  New Posts New Posts RSS Feed - Vacuum advance port from distributor
Kingiant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kingiant Quote  Post ReplyReply Direct Link To This Post Topic: Vacuum advance port from distributor
    Posted: May-17-2010 at 3:22pm
Currently my vacuum advance port coming off my distributor is not connected to anything. There are no vacuum ports on my carb. It is an aftermarket Chevy 350. What i was thinking was removing one of the plugs that is directly into the intake manifold. Then putting a vacuum fitting in that and run the vaccum advance to this fitting on the manifold. Does anybody see a problem with that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2010 at 3:29pm
I see a major problem with that, IT'S AUTOMOTIVE AND NOT MARINE GRADE.
That whole unit needs pulled along with all of the other car crap on the engine and needs replaced with marine specific parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2010 at 3:31pm
Joe,
The problem is marine engines do not use vacuum advance distributors. They are mechanical advances. Yes, there is a problem running a marine with a vacuum advance. The vacuum created is different due to the engine loading in a boat. It won't work. I suggest getting a new marine distributor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kingiant Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2010 at 3:41pm
That would make sense. i will look into replacing the distributor. To be clear this was not my doing. The engine setup came with the boat. It runs fantastic, I just thought I may be missing some top end because of no vacuum advance. But that makes a bit more sense now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-18-2010 at 2:20pm
you need to be looking at the carb, fuel pump, alternator and the starter as well as the core plugs for the block (slang freeze plugs). All of these items are marine specific and it wouldn't surprize me that it's a car engine with all the non-marine specific items.
sprayin99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sprayin99 Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2012 at 2:31am
Ok, I see this post is really old but I became a member just now to offer some info on this for anyone searching. A automotive grade vacuum advance dis CAN, CAN, MOST DEFINITELY, ABSOLUTELY CAN, WORK!! PERIOD!! And can even give a performance increase on carburetor engines. Here is the real explanation.
For this example we will use say an 86 range 5.7 mercruiser with a Thunderbolt IV ignition.
1. The stock marine unit has an iron gear, magnetic pick-up, external coil, No advance to speak of, and a seal to keep water out with a vent tube on one side of the housing. Now before anyone tries to give flack, NO they do NOT have mechanical advance! On this particular model (carbed thunderbolt) the ignition amplifier mounted on the riser acts as an electronic advance but is vague. Basically you are set at 10 btdc at idle and the unit will increase the advance to 24 deg on top of that starting at 1000 rpm and becoming full circle (34 deg) by 3800 rpm. Now in stock config in proper working order this is pretty good. However depending on engine modds and prop sizing (load on the engine), that pre set config is not perfect. Vacuum advancing can improve every aspect of this.
2. I hear allot of people suggesting hooking the vacuum line to the intake manifold, DO NOT DO THIS. There is allot of speculation from tuns of different guys or gals on these forums on how the vacuum works. Let me sum it up, Vacuum will generally be about 17inhg at idle in the intake, this goes to ZERO at WOT however again, the carb venturi vac raises with engine rpm to WOT. So in short if you hook the advance to the intake you will get the adverse effect of full advance at idle and retard at WOT causing detonation and a grenade eventually. For holley the correct location is on the front metering block on left side looking at it for Rochester, carter, afb, edelbrock check the manual or Internet as they vary.
3. Now that we know where the vac hooks up lets talk distributor modifications from auto to marine spec and the advantages of having the vac advance. First you will need to change the dis gear from the factory auto steel unit to an iron one for marine use. The housing from there up to under the rotor is the same, now buy the water tight gasket used for truck 4x4 and this will keep the cap water tight for moisture or spray, next there is a water stable coil (coated) for the top mount HEI. Now you are marine spec, No sparks, Water resistant, and the correct drive gear.
Lets talk advantage. You have installed your new distributor set it to spec and are wondering what to do, well with the HEI system you only have to get the connector for the coil pos and neg, then hook the pos and neg wires from your old coil set up (coming from the ignition switch not the ones for the mercruiser amplifier box). You can now chunk the old coil amp box and so fourth, Saves quite a few hundred dollars if your mercruiser box or dis is bad.
4. With this complete you are ready to take full advantage of the poor mans computer corrected spark advance used in newer efi versions. You can now set the dis to 10 btdc, hook up to the water hose start your engine and have a timing light ready that has advance adjustment on the back of it. With the motor running set the light to 32, 34, or 36 (depending on engine mods) raise to 2000 rpm and check to see if the timing tab lines up with the balancer at zero. If it does not do not turn the distributor, instead there is an adjustment in the dis under the cap that allows fine tuning of the advance. Adjust this screw and slide rod in or out to give desired advance on vacuum. Now rev the engine to be sure it does not go over your specified setting for total timing of 32, 34 or 36 (most mildly modded sbc like 36 total). Once this is accomplished you are ready to reap the benefits because at light throttle or a heavy load the vacuum will not be engaged yet thus keeping the engine retarded for longer creating more torque where needed, when your up on plane and cruising the vac will adjust with engine rpm up or down creating a more usable stable power band than the factory all or nothing set up. and finally at WOT high rpm you will get max advance to your setting not the factory so this means more HP. And my personal favourite, when you gig it out of the hole you accelerate faster because even though you are WOT from a stand still the dis stays retarded and rises only with the RPM because there is more venturi vacuum the faster the rpm is hence, NO BOGGING.(due to timing ofcorse). This allows the use of hotter cams and or bigger carbs with better performance and no bogg.
Point is that a vac advance HEI automotive dis not only CAN be used but is a better option in my opinion for the over all performance and longevity of the engine. If anyone has any questions regarding this thread or tech specific quarrels feel free to message me, but for anyone who has the barrel sight not to see this advantage and thinks that factory murcruiser is the only option, not only are you wrong, but your costing people reading these allot of needless money and just to be passed on the water by someone like myself who likes to be realistic and live outside the MERC BOX. Thanks guys for letting me on this forum and glad to help anyone who needs it.
Raise my brow, blip the gas, nothing but pipes, see ya...
Post Options Post Options   Thanks (0) Thanks(0)   Quote sprayin99 Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2012 at 2:58am
One more thing, for those people who are still barrel sighted and trying to figure out a way to disprove my reply think about this. Marine engines with a 4bbl carb use a vacuum secondary. This is because the secondaries are regulated by engine rpm (vacuum) and its needs up until max rpm WOT. If not then all the carbs would be mechanical secondary. So why is it so unbelievable that the distributor can benefit from this same principle? IT DOES!
Think of it this way, the thunderbolt ignition from the factory is like the mechanical secondary of distributors, while it does work it is less efficient. Let loose take the bogg out of your ride. Or just ignore me add a mechanical secondary double pumper what the hell, make her a real fire burping slug.
Waterdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2012 at 10:47am
Long ago I was told that distributors with vacuum advance are not USCG approved because it may provide an ignition source when the engine back fires. Maybe wrong but I haven’t seen a vacuum advance distributor that is USCG approved.
- waterdog -
78 Ski Tique
MartyMabe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MartyMabe Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2012 at 11:05am
This has been on the Skylark since Day 1 .
66 Skylark
93 SN
Nautiqueseventy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautiqueseventy Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2012 at 7:06pm
The guy is wrong in so many ways to list but no one said it would not work they said it is a a time bomb waiting to blow
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2012 at 10:40pm
John,
I agree and didn't even bother with a comment till now. It wasn't worth it this morning! You probably don't know him being new to the site but this is a case where I wish Chris was still around. He would have had plenty to say and backing it up with a knowledgeable background - not just a "boat rodder" opinion. Yes, I'm waiting for the big BANG!!
Welcome to CCfan. tell us more if you'd like. Boat??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2012 at 10:55pm
The 1st thing I thought last night when I saw it posted was just how many Correct Crafts use Mercruisers with Thunderbolt ignition? And just by changing your distributor your still not going to keep up with Joe anyway
Post Options Post Options   Thanks (0) Thanks(0)   Quote sprayin99 Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2012 at 2:48am
John,
Nice guys, I really would like to know all the ways I was wrong? I also have plenty of knowledge on the matter in fact everything I said was fact, look it up anywhere you wish. As for the coast guard, I am ignorant as to what they would approve just stating the differences between the two dist, there is not many. If you need fact to back my post up just say so and I will do the painstaking task of putting it all on here for you to read with citations from where the information can be found. Guys I was posting so that someone else who researched this would be able to do this to their boat (hell with the coast guard there are NO sparks period.) And I must say, you got me on the correct craft, as I do not own one, I was mearly goggling this topic to see what people were saying when it brought me to this post and I was so egar to stress my point I did not really look into which site I was signing up for. Anyhow the boat I originally described was an 86 dixie super skieer, on this test boat which was originally powered with a merc 5.7 carb, the original performance was about 55mph, after building up the engine, tweaking here and there and completing this modification, I am seeing 68-73 on the gps depending on the water itself. My point is it does work and very well and I am tired of people referring people away from trying it. As I said don't be barrel sighted. One more thing cause I know it's coming, I work on motors not grammar so please be patient with my spelling, and spell check sucks on this linux based pc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2012 at 3:25am
John,
Nice guys, I really would like to know all the ways I was wrong? (hell with the coast guard there are NO sparks period.).
Well, these guys know their stuff, that's for sure. Especially when it comes to safety.
You might disrespect the CG, but they are there to protect some people from themselves. I think they can give a citation for non-CG approved equipment on a boat. Some of them will check too.
We really want to prescribe legal installations on this site. No disrespect to your knowledge about HEI systems.
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2012 at 12:21pm
I understand your excited about this, but you did ask.
1) Secondaries are activated by venturi vacuum, not manifold vacuum. Its a matter of cfm and has less to do with your solution
2) final advance is final whether you have the vacuum advance or not, your WOT power has nothing to do with the vacuum advance (since there is none at wot) 351's and 350's like 36 btdc at wot no matter how they get it. its a function of CR, and rod/stroke ratio.
3)The correct term for where you are sampling vacuum is 'ported' vacuum.
4) You assume everyone else has a boat that bogs when we whick it open, you are mistaken.
5) If your carb has ported vacuum, then you are running an automotive carb and have , well, some 'splainin to do.<edit>
6) Best I can tell your setup is delivering a higher spike in advance off idle that dissapates with higher rpm and larger throttle openings then. I'm sure that produced some seat of the pants benifit somewhere off-idle to low midrange that you are excited about. Similar benifites can be gained by remapping the mech advance to suit the new conditions. I suspected these engines were missing some advance in that range and would respond well in a lightly loaded boat. however add a couple skiers in the water and things can become radically different.
7) the load on a boat is linear with speed, there is no high-vacuum cruise condition like in a car that required advance beyond the final mech.
8) Finally, if your mech advance is waiting till 3800 rpm to be all-in, that is root cause for poor performance, and the vacuum is compensating for a bad mech curve. Should be all in by 2800-3000rpm. Maybe your original system was just a pig.
Oh, and please stick around, we see this now and then, we all have thick skins, i'm sure we all have something to learn still. Introduce yourself
River Rat to Mole
hotboat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotboat Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2012 at 1:32pm
Little off topic here but I've always run a locked distributor for best performance without issue long as comp ratio is not too high (10 to 1) I assumed the retard was for starting purposes? Any other benefits?
Brian
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2012 at 1:56pm
Hotboat, explain more...before I presume what that means..
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotboat Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2012 at 2:01pm
No advance at all distributor locked in place
Brian
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2012 at 2:32pm
Thought so
well, they often have trouble starting hot above 12, and like 32-36 final (depending on CR)
What degrees BTDC ? I suspect you may have some performance to gain.
If you had tried running less final due to your high CR, i'm certain you wouldn't be happy with running equally low initial. the solution is to first reduce the span so you can do both. then tune in the two-stage curve.
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotboat Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2012 at 2:44pm
Anywhere from 34 to 40 btdc, If I remember right the boat I set at 34 initially, haven't got back to foolin with for 110 hrs run time. Should be broke in by now...
Brian
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2012 at 2:57pm
Brandon,
I'm confused here about you saying the stock marine distributor doesn't have an advance. What's this "magnetic pick-up" you mention? A conversion module from a point set?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2012 at 2:57pm
I don't necessarily disagree with the original post, but as it pertains to correctcrafts there are some issues..
Let’s get safety out of the way...
the biggest thing you need for a marine approved distributor is explosion proofing. In general manufacturers make these devices explosion proof by eliminating the vent in the cap, controlling all gaps (both in the distributor body and between the body and cap.. newer designs rarely use a gasket but have a tested interface that usually involves steps to eliminate line of sight openings) and then a controlled vent with a fine wire mesh is sometimes added to the body of the dist.. possibly in the location where the vacuum advance mechanism penetrates the body on the automotive version. Again this all varies; my assumption is that each of the designs is then tested by an independent body to a specific standard… I have designed and tested “explosion proof” electrical enclosures for mining industry use and am fairly familiar with the concepts and will say that I have attempted such a conversion once or twice for my own marine use… But I have also experienced first hand a bilge fume explosion and subsequent fire of my own as well as seeing the end results of many of them so I have a healthy respect for those possibilities.   I would recommend extreme caution be used, it ain’t rocket science- but you can turn your boat into a rocket if you don’t get the science right.
Not safety related but the gear on the dist has nothing to do with the marine application but instead with the cam material – which is usually determined by the cam type. If it was a stock engine and it came stock with an iron gear on the stock dist you are doing the right thing by replacing it with iron. Not all marine engines however will get along with an iron gear.
The reasons for a marine approved carb are not explosion proofing but rather to prevent gas from getting into the bilge to begin with…and they are not trivial features to fully duplicate. Gottaski points out there aren’t ported vacuum sources on marine carbs, I slightly disagree. I have seen some certified marine carbs that did not tool up a different base and simply put plugs over the ported vacuum ports, I have two marine Barry Grant carbs that are examples. The moral of the story is however that you should use a marine carb... and it is unlikely that a marine carb (and certainly not the case for the majority of the users of this forum) will have a ported vacuum source.
Assuming you can work it out so you don’t blow up you make some decent points for a light, planing, i/o boat with a mercruiser with thunderbolt ignition. They just aren’t relevant to 99.9% of Correctcrafts for a couple reasons.
First they generally aren’t mercruisers. The carb versions mostly come with mechanical advance distributors that can be adjusted and recurved to allow full advance at the appropriate rpm and are not limited by a preprogrammed curves.. exceptions are carbed protec boats. The fuel injected versions need to follow the factory map as it controls more than just the ignition timing. In general they are also pretty good, adding an unexplained vacuum advance to them would likely cause the knock sensors to retard your timing .
Second, even when not under the serious loads experienced pulling a skier these boats do not really get up on plane and run under light loads like an relatively small i/o with trim can do. The load is very linear, these boats can maintain speeds that a typical I/o cant that fall between the hull speed and the planing speed. Technically they do climb the bow wave and “plane” but not the way an I/O will. They just don’t have a bow up cruising mode like you would see on a planing I/o or even on a lightweight v drive or inboard that runs a high rake prop and no hook or a rocker the back hull. Therefore the situation where a vacuum advance could help take the level of loading at a certain rpm into account is simply not present. In general in an inboard correctcraft (even more so than the typical boat) rpm is a very good indicator of load on the engine, therefore a mechanical advance properly mapped is the best case scenario.
I hope you aren’t put off by the tone of any of the responses, when one leads by telling us if we don’t get outside the MERC BOX then we are going to be passed on the water… a little good natured kickback is likely to follow.. especially when you are on one of the few boating sites where Merc has no real relevance. Besides plenty of us think outside the box… I run a mechanical secondary carb, a relatively huge cam, and a single plane intake manifold and my boat takeoff compares favorably to that of a 1200cc two stroke jetski.. and there isn’t a merc part on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2012 at 2:58pm
Damn, any hot start issue or knock stomping off idle?
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2012 at 3:18pm
Marty,
I forgot to comment on your vac advance on the Super Saber. Universal was in it's final days before going under when they came out with the V6. They did as little as possible to the purchased engine which involved exhaust manifolds, a RWP and paint. (even keeping it a standard LH rotation) It was a "quick and dirty" attempt to get some cash going again. They found that the V6 did work well with the vac advance and suspect it was do to the unusual torque curve. The added expence of changing the distributor wasn't needed. Through the years of Buick, Jeep and even OMC that V6 had many changes. The biggest was probably changing the firing order to try and smooth it out. That V6 is the only marine engine I know of that came from the factory with the vac advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2012 at 3:47pm
Agreed, locked out is no way to live, stunted perhaps but locked out I dont see.
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: June-01-2012 at 7:19pm
are those real numbers?
if so pretty impressive for a 5.7 sbc...that dixie is probably a fast hull...
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-01-2012 at 7:23pm
I believe the Dixie was available as an I/O. Those numbers sound grossly inflated for an inboard.
86 Nautique 351 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 86 Nautique 351 Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2017 at 3:10am
I'm still learning a lot about this great boat, this forum is very helpful, thanks guys.
My 1986 2001 with 351 is bogging and not revving up. I just had the carb professionally rebuilt. Now diagnosis points to a timing issue. Saw this thread and noticed I have a vacuum port on my distributor that is hooked up to nothing.   Does this mean I have an automotive distributor? I am having trouble posting photos with my iPad or I would post a photo.
Is this a good stock replacemert distributor in the link below?
http://www.nautiqueparts.com/product/distributor-breakerless-mallory-left-hand-rotation-351-ford/
Any distributor recommendations? Thanks very much for everyone's advice and different points of view.
TD
Post Options Post Options   Thanks (1) Thanks(1)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2017 at 8:39am
It does mean you have an automotive distributor if it has a vacuum advance mechanism.
You can read the link below, it has some info on who makes a 351w reverse rotation marine distributor
If your 86 is original the engine is reverse rotation so you would want a distributor with a reverse rotation gear unlike the one you posted a link to.
The same outfit will sell you one with the right gear for your application
Post Options Post Options   Thanks (1) Thanks(1)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2017 at 8:46am
If you pull your distributor out of the engine and look at the gear it will look like this for a
Reverse rotation engine \\\\\\
Normal rotation engine ////////
