  New Posts New Posts RSS Feed - Dripping Dripless Shaft Seal
skitique179 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skitique179 Quote  Post ReplyReply Direct Link To This Post Topic: Dripping Dripless Shaft Seal
    Posted: February-02-2012 at 2:34am
Last weekend noticed that there was water in the bilge of my Tique after a day on the water. After further investigation I found that the supposedly dripless shaft seal was dripping while the shaft was spinning.
Any tips on why this might be happening and how to fix the problem?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-02-2012 at 8:11am
It's ether an alignment problem that you will correct when you get the trans back or a bent shaft that I also suggest checking. In ether case, you'll need to install a new mechanical seal. It could also be damaged if it had ever been run dry. You haven't been running the boat without water being hooked up have you?
Fl Inboards View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: February-02-2012 at 10:49am
What drip-less seal do you have?
Post Options Post Options   Thanks (0) Thanks(0)   Quote skitique179 Quote  Post ReplyReply Direct Link To This Post Posted: February-02-2012 at 6:59pm
The shaft is brand new so I don't think it is that. It must be an alignment issue. It also has not been run dry. Where can I buy a mechanical seal. Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-02-2012 at 7:03pm
No one can help you until you tell us what kind of "dripless" system you have installed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-02-2012 at 10:19pm
NG,
Tim and Jodi really summed up the issue - We need more info.
Is the new shaft no more than a TIR of .003"?
Post Options Post Options   Thanks (0) Thanks(0)   Quote skitique179 Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2012 at 12:33am
It is a PSS Dripless shaft seal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote skitique179 Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2012 at 12:35am
And the drive shaft is an Elbert's A.R.E. system that our mechanic purchased and installed. It can be seen at the following link
http://elberts.com/system.htm
Post Options Post Options   Thanks (0) Thanks(0)   Quote skitique179 Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2012 at 12:38am
Also the drip is coming from the end on the right side of these pictures and when the shaft is spinning. Thanks again for any help
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2012 at 9:09am
NG,
First: proper link
Second: I have a feeling you need a new "mechanic"!! You already have a trans problem with this guy! Is he a I/B or O/B "mechanic? Also you never responded to the question about the boat being run without water. If out of the water, no water and run in gear, it doesn't take much time to screw up the carbon/ceramic mechanical seal.
OverMyHead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2012 at 10:38am
Pete, he says here it has not been run dry.
Purchase at the ususal places, SKIDIM etc....
1987 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2012 at 10:39am
Pete, since that style of dripless packing pulls water from the engine to lubricate the seal, I would imagine that it wouldnt be as susceptible to damage as a normal packing gland, if run dry. Still a bad practice, though.
I would call SkiDIM and see if they sell replacement seals for the PSS system. I know they sell them for the OJ dripless system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2012 at 10:41am
Dave,
Thanks. My ADD kicked me again!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2012 at 11:24am
[QUOTE=skitique179]
Looks to me like it has been hit with a hammer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2012 at 11:51am
Tim,
Yes, I understand where the water comes from on a dripless. I guess I didn't phrase my question well enough. If he ran the engine dry, then the dripless is not going to get any lubrication. I've had plenty of mechanical seals apart. It really doesn't take much to screw them up. The seal faces can look perfect but you put them back together and they leak!
