  New Posts New Posts RSS Feed - learning to barefoot
 Post Reply Post Reply Page    <1 8687888990 152>
 Rating: Topic Rating: 2 Votes, Average 5.00  Topic Search Topic Search  Topic Options Topic Options
GlassSeeker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2013 at 6:11pm
Another super good foundation for backtoes is to practice longline 1 foots backwards next to the wake on each side of the wake and be able to ride them and change feet easily at will without hesitation for 5 or more seconds each. You will have to edge to keep your line...different than the straight pull of the boom.
This is the life
footinforever11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote footinforever11 Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2013 at 6:19pm
Agree with Glassseeker on keeping your toe leg bent, or not letting it stretch you out. That will help the retrieval process and keep you from catching your heel.
I ski with straight arms as well. I think that it allows me to be more relaxed. However, when people ski Keith ski with his arms in, it certainly can work. I think that most show skiers that learn to back barefoot by back stepping usually have their arms in as it is necessary to get taller. So that can have some carry over as well. Since you aren't keith, I would experiment with straight arms, and perhaps you will end up somewhere in the middle. In addition to just ll onefoots, have you ever just hooked your foot over the line. You can hook and push down on the top of the foot, and that allows you to get tall like the back toe.. A very good simulation. Another twist is to work on back toes in the front toe handle. If you think its far now, you really have to reach and keep good form to get it. It will make the back toe handle feel like cheating lol.
tbeard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbeard Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2013 at 6:31pm
WOW look at that water Roy is skiing on......No wonder it looks easy:)
Seriously very clean Roy....just messin with ya! Great discussion on back toe holds. Wanna move on to toe holds behind boat?
Thanks.......Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2013 at 7:03pm
Did we skip rule number one?
Find flat water!
This is the life
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbeard Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2013 at 1:01am
Moving tricks from Boom to LL. Please take a look and provide input. Reverse needs some work and stability. Basic seems to track all over the place:) Thx...Tom
Thanks.......Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2013 at 5:06am
go over on the other side of the wake and do the same thing and your reverse will be easier over there.
and I have the same comment as the back toes...(squeeze the cup)try to scissor your legs more to get the rope directly over and inline with the skifoot---I think this is the only reason for the instability and tracking issue. It works, try it.
really you ski well enough that you can still do those toeholds whether you are in the right position or not...they will be easier and more stable just line up the foot and the rope.
This is the life
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2013 at 5:16am
another way to look at it is that if your left foot is in the toestrap you want to "push" or "squeeze" the left leg and foot as far to the right as possible and your right leg and foot as far to the left as possible...crossing them like a pair of scissors to get that rope directly over the foot alignment.
your toeholds will be locked in, on track.
This is the life
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbeard Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2013 at 6:52pm
Thanks....Yes I see the alignment can be an issue. Will try it and provide some feedback.
Thanks.......Tom
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2013 at 1:47pm
Boat Jumps
did my first attemp this sunday... not that bad...landed it kaplastyle (washed, tumble hold it and recovery).
Second attemp same way...
Now what is the recommended speed, and what should I look for on the landing, say jump and look for a 3 point landing, or on the feet?
now I´m happy with my SS!
one foot SS
After the one foot SS...
Post Options Post Options   Thanks (0) Thanks(0)   Quote footinforever11 Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2013 at 1:57pm
The best way would be feet to feet. It would depend on how high you jump in relation to how far away from the boat. The higher the force you hit the water with and higher chances of punching through. You are going to want full speed on your boat. But, it is a similar motion to a 2-ski jump out. Those are easiest feet to feet. Handle in to absorb the landing is good, but you want solidly, but then immediately absorb the landing with soft knees. It is a delicate ratio. If you lean back a bunch you will load the line and your feet will be plowing and not gliding. Conversely too clean or too stiff and rigid will cause you to punch through. You can easily slide into a 3 point. But you don't want to be thinking 3 point from the get go.. that will be too easy to land but first and you will get rocked for sure if you land that way. Think about jumping further away from the boat and going horizontally and less upward pop to make the landings less harsh till you get the hang of it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2013 at 2:11pm
Ryan thanks for the tips! now I need to put some antiskid on the rear deck! gel is super slippery when wet...
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2013 at 2:12pm
Don't do it like this. Try to land softly (ya right) on your feet.
This is the life
skutsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skutsch Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2013 at 2:59pm
So do you think the "boat bomb" is easier then trying to straddle the gunnel and step off (because of the chine spray)?
Post Options Post Options   Thanks (0) Thanks(0)   Quote footinforever11 Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2013 at 3:09pm
Aaahhh noo.. a step off will always be easier than any form of bombout.. why are you straddling the gunnel if you are on a ski.. if its to stay dry, lean over the bar with your weight resting on your stomach, as soon as you have enough speed drop down and walk your hands back to the handle. You will have too much side spray to ski right next to the boat.
A little more clarification would help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote skutsch Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2013 at 3:16pm
Ryan - Elaine demonstrates the "concept" here at the begining. Just seems to be about the most efficient way in and out of the boat when you have a relatively small lake.
Post Options Post Options   Thanks (0) Thanks(0)   Quote footinforever11 Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2013 at 3:34pm
The high boom combined with her light weight and her boat doesn't have nearly the side spray that most nautiques have all contribute to her success. I would think that should be able to through enough of the side spray to make it work.. or grab the boom, work your way out and inch back to the handle. The fastest would be to get on the ski quickly. You should be able to slalom on a high boom at a very low speed, and as the boat accelerates you will cutting away from the spray, should be nbd.
LakeBoy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LakeBoy Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2013 at 3:51pm
Man, that girl is a bad-ass skier. So relaxed. Amazing how high she stands up in her toe-hold. I still can't connect with the hips forward "power-band" that comes from Lane Bowers, though. Works for her, but looks like extra effort to load into that position.
Got Foot?
Post Options Post Options   Thanks (0) Thanks(0)   Quote skutsch Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2013 at 4:02pm
Roy - come on you know who that is, That's Elaine Heller, #1 or #2 skier at the last couple of worlds, I believe she still holds the Jump world record. What's really crazy is driving for her, my only comment was, sure I'll drive, but no crazy stuff, I would feel wrecked if you get hurt while I am driving - HA!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2013 at 4:07pm
She's great. That 180 while in a toe hold seems like it could be really hazardous to the knees.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2013 at 5:01pm
I don't have video but with a non-extended boom and a 5 ft handle we used to swing in and swing out at speed...a gunnel step out/in....most of my old barefoot crew did it all the time but I can only swing out, can't swing in because I have super high arches--flat feet help here bigtime to get a fast quick cut to the boom/gunnel.
Andre has tips here:   Boat Jump out / in
This is the life
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2013 at 5:09pm
I like Georgia's style...she is breaking all the records.
This is the life
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2013 at 5:11pm
To you old timers...remember when tumble turns were cool and got ooohs and ahhhs from the crowd? Man, I'm feeling old.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2013 at 5:16pm
I do the swing out, cut in method Andy is describing but can't reach the boat, just the first foot of boom outside the gunnel. skutsch, you should have video of this from Twin Lakes with RJ. Sidespray can be an issue for slower speeds and the unprepared.
Post Options Post Options   Thanks (0) Thanks(0)   Quote skutsch Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2013 at 5:28pm
Ok, yep got it, here is the method that Ryan and Andy were explaining. A little different then Elaine's technique, which I believe just requires great one foot ability. I believe when I tried this (this video)I had a little slack in the rope which was catastrophic...
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2013 at 5:33pm
side spray?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2013 at 5:39pm
Paul McDonald does the over-the-gunnel step out AND in method bacwards in one of his BFC Freestyle Challenge videos. My rope is not long enough, that's my excuse! kapla, when are you going to tighten that inner cable??
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2013 at 5:42pm
geez, soon, in my todo list for this WE...
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbeard Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2013 at 8:11pm
Good point Larry, It is amazing to me how easy it looks by a pro. Or when you are at a ski school or in a clinic it seems so much easier to accomplish new things. But when I am out with my local skiers on a routine weekend the progress is so slow and takes so much effort. B. Paige make a good point last summer stating he skies 7 days week/ 30 days a month - year round. I ski on average 30 - 40 days per year give or take a few. At that rate it takes years to accomplish some of the things we see in the videos. Great sport but not an easy one to master.
Thanks.......Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2013 at 9:40pm
tumble turns still get the oohs and ahhhs from the crowd because no matter who does it it "looks" hard...a nice clean front to back looks too easy...to most crowds.
I really don't think the TT gets the respect(points) it deserves.
This is the life
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2013 at 9:43pm
This is exactly why it can keep your attention for years.
This is the life
