted: September-19-2011 at 4:30pm
thanks pete yes i use drier sheets now in all the cars and the boat seems to work well . i have had a hard time getting the coyotes to go on my wifes nylons they seem to want to do something else to her leg.... yes she has nice legs
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: September-19-2011 at 12:48pm
Originally posted by DrCC DrCC wrote:
I just think it would be funny to see the look on a prospective buyers face when you guys tell them:
"Oh yea, the hull is chuck full of pool noodles."
Clinch the sale, imo
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-19-2011 at 11:49am
Originally posted by peter1234 peter1234 wrote:
or mice get in during the winter .
Dried coyote urine in old nylons works wonders. Available at Ace. Some also use drier anti static sheets too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter1234 Quote  Post ReplyReply Direct Link To This Post Posted: September-19-2011 at 11:08am
i used pool noodles . i see particles once in a while so i assume either they break down in time or mice get in during the winter .
Nevergrew View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nevergrew Quote  Post ReplyReply Direct Link To This Post Posted: September-17-2011 at 8:25pm
From what I've read here since owning a SN, I reckon the foam causes more issues than what it's worth. I totally understand why it's there - positive flotation, structural integrity, sound absorption etc etc, but you only need a light nick in the floor skin and the thing starts filling up with water, with no where to escape.
I don't think there's ever been a 70's 80's or 90's hull manufactured in Oz that had foam under the floor - Lewy may correct me on that one though.
Most hulls have 3 bungs on the transom, a centre for the bilge and two outers to drain the underfloors, if any water was to enter. Some wake boarding guys with older boats have rebuilt the floors to hold ballast water using a gel coating inside.
I reckon if I ever need to redo the floors on mine I'd go no foam.
That's my 2 cents anyway
charger496 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote charger496 Quote  Post ReplyReply Direct Link To This Post Posted: September-17-2011 at 1:23am
As much time and money as I have in this boat, selling it will NEEEEVER be an option!
KRoundy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2011 at 8:51pm
Hahahah....
Jwbolton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jwbolton Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2011 at 3:26pm
If i end up using pool noodles, I will be putting in some ribs just for a little extra support for the floor.
'72 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2011 at 3:07pm
It's not 'fugly'?
You are correct! I wish I had some typing skills!! I did edit the post!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2011 at 3:04pm
It's not 'fugly'?
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2011 at 1:54pm
Fair enough... at least the 1st gen (60's) hulls have been proven to be fine without the foam (and no additional support). Not sure we can say the same about the 70's hulls, as foam was standard by then. I guess I would strip the boat in question down to the bare hull and see how much it flexes under load before deciding that supports were unnecessary.
I agree and have a tendency to say the 70's hulls can take it without exra support.
Regarding the pool noodles, I'll use one of Tims favorite terms: they are just too "fugly"!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2011 at 1:45pm
I think its a given that if you choose not to refoam, then the structural rigidity that the foam provides (hull-foam-floor sandwich) should be replaced with something else. Most choose to glass in horizontal ribs.
I would say it is a given in a 82+ SN, it is my choice but debateable in 70s hulls of all type.. but you get into the first gen fiberglass hulls where some where not foamed to begin with and well.. given would be a strong word.
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2011 at 1:21pm
