  New Posts New Posts RSS Feed - Water pump
Water pump
cphase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cphase Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2013 at 12:17am
Yea...after seeing your pump that is not the right one. I am not sure which one is correct. Who marinized the engine?
Thanks,
Jeff
82 SN
Arch Linux
73SN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73SN Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2013 at 12:27am
its a Jabsco PN:920-0103 2" - width with a spline drive. still searching
Post Options Post Options   Thanks (0) Thanks(0)   Quote cphase Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2013 at 12:31am
Paul look at the top of this page.
Thanks,
Jeff
82 SN
Arch Linux
73SN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73SN Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2013 at 12:32am
Sorry, marinized? googled it and dictionary.com'd it whats that mean?
Another one for the books.
its a 351 ford marine engine.
I'm guessing the RWP is what came from correct craft 40 years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cphase Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2013 at 12:38am
Do you know who built the engine? Pleasure Craft Marine(PCM), Commander?
Thanks,
Jeff
82 SN
Arch Linux
73SN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73SN Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2013 at 12:43am
anyway I can search, I've looked and just wanted to know if this was unavailable before I wasted much more time. I read where some folks had to go with other options due to unavailability of type.
THANKS
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2013 at 1:01am
Paul,   In order to find an impeller for that pump, you have to ask for a Volvo impeller.   They, (Volvo) still use the splined pump shaft.
It's the gaskets that have become next to impossible to find.   I make my own.
The alternative would be a new brass pump, which is very expensive and the pump mount base has to be altered so that you can use your same pulley.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2013 at 1:38am
Since its red I'm guessing its s Palmer?
73SN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73SN Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2013 at 1:40am
Go2marine has a couple: 5/8 is Drive type 7... 2" depth, .....we'll see
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2013 at 1:41am
All you need to do is use the search engine of your choice and type in Jabsco 920-0103 I found a bunch-
Link-1
Link-2
Link-3
Make sure you buy an oem Jabsco impeller too,problems occur when you other brands
73SN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73SN Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2013 at 1:58am
wow, plenty to choose from when you know what you're looking for...
THANKS again
73SN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73SN Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2013 at 2:48am
yea, the red is from some yea-hoo with a rattle can... bolts, harnesses, hoses, tranny, everything. what a mess!
I'll have it all clean in the end.
@ DrCC: I'm getting pretty good at the gaskets. seems to be better when not rushed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2013 at 8:17am
I'm still curious as to who's marinization it is.
BTW, it would be common to find almost everything painted from the marinizer. Don't assume it was a PO with a aerosol can of paint. It was common practice for them to bolt on all the marine parts and spray everything. Typically the only exception would be the carb, distributor, plugs and wires.
73SN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73SN Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2013 at 2:45pm
hmmmm, painted that way by a pro? That would've never occured to me. you can see the original Ford blue in spots they missed.
How could you tell who marinized it?
I just figured it came marinized from the CC boat building place.
It said Mfg. by THERMO ELECTRON ENGINE CORP Detriot, Mich on the Correct Craft sticker on the valve cover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2013 at 2:57pm
Correct Craft has never marinized their own engines. At least not on the 60's and newer boats (someone else more knowledgable can speak to the older ones). They now get their engines from Pleasurecraft Marine (PCM). They used to get engines from Commander, Chrysler, Interceptor, OMC, etc. Conquerer/Crusaders and Palmers were closely related in the early 70's, as they were owned by Thermo Electron at the time (Dr CC will correct me if I goof that up again).
Marinization companies usually design and install their own cooling, ignition and exhaust systems, as well as the brackets used to mount accessories. They generally include the transmission as part of the powertrain package as well. Most of these items (thermostat housings, brackets, exhaust manifolds) were unique between the different companies. It sounds like you have a Palmer, but a picture would confirm.
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2013 at 4:25pm
Sounds like he has a Thermo-Electron.
There were two separate companies using the same name "Crusader".
1. The International Harvester/Palmer Marine/Thremo-Electron/Crusader.
2. The Cal Connell Cadillac Marine/Conqueror-Crusader.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2013 at 5:02pm
There were Thermo-Electron Conqueror Crusaders, right? Not sure if thats consistent with what you just said or not.
Here's what Im calling a Palmer... note the same thermostat housing and "Model 220" decals. I had thought that both Palmer and Conquerer Crusader were Thermo Electrons.
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2013 at 9:37pm
That does show some intermingling between companies.
Cal Connell Script
IH Palmer Flag-Crusder logo
International Harvester Palmer Marine Flag
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2013 at 9:46pm
Never to my knowledge as well. My 54 is actually a Chris marinization painted red (not Chris blue) and tagged as a Correct Craft. It's just a "private labeling".
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2013 at 10:16pm
Correct.   So, a "Correct Craft" labeled engine could be either a Palmer or a Thermo-Electron. (in the 70's) I believe some white Escorts also were labeled CC.
73SN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73SN Quote  Post ReplyReply Direct Link To This Post Posted: January-31-2013 at 12:11am
Yep it looked mostly like the Palmer pictured above. It wont when I'm done tho:
Photobucket pics for my first engine build
I'll add some pics this weekend, been busy.
Photobucket ain't the best but right click and "open link in new tab" for a better look at a pic.
