  New Posts New Posts RSS Feed - Oil pressure sending unit
downtime View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote downtime Quote  Post ReplyReply Direct Link To This Post Topic: Oil pressure sending unit
    Posted: July-15-2006 at 6:08pm
Just wondering if this is the correct sender for a '85 Nautique 2001. Motor is a 351. It's the only one skidim shows on their site.
Thanks
http://www.skidim.com/prodinfo.asp?number=R020001
jimbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimbo Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2006 at 1:57pm
That is the correct one.
Just don't use one from the auto parts store; it won't read properly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote downtime Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2006 at 2:48pm
Thanks. I stopped by a local marina and they said one from an auto parts store would work. I didn't think it would.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2006 at 1:46pm
the resistance is different on the sending units and guage, Car vs boat that is.
Never go back to that marina again to have your boat worked on they don't know anything and will rob you blind.
Post Options Post Options   Thanks (0) Thanks(0)   Quote downtime Quote  Post ReplyReply Direct Link To This Post Posted: July-26-2006 at 12:26am
Got the unit on this weekend. Oil pressure now stays at 40 constant. If I give a little throttle it will rise to about 45 but otherwise steady 40 psi. I think this is ok, just expected a little more variation. Oh, that same marina sold me an impeller last year for under $20. The mechanic I spoke with might be a little "off", but it seems their parts are reasonably priced.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimbo Quote  Post ReplyReply Direct Link To This Post Posted: July-26-2006 at 10:16am
Mine varies between 5 psi at idle to 45 psi at wot.
I'm not worried yet. But I know I'll need some work one of these days.
