  New Posts New Posts RSS Feed - Bow Stop Assembly
Bow Stop Assembly
gsyogi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gsyogi Quote  Post ReplyReply Direct Link To This Post Topic: Bow Stop Assembly
    Posted: May-19-2013 at 12:10pm
I am preparing to strip down the bow stop assembly this a.m. and have a question concerning putting it all back together (note that I will be drilling new holes for the assembly hardware before coating the wood with CPES). Here is the port side bow stop:
Here is the starboard side bow stop:
From the front:
And, I think most importantly, from the top:
Now to my question, it appears (at least to me) that the port side is the "factory" set up and that the starboard side was replaced by a prior owner. As it is now (see the photo shot from the top view), the port side is offset some 1 3/4" from the bow stop mast, while the starboard side is offset only 3/4." Question: Should I leave the spacing/offset the same as it is now our should I make it even ... both set at 1 3/4"—my question concerns how the SN will load and ride on the trailer (I am recovering the existing bunk boards). Thank you ... and I hope this will be my last question for a bit!!!
Oh yes, a pic of my new boards:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2013 at 1:33pm
The offset does not matter.
jimsport93 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimsport93 Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2013 at 1:43pm
Mine are both at what appears to be 1"3/4".
Would think that putting them both at that offset is correct. Even them up for better "eye appeal" also. Good to have a little wiggle room up front too.
Air206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2013 at 8:20pm
I changed mine to plastic - Zach and Townsend have 'em.... they bolted right on and are AWESOME! I am soooo done with carpet up there......
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2013 at 8:29pm
The plastic on the '91 looks just like what is on my '04...
