Tranny cooler |
lakedog55
Posted: March-22-2012 at 9:34am |
Hi, I ordered or they shipped a 7" cooler boat calls for a 5 will the 7 work? going to the sjrr today. Old cooler must still be leaking. put a new rear main seal in yesterday and still had a slight dicoloration.
Thanks Mike |
Lakedog55
Dog,
I'm not following you here. Are you dripping oil in the bildge (rear seal) or are you getting water in the tranny fluid(cooler leak). What discoloration are you talking about. |
lakedog55
Thanks,
I did the rear main yesterday so hopefully that oil is no longer there. The tranny had the slight discoloration, It had a pretty good amount of water in it awhile back so I drained a few times and it seemed to clear up.Pressure checked the cooler and did not see any leaks, but now there was a little water in the fluid, after about 5 hours running time. Mike |
Lakedog55
lakedog55
I was still asleep on the first post.
Lakedog55
Sounds like an interior cooler leak to me thats about the only way water can get in the tranny oil.
The 7" will work as long as you can fit it in and the cooler lines reach. How did you pressure test the cooler? |
lakedog55
This should get a few comments Southern Engineering
Lakedog55
OverMyHead
Does the skate board make it a mobile testing device?
1987 Ski Nautique |
Mike,
How many times did you change the trans fluid? it may take several before you get all the water out. |
Hey Pete has the same board,keep it original!
Did you get water out the fluid fittings during the test?
lakedog55
Pete,
Changed probably four to five times, Tranny runs smooth no slips sounds smooth That is a mobile leak device |
Lakedog55
lakedog55
no water out of fittings let it run like 6hrs
MIKE |
Lakedog55
HatterBee
Hey maybe you could market that mobile testing device and go around and help others!!
Seriously, it will take several fluid changes to get all the water out. Water will find all the little nook and crannies it can within the gear and hide. Also remember that it only takes a little water to make the fluid look milky. Flushing would make a better method of removing the water. |
If you didn't get water out the fittings that tells me it isn't leaking. That would be the only place water could get in to the fluid.
Am I forgetting something and there’s somewhere else the water could get in?? |
perfect example of someone not using a wrench on the hex
the PCMs and ZF will send 120 psi of oil through that cooler, the BW only sends cascading oil through it, no big PSI with the Borgs
Eric, Good info to know - thanks. Since Mike didn't really give us much on the year of his boat nor has it in the diaries (no avitar at least) I had to get it the hard way by doing a search through his old posts. It looks like he has an 84 SN so that tells me he most likely has the Velvet B/W. At least he has the new cooler since I would not trust his testing method. |
actually i never even gauge them because i knew the burst pressure is way up there, normally aired them up and dunked em
I assumed he plugged the one end and pressurized it with water pressure.
