  New Posts New Posts RSS Feed - Oil gauge
Oil gauge
eneitz220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eneitz220 Quote  Post ReplyReply Direct Link To This Post Topic: Oil gauge
    Posted: March-29-2012 at 2:10am
Took my boat out for the first time this year. Oil gauge was showing no preasure. Checked everything out everything was good. Ran it for a little while then gauge bottomed out the opposite direction. My first thought is something is wrong with gauge. Any advice?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2012 at 8:40am
First check the 12 volt connection on the gauge. It sounds like this may be intermittent. If good, remove the wire from the sender at the engine and ground it to the block. If the gauge pegs max, the gauge is good and the the sender may be bad. Make sure you do not have any type of pipe thread sealer where the sender is screwed in. That's the ground source for the gauge.
Welcome to CCfan. Tell us more about the boat and we love pictures! Get some pictures are text submitted for the diaries.
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2012 at 4:52pm
have to try this on mine also, died again...
Post Options Post Options   Thanks (0) Thanks(0)   Quote eneitz220 Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2012 at 11:52am
I called the service department @ buxton marine. They told me to check the digital gauge by pressing the m button on the hours gauge. It was reading perfectly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2012 at 11:56am
This is where good info from the start is very important. We had no idea what boat or gauge you had. I assumed it was an analog. Sorry!
Post Options Post Options   Thanks (0) Thanks(0)   Quote eneitz220 Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2012 at 12:09pm
No problem. I appreciate the help. I'm sure I will have many more questions. Just got the boat @ the end of last season.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eneitz220 Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2012 at 12:12pm
Here is one, one of my ballast pumps is making a louder not so good sound when I turn it on. Is there any type of maintenance Icahn do for the pump other that changing the impellers in them.
DFoster View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DFoster Quote  Post ReplyReply Direct Link To This Post Posted: March-31-2012 at 3:50pm
What does pressing the "M" button do. I've got a 2004 SV211, so digital guages (so I'm told). Does it run the guages through a test?
I recently "fixed" a fuel guage issue just by diconnecting and re-connecting the wires, and now am on to trying to get the ballast guages to work, but that takes either pulling the senders out, or being out on the water. Some quick test to see if they actually move would be good.
Does the "grounding" of the sender wire test work with a digital guage?
Proud owner of my first Nautique! A 2004 SV-211. Always looking for "extra ballst" for wakeboarding or surfing ;-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote eneitz220 Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2012 at 12:15pm
On my 2006 220 I have two digital gauges underneath the speedometer and my rpm gauge. There is a "m" button underneatheach digital gauge witch stands for "menu". By pressing m it allows you to leave it on different setting.   The digital display on the far left allows you to leave it on hours, volts of your battery, oil pressure, and engine temp. The only gauge that it doesn't have on digital also is fuel.
must_dash View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote must_dash Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2012 at 5:52pm
Must be a day for oil pressure,Just cranked up the Martinique and no oil pressure. Trouble shooting planed for tomorrow.
1986 Martinique - sold
When we ask for advice, we are usually looking for an accomplice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2012 at 8:00pm
No oil pressure by the gauge? Check to see if you have 12 volts nominal going to the gauge.
If in question,it's best to check it by tapping in a mechanical next to the sender.
Post Options Post Options   Thanks (0) Thanks(0)   Quote must_dash Quote  Post ReplyReply Direct Link To This Post Posted: April-02-2012 at 10:36am
Sorted, blue wire had come off the back of the gauge.
All the wires in the loom at the back of the dash are really tight and if the loom is disturbed connectors pop off.
