1991 Barefoot engine problem |
davidrupp
Newbie Joined: July-09-2006 Location: United States Status: Offline Points: 2 |
Posted: July-09-2006 at 7:48pm |
I have a barefoot with a 454, ecm just recently quit, replaced with a distributor and coil, but engine still doesn't run good. Nautique sells a conversion kit to do same, has anyone ever used it?
Dave
Bradley950
Senior Member Joined: February-07-2005 Location: United States Status: Offline Points: 168 |
When you say dosen't run good what do you mean? Are you talking about using the convertion kit, what kit?
Brad Miller
bradley950@yahoo.com |
davidrupp
Nautique offered a conversion kit, a mallory distributor, coil, wiring harness for $700.00 I bought the items thru Summit Racing for $200.00 The wiring is pretty basic to bypass the existing wiring. The engine misses really bad, and won't idle.
Dave
Bradley950
Have you cheaked the timing? Did you pull the dist.? Is the firing order right? Just some questions so we can figure this out.
Brad Miller
I assume you used a marine distributor? That shouldnt affect how it runs, but an automotive unit would be a safety hazard. I agree with Bradley950, check the simple things first- start with the firing order. |
