351w cam upgrade? |
Post Reply | Page <12 |
The 60hp increase comment was in reference to the base (240-255hp) 351w, not the HO (285-310hp). I would expect a 15-20hp upgrade over the 310hp GT40 with a better cam and P heads. The p heads are a *little* better than the regular GT40's that came on the GT40, but not a lot- so you wont see the same bang for your buck by upgrading. That being said, it wont cost much more to go with new/refurb'd P's on the rebuild than it would be to have your GT40's rebuilt... and the P's dont seem to be as prone to external water jacket cracks as the regular GT40's are. So, while you wont see the big gain in hp by switching, you'll see something with the slightly better flow and smaller combustion chambers. Plus, if your GT40 heads are still in good shape, you can make some of your $$ back by reselling to a Mustang guy, as theyre more sought after for automotive applications. |
TX Wind
Senior Member Joined: March-29-2011 Location: near Dallas Status: Offline Points: 333 |
I concur Tim. He may even get all of his money back as the 40's go for a bit more money than the P's. A little more lift in the cam will give a few more ponies. Maybe 15 and 20 if you're lucky. If you really want to get more than that you could have the heads ported. That will open the flow up a bit. But honestly, 330 hp in the older boats is a heck of a punch. Maybe you could under drive the tranny. The 1.52:1 Velvet drives are awesome and IMHO offer a significant advantage in hole shot over the PCM 1.23:1. We have boats with all 3 trannies and the 1.52:1 is amazing.
IF....you were going to try to do that, research a bit. The typical prop size on the 1.52:1 is 14x18 and I don't know if that will fit your boat or not. It also requires a 1 1/8" shaft and strut. For slalom and wake board, I'd stay 310hp and look at the tranny. OK Tim....blast me apart now. |
TX Wind
I might add to that, the 351w properly maintained is designed to withstand a TON of working hours. I would not be surprised to see many of the boats on here with a thousand plus and still pumping strong.
I disagree that the 1.52 is worth considering. There's a reason why mc has gravitated closer to the PCM reduction ratio (1.26) in their mainstream motor(s). I think it's been found to be pretty optimal for all around ski boat use. Besides, the bw can't reverse the direction of engine rotation, so you're talking a lh prop with that set up, and all the handling abnormalities that come with it. Would need to change prop, strut, shaft log, shaft, and most likely rear engine mounts- in addition to the tranny itself. It's also commonly accepted that the slot boats are slower up top, which is not the case with the 1.23's (as compared to the 1:1's).
TX Wind
Mark, Tim is right about the handling issues. If you have a 1.23:1 tranny, you're stuck with it unless you reverse the rotation of your engine when you change trannies. In other words, it would become expensive and involved and adding h.p. is a much cheaper route.
There's a reason Tim is a Grand Poobah here. He knows a ton about boats. However...for a slalom and wake board boat, especially a larger heavier one like yours, I will say this at the expense of having my head handed to me. There is a reason that a less than 15 yr old Mastercraft boat company snatched top sales honors from Correct Craft and it was called the Powerslot(the 1.52:1 tranny). With the advent of wake boarding and so many boats going to v-drives, the direct drive had to become more versatile. A very small percentage of boats are direct drive now. Because the new engines made so much power, it made more sense to go to the 1.23 ratios. Like Tim says, they are better all around. However, if you wanted a slalom/ wake board boat and could custom design the setup, the 1.52:1 is my choice 6 days a week and twice on Sunday. The difference in hole shot is overwhelming. That's just my personal experience without discounting anything Tim has said. If you have a 1.23:1 setup, that's an expensive transition in order to keep the prop rotation right. However Tim, in these newer, longer, heavier, and wider platforms I would think that is less of an issue than it is in the older smaller boats. I could be wrong. If you do have a 1.23:1 already, I would spend my money on H.P. For the difference in what the conversion costs, you could do some awesome power upgrades. The truth is, unless you do some aftermarket head work, I doubt you will get the 351 to do much better than 330 h.p. and still have normal functionality and that's about where the new rockers and 40P heads will take you. Porting the heads might get you a little more. Question Tim. Was the 351w with the 1.23 still a RR engine because a LR engine opens some new doors honestly. I could swear my brother's Nautique with the 1.23 is LR. If it's LR, go roller, then think about the 40P vs. 40 heads. The roller cam allows the lifter to stay at the max. lift for longer and also allows for much higher lifts than the flat tappet cams. |
phatsat67
Grand Poobah Joined: March-13-2006 Location: Indiana Status: Offline Points: 6151 |
Anything to my knowledge with a right hand prop and a direct drive 1.23 was a standard rotation engine TX.
TX Wind
What tranny do you have Mark? If you have a LH engine, you have more choices than the RR guys do.
ultrarunner
Platinum Member Joined: October-02-2005 Location: Ridgefield, Ct. Status: Offline Points: 1831 |
Hi Jeff, thanks for the recap. I do have the PCM 1:23 with the GT-40. So it sounds like cam, rockers, and P-heads...maybe even flow 'em. Then prop accordingly.....
MS |
TX Wind
Sorry Mark. I was so caught up in the RR talk that it didn't occur to me immediately you might have a LR engine.
So cool...I'd go roller cam then personally. Maybe the GT-40P heads and some porting. I wouldn't be surprised to see you climbing above the 1hp per cube mark that way but you need to make your head decisions before anyone can advise you on best cam. What would you say Tim? |
The GT-40 with a 1.23:1 is a lefty with a right hand prop.
When I rebuilt my GT-40 I went with the P's and a CR cam (dont have the cam #'s in front of me now)I stayed with the stock rockers because I didn't want to mess with different valve covers. It did up my top end a little, it will run around the 50 mark maybe a touch north of 50 but I never got a GPS speed on the stock 1442. I did play with a 1442 that I had Delta take some cup out of and as the hole shot may have increased some the top speed dropped to 47/48 mph as the RPM increased to the 5400/5500 mark. With the stock 1442 the hole shot is still more than you would ever need and gives a better top end. |
81nautique
A little late to the party but if you are going to go with a set of P heads and spend money to have them ported it would be prudent to look into some aftermarket heads that will perform better out of the box than just about anything you can do to a set of P heads. If you're porting the P's yourself then go for it but I wouldn't spend money on them to have someone else do it, there are better options out there.
You can find aftermarkets starting around $1000/set fully assembled and they will blow the P's away. Check out RHS and of course AFR are very popular but do some homework on whats out there. P's are a great drop in for a stock 240 hp base motor but the gains per dollar might be greater with something else. Ancient history for me now but my 81 was up around 380 hp with a set of cast iron RHS heads ported and gasket matched to the intake and exhaust and that was running a fairly mild .460 cam. I also don't like the geometry of the 1.7 rockers so I would try to spec the cam properly from the start and stay with 1.6 ratio rockers. Assuming you go with aftermarket heads you will need stud rockers and my 1.7 rockers bound on the studs and needed some machining to get them working properly. I just think there's some more planning needed before you jump the gun and start buying parts. Any head swap costs a lot more than you think once you get into gaskets, etc so do it once and do it right. |
phatsat67
RHS kicks but at all 3 of the big 3 heads and they are cheap!
81nautique
Plus, you will never get the ports on the top set of heads from the heads in the bottom of the photo. And don't forget about the larger valves aftermarkets will have I just think it's time to stop and do some more homework before spending any money. |
phatsat67
.....and the smaller combustion chambers with better quench area!
Those sure are pretty. Those heads solve the problem of small Ford exhaust ports ;) Whats the valve size 2.02? 1.88? I'm considering a ported set of those on my 360 this winter |
Again, the 1.52 is not worth considering... LOTS of expense with all new running gear, and you'll end up with a LH prop unless you revert back to a reverse rotation engine (a whole different can of worms and $$$). For what might amount to a VERY slight holeshot advantage and a reduction in top speed. Ive held my own against 330+hp 'slot boats with my 1.23 out of the hole, and then walked away. The PCM trans is a great all around box with the reduction, and also allows a LH engine to turn a RH prop. Win/win/win, dont try and reinvent the wheel here.
I agree with Alan... if wanting to freshen things up and get a little more hp (~325ish) then bolt on some P's and throw in a flat tappet Cam Research stick. Paul's '95 siggy runs real strong, as he said. If wanting to push it beyond that point, aftermarket cylinder heads and a roller cam are worth considering... in the end those 2 upgrades will probably set you back an additional $1000-1500 over the p-head combo, and allow you to push the 375-400hp mark, if done right. Whether the stock GT40 fuel and ignition system will allow you to take advantage of the better parts or not remains to be seen... if youre going to be upgrading injectors and remapping A/F curves, the project becomes a bit more involved (and expensive). It all depends how fast you want to go and how much you want to spend. Like Joe said, "Whats money, but paper waiting to be turned into horsepower?" |
81nautique
2.02/1.60, Stock pistons (on a SBF)should have plenty of relief for them but clearance must be checked when changing cams. |
phatsat67
You can go as fast as your wallet.
As Tim said about the GT-40 I don't think you can do too much untill someone comes up with a tuner for the computer.
Youre probably right, but its still TBD how far you can push it based on the stock GT40 ignition, fuel system and ECM. Theres at least one stroker GT40 in existence, no idea how extreme it is or what modifications (if any) were made to make it run reliably (or not). Personally, Im waiting on Joe to be the pioneer... he's got that '95 GT40 dissected and all the parts identified- just waiting for some love. I plan to follow suit with an EFI Ford stroker, right after he figures out all the hard stuff. |
ultrarunner
Well, plenty of Mustang tuners out there that may be able to provide some input, and there are tools out there to let us re-map the existing chip, but not sure how effective that would be on just the stock motor, being normally aspirated.
I re-chiped my Audi a bunch of years ago, but in that case, I started with a twin-turbo V6 and could take advantage of what that motor turns out in other applications.... But with all that said, I'm thinking it would be fairly easy to remap our existing chip to account for another 50 hp's or so. That or I'll just get a Python and be done with it |
I dont think its possible to reprogram the existing ECM- PCM has it locked down. It could, of course, be replaced with something tunable... but you'll be starting from scratch on the A/F curves. I would guess it to be a slightly more complicated than a "fairly easy" task, as surely there are significant differences between automotive and marine applications (otherwise PCM would be slapping a generic tune on their motors rather than putting the R&D into their own). But then again, Im no software guy!
A healthy 351w (north of 1hp/ci), or better yet, a stroker 351 (393/408/etc) thats built properly should outperform the Python powered boats without much of a problem... and not have the 300 lb weight penalty associated with the big block. Those Python boats only ran 50-51mph. |
ultrarunner
I'd agree, you could make a much better motor out of the 351 than a Python...
TX Wind
Just to clarify Tim. I thought we were initially talking about a RR engine with some limitations because of the cam sizing available. That is why the suggestion of the 1.52:1 for hole shot. However, with a LH engine, that's another story. Lots of better options to choose from.
I was unaware AFM heads could be had that cheap. The ones I've seen have been twice that much. As far as the ECM's go, there are definitely tunable marine ECM's out there. They start around a thousand bucks or so. Programmable ECM's |
