  New Posts New Posts RSS Feed - Teak/shaft alignment..
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Topic: Teak/shaft alignment..
    Posted: November-19-2012 at 7:59pm
Best way to improve teak swimm.P.appearance? Products? Prep?
Should shaft alignment be checked, every 2 years? Or ?
Ty--- Linda!
GlassSeeker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: November-19-2012 at 8:59pm
do a search here on swim platforms, there is plenty info.
the shaft, if it ain't broke don't fix it. Do you feel you have excessive vibration? eliminated the prop as a cause yet? then check the shaft...
This is the life
Dreaming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: November-19-2012 at 9:07pm
This is a link for some commonly asked questions on the forum.   I am pretty sure that teak maintenance is on here, as is the alignment video.   By Are you typing on your mobile phone?    I am able to guess what this post was all about, but some of your other posts have been much less understandable.... Any chance you could type out what you are asking?   I am not from the texting generation, so spelling it all out really helps me to deterimine the real questions you are asking.
link repaired
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: November-19-2012 at 9:27pm
Here is a better link to teak maintenance...   TRBenj - the link in your post takes me to a post by East TX on MCTT, but it doesn't appear that there is a teak post affiliated.   for research sake, it wouldl be great if you could repost?   I'll be doing my platform this winter as well.
Swim Platform Maintenance
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2012 at 10:41am
Shaft alignemnt should be checked once per year, in my opinion. Good thing to do at the start of the season. It is cheap insurance.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2012 at 11:14am
ty- guys- not getting vibration .it would show up going straight right? Or would it be more pronounced during a turn?
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2012 at 11:40am
testing to se if pic came up---lol
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2012 at 11:41am
Finally---------------it worked....lol way too large though==Break through today---lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2012 at 12:04pm
Misalignment will not cause vibration... it will actually dampen it slightly due to the greater side load of the shaft in the strut. The manual calls for you to check it every year... but thats probably excessive if you have no reason to suspect it has changed. If the prop still spins smoothly by hand (pinky finger light) then I wouldnt sweat it. Of course, if the boat is new to you, then its a smart idea to align it, regardless of when the previous owner claimed it was last done.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2012 at 12:40pm
ty----Trbenj--Will try the pinky spin.. thanks again for all the help
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2012 at 4:20pm
trying for 2 for 2 with pic posting...
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2012 at 4:23pm
today has to be my lucky day-- i have been trying to post pics,for so long...Now to fig out how to post a avatar,,, id number?HUH
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2012 at 8:28pm
Tim is absolutely correct. I have mentioned it several times.
Silver15 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Silver15 Quote  Post ReplyReply Direct Link To This Post Posted: November-21-2012 at 12:09am
Just my $0.02, Having snapped a driveshaft at high speed before, I would definitely advocate that you at least inspect it and see how difficult it is to spin the prop as said above. Having a shaft break loose is a scary experience and can damage your hull, prop, rudder, etc. It would be worth the effort to get it aligned and save yourself the potential problems later. I learned the hard way.
2000 Air/Sport
1978 T16
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: November-21-2012 at 12:21pm
ok thanks again everyone,, will do! Silly question! When turning I her what sounds like a whistle or rope being wound up real fast-- Is this coming from the FINS? ty--
bhectus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bhectus Quote  Post ReplyReply Direct Link To This Post Posted: November-22-2012 at 4:38pm
That's normal. Every 2001 hull I've been in, including my old '83 used to make that sound when turning. They usually only do it one way though, I can't remember which. My BFN doesn't seem to do it but that is a totally different hull bottom.
'87 Barefoot - sold
'97 Super Sport Nautique - originally custom built for Walt Meloon
'97 Ski Nautique
'83 SN 2001
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: November-22-2012 at 4:44pm
Hey Thanks, crazy sound for sure.. Glad to know, that all is more than likely ok..ty
