Rough 1993 Ski soft floor |
Post Reply | Page <12 |
to dry em up, I use a commercial de-humidifier with the boat cover on or a tarp, a normal de-humidifier works well also
KRoundy
Eric, you have done that before? Do you think that would suck the water out of the foam in my boat? How long would it take to dry everything out?
Kevin |
Keeganino
I used to work for a company that mitigated water damage. They would set up fans and dehumidifiers in the affected areas for up to a week. Daily moisture checks measured progress and there was a target moisture level that had to be achieved before we could sign off on a job. Even with good air flow and dehumidifiers I am not sure that you could dry out wet foam. It would get some of the water out for sure but that foam really locks the moisture deep inside.
It is starting to sound like once you are in there it is probably just as easy to remove all the old foam, dry the structure, refoam and reglass. Does not take that long to demo the floor and foam. |
1973 Skier |
BuffaloBFN
Granted you've done it once, right? |
KRoundy
Keegan,
Have you seen my posts about the bizarre nature of my floor? It's not a simple flat layer of fiberglass. What is the "varying thickness" of my floor? I'm still waiting for somebody to tell me what all the ribs and thick (about 1/4") and thin (about 1/16") areas in my floor are about. Can I just cut through all this stuff? I'm reluctant to do so because replicating the complex arrangement of ribs and built-up areas would be very hard. I'm still working to get out all the wet foam, I just can't find a way to cut huge holes in my complex (post-1992) floor to rip all the foam up easily. Two nights ago I gave up on the tools and was reaching in and pulling it out with my bare hands. I would LOVE to go look at floors being installed in the Nautique factory to see how it is done (assuming today's boats have a complex floor similar to mine). Any helpful thoughts would be sincerely appreciated. Kevin |
Keeganino
I have been following this thread and no doubt the floor layup is different to the one I rebuilt. The floor in my Skier varied in thickness from very thick to barely being thick enough with no rhyme or reason other than inconsistency. Once a cut was made all the way around the perimeter of the floor the entire piece would pop out using a pry bar. It may not be that easy with the new composite system, I don't know. If the floor is bonded to the tops of the stringers you would probably have to cut the floor right up to the edges of the stringers, remove that piece of floor, and then grind the top of the floor on top of the stringer down to the desired height.
I understand your hesitation to go hacking away further, especially since you are taking one for the team digging into a post 92, but the time it would take to remove all the foam and floor will be less than what you have spent so far extracting foam by hand through a small opening in the floor. Keep in mind fiberglass is a really easy medium to work with with regards to putting the floor back in. I spent a couple of weeks digging into the stringers with screwdrivers and after I found that everything was wet, and convinced myself I could tackle the project, removed the floor and all the foam in 2 evenings. At the very minimum I would remove the floor over the entire cavity you believe to be wet and get after it. Forget the little holes. These may be of little help in your application but shows the concept. Before After cutting perimeter with angle grinder and removing floor |
1973 Skier |
Kevin, I think many of us would be very interested in seeing what the stringers and floor look like in a 1993+ boat! Unfortunately, thats been something that just hasnt been shared yet- even during the documented build of the Crush. You may be on your own, if you decide to tear into it, unfortunately. If I had to guess though, I dont think youre looking at anything overly complicated. You may want to study some of the older stringer rebuild threads and see how the wooden-stringer boats were built from the factory. I would bet that the heavier build up youre seeing in the floor in that area is meant to specifically address the mounting of the seats and lend strength to the area that spans over the bilge. Basically, its doing the same job that the 3/4" wood floor section between the motorbox and battery box did. My guess is that the rest of the floor will be similar to the older boats (1/8" or so thick). I would say that if you wanted to replace all of the foam, you could cut the floor out and either reuse this section when rebuilding it, or put a piece of coosa in this section. The rest could be the original glass over foam. Just a guess! |
bkhallpass
I would think the thick portions you are seeing are the top of the fiberglass "rib structure" in the boat. Someone posted the drawing. It's more like a corregated structure than the traditional ribs we see in the wood boats. Just my guess. BKH
Livin' the Dream
uk1979
Platinum Member Joined: June-13-2007 Location: United Kingdom Status: Offline Points: 1422 |
I throw this one out here, this may work if you drill vent holes all over the floor then insert straw type tubes down through the foam which have holes drill up the sides then roll over the hull with an RF gun which would vaporize the moisture, would like to give it a go to see what happens, the main down side I can see is if there is moisture under the gel it will blister it as well, the US one I found will go 2’1/2,in deep on their big one so may work if you used it on the floor side, think it’s time for more meds now
RF Gun |
Lets have a go
i could possibly snap some pics of that 95 hull I have, the floor is out along with the foam, the complete structure is there, i really dont know if this is the correct structure or not since it was a display boat and has never been in the water.
i also have a 92 hull with a the foam out and there is a piece still up front and you can see the waterline about 6 inches up in the foam, this boat too was soaked and the stringers were completely rotted. im getting ready to cut that one up, I need the forward deck, the rest will get the sawzall....I really was thinking of using the front hull as a man door canopy |
KRoundy
Eric, how did you get the floor out of your '95? I'd LOVE to see a picture or twenty...
KRoundy
I know this has little to do with my wet foam (still digging - had not much spare time lately so progress is slow), but I found a trailer for my boat. Got a great deal (less than $500) I'm excited to get this step behind me. Going to re-carpet the bunks before I slide it under my boat. It's a little rusty here and there, but solid, and will work for the 1 mile trek from my house to the boat launch.
Kevin |
storm34
Thats a good looking trailer for under 500 bucks! Nice find!
KRoundy
OK. Update time for anybody following my wet foam saga. I have dug out the wet foam in the section that was under the crack in my floor. I took some photos.
This is looking forward in the hole. This foam is dry. I've dug in for a few more inches and it's all dry. This is looking aft. It's a long ways back there. I can't reach it with my hand, even when my shoulder is all the way down in the hole. I had to dig at it with a nail claw and a long screwdriver. It was really slow going. I was a little surprised tonight to pull the lid off my shop vac and see that I filled it up along with the stuff I pulled out by hand and put in this 5-gallon bucket. Next, I gotta figure out where to buy foam and then teach myself fiberglass repair. Or, go look for a sale on pool noodles? |
