  New Posts New Posts RSS Feed - Coil radio connection?
Frankenotter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Topic: Coil radio connection?
    Posted: May-21-2013 at 12:01am
When I was out on the lake last week I killed the engine and just wanted to have the radio on.
However,
If I turn the ignition (breaker/switch) off it kills the radio. When I turn it on I think the coil is energized. I put the multimeter on the posts of the coil with the ignition on and I was getting 6V.
I'm slightly confused why its 6 and not 12V and wondering of the radio is wired improperly. I don't want my coil energized while km just floating along.
Ideas?
Chris
1999 Ski Nautique 196
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2013 at 12:54am
Can you just hook the radio up to one of the acc breakers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2013 at 3:34am
I definitely could and probably will. I was just wondering if there was a reason for the way it is now. Based on how the radio was wired when I got the dash open, I wouldn't be surprised if the PO just picked the ignition switch at random.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2013 at 6:47am
Ideas?
Chris
Yes, it's because you measured voltage incorrectly. Don't go to the negative post on the coil. It goes through the distributor to ground.
Positive probe to the positive side of the coil. Negative probe to ground (engine block or equal).
Also, you have the ballast resistor reducing voltage if you still have a point set and not an EI conversion. Try it again. You should get closer to 9 volts.
backfoot100 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote backfoot100 Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2013 at 10:09am
I think this is pretty much standard practice. The radio has to get powered someplace and it's normally through the ignition switch unless you have some accessory switches. My boat was wired that way.
I didn't have any accessory switches to wire it to so I opted for a new ignition switch with an ACC setting like your car has. My radio is wired through that ACC position now and I can listen to it without powering the ignition system.
Eddie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2013 at 11:41am
Ideas?
Chris
Pete that makes complete sense now that you say it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2013 at 11:43am
Thanks eddy, good to know you've done this as well.
Ill take some pictures and post them here for others next time I get to the boat.
Cheers!
