77 Ski Tique Floor |
Mille1sj
Senior Member Joined: October-01-2007 Location: United States Status: Offline Points: 278 |
Posted: July-18-2012 at 5:32pm |
Hello All,
We noticed this year that the floor in our 77 Ski Tique is starting to get a little soft in a few areas. I wanted to see if anyone had any information to offer, pros or cons of replacing the floor yourself. I am very handy when it comes to carpentry and have a decent amount of experience with fiberglass. My one concern would be replacing stringers if it is needed. Any thoughts, pictures, pains or general comment would be greatly appreciated. Steve |
If the floors are soft, then youve got wet foam and rotten stringers too. A slightly mushy floor is the tell tale sign, and is just the tip of the iceburg!
Search this site for stringer rebuild threads. Tons of good info. |
I concur with Tim. You need stringers.
Mille1sj
I searched the site and found a lot of great information and very detailed plans, do you have an estimate for the cost? I need to plan for a budget...plus about 30% like every project, but I just wanted to get a feel for the overall cost.
Mille1sj
I wont be starting this project until the fall, however, I have found in many of the posts, that the correct lumber can be difficult to find. From what I have been reading, Douglas Fit is the wood of choice for the primary stringers, what should I use for the secondary on a 77 Tique?
I would like to start the research now so I can have all of my materials lined up when its time to start. Does anyone have a suggestion for foam? |
How about none? I think you would use Douglas fir thu out the boat. |
Doug Fir can be hard to locate depending on the part of the country you are in but not impossible. We do have one member who is in the final stages of doing a stringer job with LVL. It turned out fantastic. The Doug Fir is idea for both primary and secondary but not absolutely needed for the secondaries. Common pine is fine since I suggest CPES and epoxy that will seal up the wood.
Yes on going no foam! |
