  New Posts New Posts RSS Feed - Carb Issues
Carb Issues
MY70/81 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MY70/81 Quote  Post ReplyReply Direct Link To This Post Topic: Carb Issues
    Posted: August-21-2006 at 8:58am
I am looking for some advice on my 81 SN. I have spent my summer sorting out several problems left to me by the PO, and I believe I am pretty close to having it right. I have a nagging problem with the idle on my 351, so far this is what I have done, set Timing to 6 degrees BTC, adjusted Points, Plugs, Rebuilt Carb and set everything to rebuild specs, I also previously replaced one Piston, and the Lt side Head. I am having a lot of problems getting it to idle until completely warmed up, and it has a slight stumble pulling from a stop. I have read some posts that say the Timing should be 8-10 degrees? I am kind of new to the 351, because my 70 SN has the 318 in it.
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2006 at 9:09am
Yes, 8-10 is best. Also set your air screws when idling in gear. Off-idle will improve.
Make certain there is noi slop in the accel pump linkage, too.
You make have a vacuum leak too.
River Rat to Mole
