  New Posts New Posts RSS Feed - what engine
what engine
birdiebertus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote birdiebertus Quote  Post ReplyReply Direct Link To This Post Topic: what engine
    Posted: April-14-2013 at 8:35am
hello i need to no what engine i have LH or RH rotation
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2013 at 8:41am
If the prop is on the boat and it's the correct hand, take a look at it. If it rotates clockwise in forward looking at it from the aft and you have a direct drive 1:1 trans, then it's a RH.
BTW, over hear, that automotive air cleaner is against the US coast guard regulations. If you don't mind driving a potential bomb keep it otherwise get a marine flame arrestor. Your fuel line to the carb is also suspect and not USCG. Who's been doing the "hacking" on your engine/carb?
Marine Holleys do not have externally adjustable floats, or sight plugs... both ports are closed up with solder plugs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote birdiebertus Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2013 at 9:59am
i have a RH prop and a 1:1 gear so my engine is a RH engine
so it is not posseble to juse a car start engine
sorry for my bad engels
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2013 at 10:20am
Besides the opposite rotation from automotive, there are components that are used for marine safety. Fuel delivery and ignition protected electrics are the major items.
You're OK with your English. So far, I'm able to comprehend!! Just don't ask me to respond in whatever you typically use!
Got Tiques View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Got Tiques Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2013 at 10:47am
An automotive (car) starter will not work on the reverse rotation motor. Try a shop that rebuilds starters, as they may be able to rebuild yours, or have a reverse rotation stater in stock.
You have a great looking motor, but be careful on some automotive parts that greatly reduce the safety.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Got Tiques Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2013 at 10:53am
b.g.,
Welcome to the site!! There is lots of help here, with many different personalities, but don't hesitate to ask. I do see a pylon with the ring and finger cut off. Too bad for those of us that strive to keep it original, but some replacement parts are found on this site!! How about posting some photos of the boat, trailer and interior.
Todd
Post Options Post Options   Thanks (0) Thanks(0)   Quote birdiebertus Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2013 at 5:18pm
GlassSeeker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2013 at 6:26pm
nice boat
This is the life
