  New Posts New Posts RSS Feed - Poor Man's GT40 Diagnosis
 Post Reply Post Reply Page    <1234 8>
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2012 at 11:21am
Cool, thanks
I gave that its own column; full ignition tuneup. Goes to show that it helps to check the simple stuff first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2012 at 12:45pm
Hot loping (rolling idle) problem fixed with Idle Speed Control Valve:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=24848&title=gt40-engine-loping
Part found on Rock Auto:
IACV PN: e9se9f715eb (off the original valve)
http://www.rockauto.com/catalog/moreinfo.php?pk=945342
$55.79 + shipping
Updated Spreadsheet
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: June-30-2012 at 2:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: July-04-2012 at 3:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: July-09-2012 at 12:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: July-09-2012 at 1:17pm
Bohinny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bohinny Quote  Post ReplyReply Direct Link To This Post Posted: July-09-2012 at 2:54pm
IACV PN TV-206 at autozone $55 and close to the lake if needed. I like having theses PNs so I can possibly save a wekend. Thanks for the spreadsheet
Billy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: July-09-2012 at 3:50pm
You're welcome. Hope it helped.
I updated the IACV line with the Autozone PN, the Napa one is there too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2012 at 2:00am
Low pressure fuel pump not activating. Fix is to replace
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=26811&PID=344711#344711
Will update spreadsheet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: August-07-2012 at 12:51am
Clogged Fuel Pickup tube causing reduced top speed, surging and poor performance:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=27274&title=gt40-issues
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: August-07-2012 at 12:53am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: August-09-2012 at 12:59pm
Old Post with a cracked tube in the FCC leading to very poor performance, backfiring etc:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=21983&title=pcm-gt40-backfires
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2012 at 1:46pm
Another failing Low Pressure Pump causing breaker to pop repeatedly:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=27336&PID=350861#350861
Updated Spreadsheet
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2012 at 1:33pm
Another tiny crack in the fuel line inside the FCC. This one caused very sudden, total loss of performance. Inability to idle and rev up:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=27375&PID=351303#351303
Updated Spreadsheet
panda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote panda Quote  Post ReplyReply Direct Link To This Post Posted: August-23-2012 at 3:43am
Where did you pick up your cap and rotor for that price?
Originally posted by charlesml3 charlesml3 wrote:
Specifics:
1999 GT-40 EFI. 671 hours. Well maintained since new but never tuned up.
Symptom:
Lumpy idle. Clear raw fuel smell at the exhaust when idling. Obvious miss/skip from idle speed up to around 2100RPM. Occasional miss at cruise speeds if you listen carefully.
Solution:
Replace distributor cap and rotor. The original cap and rotor were clearly worn and pitted. The boat ran great after this. $44.
Also:
New plug wires, new spark plugs, new fuel filter and raw water impeller. Might as well do it all. The boat hasn't run this smooth in years. Total cost was $200 and it took about an hour to replace everything.
95 Ski Nautique GT40
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2012 at 10:53am
minasianj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote minasianj Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2012 at 3:19pm
Symptom: No start and inoperative low pressure fuel pump.
Solution: Replaced fuel pump relay. $13
Keith View Drop Down
Admin Group
Admin Group
Owner / Operator of CorrectCraftFan.com
Post Options Post Options   Thanks (1) Thanks(1)   Quote Keith Quote  Post ReplyReply Direct Link To This Post Posted: September-03-2012 at 1:05am
1997 GT40 with approx 700 hrs.
Symptoms: An otherwise perfectly running engine suddenly dies and won't restart. Turns over but won't catch. An hour or more later, starts and runs fine. Later dies and won't start again.
Solution: Bad Ignition Module or TFI(Thick Film Ignition).
Replace TFI by removing it from the heatsink. These TFIs come in four flavors - distributor mount and remote mount, in grey and black. Make sure you get the remote mount, grey one - referred to as "Remote Mount Gray TFI-IV 'Push Start' ICM".
Part Numbers:
Motorcraft - DY1075 (supercedes DY533)
Ford - 5U2Z12A297B (supercedes E8DZ-12A297-A)
Wells - F125
Niehoff - FF411
BWD - CBE33
Standard - LX226
Napa (Echlin) - TP33 (~$73)
Delphi - DS10053
Transpo - FM533
Image of TFI mounted to heatsink
Image of replacement TFI
Edit:
You'll need a deep socket 7/32 to remove/install the TFI from the heatsink.
The replacement TFI also will come with with a silicone that is applied to the metal back of the TFI, where it comes in contact with the heatsink.
The TFI is the grey plug facing the front of the boat, located under the black cowling, next to the coil near the throttle body.
See Lewy's photo:
Former:
97 Sport Nautique
1994 Ski Nautique
86 Silver Nautique
79 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: September-04-2012 at 12:28pm
Thanks guys. Good write up Keith.
Updated Spreadsheet
lewy2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: September-23-2012 at 2:13pm
Keith was the module you replaced grey or black?
I was working on my boat today getting it ready for the summer and while inspecting my TFI module (was going to re-apply heatsink compound) found that it was a black module. This had me initially thinking somewhere along the line it must have been replaced with a incorrect module. The main difference between the black and grey modules is that the grey module sets the dwell while with the black module the computer controls the dwell.
The GT40 manual in the reference section (3F-13 page 222) species the use of a black CCD (computer controlled dwell) TFI module. This led to some research and I found what I think is the correct answer. I will confirm this in the next few days at my Ford parts dealership but it already looks conclusive from this article.
TFI Modules Grey or Black
from this article:-
"Since these two TFI systems are so significantly different, yet so similar in appearance, parts application problems will inevitably occur. A gray Push Start TFI module will plug right into a CCD system, and vice versa. To make matters worse, parts books are often incorrect on TFI module applications! With the incorrect TFI module installed, the vehicle will run, but driveability and MIL (malfunction indicator lamp) problems will result. For instance, if a gray Push Start TFI module is installed in a CCD system, the computer will not be able to control ignition dwell, and the MIL will illuminate with memory codes for the IDM circuit set, as the gray TFI module is incapable of generating an IDM signal to the computer. If a black CCD TFI module is installed in a Push Start system, dwell will remain fixed, since the SPOUT signal duty cycle never changes. If in doubt about which TFI module belongs on a particular vehicle, consult the ignition system wiring diagram for the vehicle. If the wire going to pin #4 on the EEC-IV computer comes directly from pin #4 of the TFI module, it is a CCD system. If not, it is a Push Start system."
These should be the correct part numbers for the GT40 TFI
Remote Mount Black CCD "Computer Controlled Dwell" ICM
Motorcraft - DY1077 (supercedes DY679, DY667, DY645)
Ford - 5U2Z-12A297-D (supercedes F1PZ-12A297-A)
Wells - F139
Niehoff - FF413
BWD - CBE40
Standard - LX-241
NapaEchlin - TP29
Delphi - DS10056
Transpo - FM544
Keith maybe your TFI had been swapped out earlier with incorrect "grey" module. It would be easily done as stated in the article as they look identical apart from colour and will still function just not as efficiently.
89 Ski
Admin Group
Admin Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keith Quote  Post ReplyReply Direct Link To This Post Posted: October-01-2012 at 2:50pm
Lewy,
I had the same dilemma when trying to fix my boat during Labor Day weekend (grey or black TFI). I need to contact PCM and get a definitive answer. I can tell you my TFI plug is grey, not black. That, and the fact the bad TFI I was replacing was grey, caused me to go with grey.
The research I did on Fords of that error made me belive they used grey TFI's which were attached to the distributor first, then Ford went to remoted mounted grey TFI's and then remote mounted black TFI's.
I wonder if early GT-40's would be differnet than later GT-40's. Marine was so far behind auto it's always hard to tell when parts changed.
I'll try to get the final answer and post here.
Thanks,
Keith
Former:
97 Sport Nautique
1994 Ski Nautique
86 Silver Nautique
79 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: October-02-2012 at 10:09pm
Keith it would be nice to get a answer back from PCM. But do not hold your breath still waiting for their answer on the modification to EEC fuse wiring on the GT40 engines.
The manual in the reference section is for the early GT40 without the FCC.
It does specify the use of a black CCD TFI unit. (3F-13 page 222)
Also the article from Ford Engineer David Sill has a method of determining which type of TFI is required.-
"If in doubt about which TFI module belongs on a particular vehicle, consult the ignition system wiring diagram for the vehicle. If the wire going to pin #4 on the EEC-IV computer comes directly from pin #4 of the TFI module, it is a CCD system. If not, it is a Push Start system."
The tan/yellow wire from pin 4 of the computer does go to pin 4 on the TFI connector on the GT40 engine.
So what started out as simple check ended up being a full on investigation. I was unable to source the correct TFI unit at any of my OEM auto part suppliers or local Ford dealer parts department. The only TFI module that ever made it to the Australian 5 litre V8 Windsor engine was the distributor mount "push start" grey module.
I decided to order one from the US just in case mine played up in the middle of summer at a very inconvenient time. Found it unusual that Skidim did not stock them. If they are a high failure part I would have thought they would carry them. Maybe they don't actually fail that much in the marine application.
Sourced it through Amazon who have good shipping rates to Australia.Black CCD TFI
Found this one which should be compatible but played safe with the genuine Motorcraft part. It maybe worth ordering one as a spare for US based owners at $29 though. Cheap Spare TFI
89 Ski
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2012 at 9:31pm
Brian did not intend to mess this thread up. Not sure if Keith can remove this TFI stuff and start a new thread just on the TFI.
Anyway the new ignition module arrived yesterday from Amazon. It should be the latest revision of the "CCD remote mount"
89 Ski
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2012 at 11:14am
No problem. Just put in the final word on what is the correct TFI is to use, or if depends on the year?
Admin Group
Admin Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keith Quote  Post ReplyReply Direct Link To This Post Posted: January-15-2013 at 2:13pm
Lewy,
I was just able to confirm with PCM that the black TFI is the correct one. "The TFI module we use is black with a Ford part number F15F 12A297 C1A. This one is the only one that I know of that will work properly with our calibration."
I will update my TFI write up above once I find the other part numbers.
Looks like I will need to buy myself another TFI module before Spring.
- Keith
Former:
97 Sport Nautique
1994 Ski Nautique
86 Silver Nautique
79 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: January-16-2013 at 1:41am
Keith glad to see you finally received a reply from PCM. I have never managed to get a reply from them. You must have a inside man.
The number for the TFI module they gave you is the old number that was available when PCM were building the Ford GT40. It has been superceded by Ford since then.
The F15F 12A297 C1A was previously superceded by F1PZ-12A297-A
If you try an order a F15F 12A297 C1A the Ford parts man will tell you they no longer exist replaced by the new number.
These are the correct part numbers for the GT40 TFI
Wells - F139
Niehoff - FF413
BWD - CBE40
Standard - LX-241
NapaEchlin - TP29
Delphi - DS10056
Transpo - FM544
89 Ski
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: January-16-2013 at 1:57pm
It looks like Nautiqueparts is carrying this black TFI for the low, low price of $180
http://www.nautiqueparts.com/tfimodule.aspx
Maybe we can see if Zach will/can/does stock it and can give a better price.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: January-16-2013 at 2:02pm
^^Or course, it looks like they are including the heat sink... which is probably a pricey chunk of metal.
E4ODnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote E4ODnut Quote  Post ReplyReply Direct Link To This Post Posted: January-16-2013 at 3:52pm
I had a look in my Ford '92 Car/truck service manual and it looks like there may be some wrecking yard options available. The following are listed as using TFI CCD (black):
Passenger car engines
2.3L HSC/2.5L/3.0L Taurus/Sable
3.0L Probe/Tempo/Topaz
3.8L Thunderbird
5.0L HO Thunderbird/Cougar
Truck engines
3.0L Ranger
7.0L
Hope this helps.
Robert
1993 Bayliner 3288 "Hocus Pocus"
351 Fords, converted to tuned port programmable EFI
Admin Group
Admin Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keith Quote  Post ReplyReply Direct Link To This Post Posted: January-16-2013 at 5:38pm
Do a Google search on the part numbers Lewy provided. You find some decent prices - especially for the Wells F139.
- Keith
Former:
97 Sport Nautique
1994 Ski Nautique
86 Silver Nautique
79 Mustang
