ACME 540 ??? |
Page <1 234 |
That's funny, the one and only time I thought I might die in a ski boat had Tim also at the helm. Hmpf.
Oh c'mon, we werent even doing 30! ![]() |
81nautique ![]() Grand Poobah ![]() ![]() Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5777 |
I never once had a bow dive (or chine lock or whatever you call it) in the 81 with either Amce prop (540 or 430)but those are both different animals than the 208. I had it happen a couple of times both with an OJ 13x13 at just above 50mph and that is a scary feeling. The OJ always pushed the nose down so it skied pretty good but the faster it went the less I trusted the boat in anything but glass water. Seems both Acmes were trying to lift the bow (or sink the stern), either way there was night and day between the styles of prop.
Will be interesting to see what that motor will do in the MQ although I expect it to be propped for pulling a bunch of footers most of the time. Hopefully it gets run this summer or you should make sure it's been fogged. |
Alan, my suspicion is that the 208 is a lower rake prop and will act more like the OJ's. The 1868 never caused our v-hull to chine lock but it nose dived hard enough to rob 5+ mph off the top (I could continue to power through it)... so Im thinking the same type of thing is at play.
Agreed that it will be interesting to see how a v-hull compares to the 2nd gen SN speed wise- this will be a perfect comparison! My guess is that it will be pretty fast... a reliable 55mph for sure, maybe a touch more? I would say our BFN came to us with about the same amount of hp (~380hp) and it ran right there. |
Page <1 234 |
