Teak Swim Platform Restoration Questions |
RedandWhite73
Senior Member Joined: October-03-2011 Location: Minnesota Status: Offline Points: 135 |
Posted: February-09-2013 at 8:08pm |
I recently acquired a teak swim platform for my '73 Southwind. I spent some time searching through old threads to find instructions on restoring it, but couldn't find what I was looking for.
Does anyone have any recommendations? The gentleman at the hardware store suggested that I lightly sand the wood, then apply teak oil. I thought it would be best to run this past the board. Thanks, Dan |
Dan,
All you need to do is go to the CCfan FAQ thread and it will link you to almost anything you need to know. If not, get back to us. BTW, the guy in the hardware store doesn't know how to clean Teak. Get one of the Teak refinishing kits. Cleaning is the most important step. I also recommend gentle use of a pressure washer. |
Brass brush for use with the cleaner. Sanding is optional between coats.
RedandWhite73
Thanks for the links. Looks like this topic has popped up a time or two.
snipe
Senior Member Joined: July-13-2009 Location: United States Status: Offline Points: 157 |
I used the three step Starbrite method with excellent results. I did power wash first (lightly) then the cleaner, then power wash lightly, let it dry and follow the directions from there. I did NO sanding. It gets too smooth for kids getting out of the water.
OldSchoolBlue84
Gold Member Joined: December-02-2012 Location: Valparaiso, IN Status: Offline Points: 814 |
Good job snipe! Will be doing mine this spring. Did you use a certain brush?
Kostas
1984 Ski Nautique 2001 |
snipe
I used a bristle hand brush for the cleaning just to rub the cleaner in good; then lightly power washed. The oil was applied with a small paint brush. Nothing special. Don't overdo the power wash.
NCH20SKIER
TSP from Home Depot / Lowes works well for cleaning.
'88 BFN |
OldSchoolBlue84
Thanks guys, this will be added to my to do list before the boat hits the water this year. List keeps getting longer.
Kostas
Greg, The TSP may work good for cleaning but not brightening. I as well as Egon recommended the teak kit since it has oxalic acid that will remove the gray color. |
