  New Posts New Posts RSS Feed - Craftlander Boat lift
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2013 at 6:31pm
Get a price on new unassembled.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2013 at 7:21pm
Lift cost is highly dependent on your location. A good used 3-4k lb manual crank lift (no canopy) fetches $1500 here in the northeast all day long. Used ones come up rarely and don't stay on the market long.
I'm very envious of the Midwest prices... Most seem to be made in wi or mn, so surely that's a huge factor.
dwouncmd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwouncmd Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2013 at 10:04pm
The deal breaker for me may be the move (trailer, permits in two states?!). In some ways, it would be worth it to have new one delivered unassembled.
89 SN
<a href="http://www.correctcraftfan.com/diaries/details.asp?ID=6567&sort=&pagenum=1" rel="nofollow">7
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2013 at 11:16pm
Permits?
P71_CrownVic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote P71_CrownVic Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2013 at 11:19pm
Originally posted by dwouncmd dwouncmd wrote:
To add to the thread, I am hoping to pick up used Shore Station SS-36108A, so I will be going through the all of the above starting with moving it 4 hours, probably on a pontoon trailer. I have never had a Shore Station (or any other kind of lift for that matter). Is there any chance I can get away with using the elevated bunks for the 89 SN and Tique vs. the more radical solution Pete used? I probably have less than 4 feet of water at the dock when the lake is low. Is it possible to set up the bunks to accommodate the 89 SN and the 78 Tique? Is there anyone in the Triangle with Shore Station experience (or a toon trailer to loan for that matter)?
I have that exact lift and bought a bunk kit to make it SN friendly. I will measure and take pictures tomorrow of my low water example as I just got the docks and lifts in today. Our water is controlled by a dam (for now)and is lowered 3' in the winter. I'll take some pics and post them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwouncmd Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2013 at 11:23pm
Permits?
Wide load...
89 SN
skutsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skutsch Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2013 at 12:42am
If this is the lift, and it is too wide, it appears that if you rotated it 90 degrees, it's height, less then it's width now might fit where you don't need permits. Again, this is all a guess, you would have to do actual measuring.
But as Tim (TRBenj) said, "Permits???"
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2013 at 11:09am
Wayne,
Go back to my UHaul post, I have moved a SS lift that exact way, everything will be in the trailer, it does end up tall but no permits required, guaranteed!! Around here the dual axle open trailer can not be rented one way and only the larger dealers have them, so I did have to pull it round trip, never have had in issue renting UHauls.
Good suggestion on purchasing new unassembled, the Shorestations do go together pretty easily.
Post Options Post Options   Thanks (0) Thanks(0)   Quote P71_CrownVic Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2013 at 12:34pm
Ok, I measured and took pics this morning. My bunk kit is 15" from the base of the cradle to the top of the bunks. The cradle itself is around 5"-6" thick. At the front of the lift, I have just under 22" of water measuring from the foot pad of the lift to the water surface. At the back of the lift, I have just under 31" inches of water measured the same way. With the lift fully lowered I have about 6" of water above cradle.
Front depth:
Rear Depth:
As low as it will go:
Idea of how low the water is in the winter (for now):
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwouncmd Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2013 at 11:12am
Everyone, thanks so much for your help! Bad news though, I found out this morning that my wife is going to have to have surgery, which may lead to more surgery and will require long term follow up either way. I had to let the owner of the lift know that I can't make it Virginia this weekend. I wouldn't be surprised if I lose the deposit I gave him to hold the lift.
89 SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2013 at 7:34pm
Wayne,
I wish your wife the best for the procedures she needs to go through. Our prayers are with her.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwouncmd Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2013 at 12:33am
Thanks Pete, that means a lot.
89 SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2013 at 11:48am
Yes, best wishes from us as well, everything will be OK is my favorite thought!!
Considering what you got going on, wish Virginia was closer, I would go get your money, the lift or both.
Post Options Post Options   Thanks (0) Thanks(0)   Quote skutsch Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2013 at 2:18pm
Wayne, hope it all works out, prayers headed your way. Hopefully the guy with your deposit is understanding...
